Question about Whirlpool Duet GHW9150P Front Load Washer
Water Leakage Under Front Load Washer
Water leaking under the washing machine NOT through the door or any hoses; when a light is shined under the machine, I can see the water dripping. I pulled a sock from the fold of the seal, and it appears that the bottom part of the seal is not sealed all of the way. Does a seal need to be replaced, if that is the problem, or does the seal need to be redone?
  • Anonymous Mar 17, 2014
    water appears to be leaking from the soap box. water leaks down the front of machine. checked and not door seal . soap box looks the only likely area . cab the soap box split ? where can the leak originate from
  • Anonymous Mar 24, 2014
    Water leaking out front whenever machine is on
    Novelist:
  • 159 Answers
Most likley cause of your problem is the grey bellows has a tear in it. Inspect the bellows to check for tears. Or you can remove the lower panel and run the washer and look for the leak that way. Im sure it is a tear in the belows. Not a diffacult part to replace if you are mechanicly inclined. Good luck.
Posted on Jul 12, 2007
Look for split in door seal...that is the prob i hav at the moment....mainly at the bottom where the water wells when drum is still... if so u might be able to move doorseal so that split is at top...it is awkard but saves u buying new seal.... and yes u might have to fix the seal properly . 1 open door 2 find and pull off wire retainer..it has a spring which can be stretched a little... 3 carefully place door seal into grove all round lip of door jam and replace wire back in place with spring in same place as before.. near hinge probably.... hope thats helps
Posted on Jun 11, 2007
Water leaks from under washing machine after each wash
If it is a top load washer, you can tilt the machine back to where you can look under it to see if you can see the leak. If it is a front load washer, you will need to take the top of the unit off and start checking all parts that have water running through it. I would start by looking around the door seal for any rips, tears or holes. If you don't see anything there, look under the tubs at the drain pump and hoses. Sometimes underwires out of bras put a hole in the tub-to-pump hose.
Feb 27, 2015 | Washing Machines
Leak around Duet wash machine
Leakage from under a top loader often indicates either that the pump is leaking or there is a leak in one of the hoses
Apr 24, 2013 | Washing Machines
I have a LG front load washer seem to leaking front area. Hoses OK Need o see what causes it to leak
you will need to narrow down where the water is leaking from. under the door...? behind the bottom drain door..? underneath machine..? behind machine..? leaks can be found in many areas.
May 16, 2011 | LG WM-2277HW Front Load Washer
I have an LG front loader washing maching, model# WM2277H* I have changed both the hot/cold water value and the washer is still leaking.
if leaking on front unit : check rubber seal front glass door. if it ripped you should change it.
If leaking behind unit : check water hose , is it placed properly ?
If leaking under unit : call technician to repair it.
good luck.
Mar 25, 2011 | LG WM-2277HW Front Load Washer
I have LG WD -1050F Intellowasher 7kg front load washer, while operating time getting water leakage under front door. need solution.
The problem is due to the rubber boot is been torn that is causing you the leak. You have to check the rubber boot for leaks by removing the clamp assembly that secures the rubber boot to the outer lip of the door opening. Peel off the rubber boot then inspect it for any holes where it may be leaking. The rubber boot in your washer can be accessed only when you remove the front panel. This requires the removal first of the top panel then the console. Also check your inlet hoses on the outside of machine, also check the connections inside the panel in back.
Thank you !!
Jul 26, 2010 | LG Washing Machines
My LG front load washer is leaking during the rinse cycle. I cleaned the filter and it is still leaking. What should I do?
Leakage can be a few things..Check the door boot seal for any small rips, next the fill hoses are the watertight, next drain hose , now under the machine is the pump ok, Last assuming all hoses are ok has the drum a hole in it...good luck
Apr 19, 2010 | LG WM-2277HW Front Load Washer
Leaking water from the front of the washer checked the hoses and they are not leaking
If this is a top load washer the problem is usually the pump. If you can tilt the washer up at the front and support with two pieces of 2x4. Shine a light under the maching and take a mirror to observe. Fill the washer 1/2 full of water and advance the time into the spin cycle. Observe under the maching to see where it is leaking. The pump is located at the front of the washer. If the pump is leaking, replace the pump.
Dec 29, 2009 | Kenmore Washing Machines
There is water leaking out of the bottom of the washing machine
I would check to see if the pump is leaking. Tilt the washer up and put on two peices of 2x4. Shine a trouble lite under washer and take a mirror to look under the washer. Fill 1/2 full of water and advance timer to the spin cycle. Observe to see where the water is comming from. The pump is located at the front of the washer.
If water is leaking from the pump. Replace pump.
Dec 29, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Water leak
Remove the lower panel under the washer door and inspect the interior. The panel is removed by loosening and removing the screws under the bottom front edge. With the screws removed the panel will drop down, then off. Inspect the following areas:
- Check all hoses for leaks, cracks, holes and loose connections. Check the seal where the drain hose from the bottom of the wash tub connects to the intake of the drain pump. Make sure the drain hose from the pump to the standpipe is connected snug to the pump and is not leaking.
- Check the drain pump to ensure it is not leaking. The clean out reservoir cap (if not fitted properly) can leak around the seal.
- Check the door bellow (gray rubber boot) to ensure it is not leaking. HINT: A tale-tell sign of bellow leakage is wetness showing up on the front washer counterweight. This is a concrete block mounted to the front of the wash tub. It is not supposed to be wet.
- Check the pressure switch air hose to ensure it is connected to the air dome on the side of the wash tub. This is a small rubber hose that runs from the pressure switch in the top left rear of the washer (viewed from the back, with the washer top panel removed) to the bottom right hand side of the wash tub. However, if this hose were to come off the air dome fitting, the wash tub would continously try to fill and water would begin to pour from the bottom of the wash tub. If this does not sound like your symptoms, disregard this step.
- Check the seam where the wash tub shells meet. There is a rubber tub gasket that seals the two tub halves together. If the seal is bad, water will begin to collect and drip along this seam.
- Check the tub for cracks. This is NOT common, but it can happen.
The following link explains the step-by-step process of checking and cleaning the drain pump:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
I mention this link, because it gives you some guidance on how to access the pump and how avoid the possible mess involved with water pouring out of the pump.
If you discover the door bellow as the the cause for your leak, please refer to this link:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
I hope this leads you in the right direction and helps you resolve your problem. Please post back if you have any further questions.
Aug 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
1,251 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
