Can't change channels
Can adjust volume but can't change channels
  • 1 more comment
  • lwchr225 Nov 14, 2008
    can't ascess the menu, but sound works, can't change channels
  • timlpz Mar 08, 2009
    I cannot change the channel on the TV to channel number 3 for the cable setting.
  • katybrook22 Apr 18, 2009
    I cannot get the channgle to change but the volume and everything else works.
  • 85 Answers
Check to see if youhave the speakers turned off on the tv menu
Posted on Nov 14, 2008
Controller will only turn equipment on and off. Can't do anything else, ie: adjust volume, change channel, etc. Universal MX-900 Remote
Hello, Reset the remote control and use with the equipment . If it does adjust volume, change channel. then use have to get another one of different model
May 20, 2010 | Universal MX-900 Remote Control
Tv is stuck on aux
Push the "menu"button on the front of the unit. That will get you into the menus to adjust any setting, like caption, language (but that one is tricky if yours happenend to be set to a language you couldn't understand :P), brightness settings and the such are there too. The one you are looking for is "input", change THAT setting. with either volume up/down +/-, or channel up/down (+) (-). In the menu, change the "input" selection to cable or whatever you are trying to watch on the tv.
Hope this helped some, if so, please rate, thank you!
Channel setup
V-Chip Setup
Caption
ect.
Using the Volume + and - along with the Channel up (+) and down(- ) key's, will give you all the adjustments you may need without a remote control.key's, will give you all the adjustments you may need without a remote control.
Feb 02, 2010 | Durabrand DWT1905 TV
When I adjust the volume on the remote control it changes the channel, but not on every occasion.
Hey,
This could be due to the accumulation of dust inside the remote control. You can try to open up the controller and just clean it up.
Thanks
Apr 15, 2009 | Televison & Video
Left Surround Channel
Try to tighten the screws at the back where you insert your A/V jacks.
Thanks!
Apr 10, 2008 | Onkyo TX-DS575 Receiver
Samsum PLH403W service menu
Here is how you get to the service menu. Just be sure to write down anything you change in case you want to change it back.
1. TV turned off
2. Press 'Mute' then '182' then 'Power' buttons on the remote.
You are now in the Adjustment mode
4. Use the 'Channel up'or"Channel dwn' to select the category.
5. Use the 'Volume up or dwn' to enter the category.
note:Some models may not have Category Selection.
6. Use the 'Channel up or dwn' buttons to select item to be adjusted.
7. Write down the old value of the item before changing.
8. Use Volume up and down adjust the value.
9. When you have made all the adjustments you want turn the set off to exit.
Feb 01, 2008 | Samsung PLH403W 40" Rear Projection...
Service menu
1. TV turned off
Jan 23, 2008 | Televison & Video
TV turns on and changes channels on its own
Keeps changing channel
Check voltage on D12 if below 4.8V then change
Changes channel or volume adjusts by itself
Check S900/1/2 on pcb H1, alternatively this could be due to failure of IC005 (CD4052BCM-FL63) on pcb A
Oct 17, 2007 | GE 31GT740 31" TV
Televison & Video Logo
134 people viewed this question
Top Televison & Video Experts
