Question about JVC KW-AVX706 Car DVD Player
All stored settings are lost everytime i switch of my car.
When i switch my car and made all the desired settings like, equalizer, wallpaper etc. it is stored but as soon as i switch the car of and switch it on again, all stored settings are gone, what should i do?
    Scholar:
  • 121 Answers
You have not installed your radio correctly........
there is suppose to be 2 power in for the radio
1 that holds memory for the radio has to be picked from a line that has power available to it even if the car is switched off
and the other just to switch on the radio itself...normally responding to ignition
check to verify that you have connected the memory power for the radio correctly and that that line has power even though the car is switched off......
use dc tester to test that it has power available
This will work for ya
keep me posted
Please don't forget to vote
Cheers!
Posted on Nov 14, 2008
Sony how to change the bass on my sony mex bt3100u stereo
Hello Tom,
You may have to adjust the EQ7 Preset to XPLOD and then listen to the jam. Here are the instructions from the bt3100u manual:
Selecting the sound quality
- EQ7 Preset
You can select an equalizer curve from 7 equalizer curves ("XPLOD," "VOCAL," "EDGE," "CRUISE," "SPACE," "GRAVITY," "CUSTOM" or "OFF").
1 During reception/playback, press the select button.
2 Rotate the control dial until "EQ7 PRESET" appears, then press it.
3 Rotate the control dial until the desired equalizer curve appears, then press it.
4 Press (BACK).
The display returns to normal reception/play mode. To cancel the equalizer curve, repeat the first 2 steps then select "OFF" in step 3.
Tip
The equalizer curve setting can be memorized for each source.
We hope that this helps. If not please return and post how this went.
Nov 24, 2013 | Computers & Internet
Tip
Changing folder background
do you want to change the folder background?
do the following steps:
1. Open Command Prompt and set folder attribute to "system". Suppose there is a folder "Setup" in "D:\" drive, in which you want to set a wallpaper as background image. So give following command in Command Prompt:
attrib +s D:\Setup
It'll change the attribute to "system ".
2. Now open Notepad and paste following code:
[ExtShellFolderViews]
{BE098140-A513-11D0-A3A4-00C04FD706EC} = {BE098140-A513-11D0-A3A4-00C04FD706EC}
[{BE098140-A513-11D0-A3A4-00C04FD706EC}]
Attributes=1
IconArea_Image=path_of_the_wallpaper
IconArea_Text=0x00000000
Now change "path_of_the_wallpaper" to the exact path of the wallpaper which you want to set as background. Suppose the wallpaper is stored in "D:\Wallpaper\Image1.jpg", then the code will be as following:
Attributes=1
NOTE: If you copy the wallpaper in the same folder which you are editing, then you can simply put the wallpaper name in the file. e.g. if you copy the "Image1.jpg" file in "Setup" folder, then the code will be as following:
Attributes=1
"IconArea_Text" stands for the text color, you can change it to white, yellow, blue, black or any other color. You just need to know the hexa-decimal number of the color and then replace the code in "IconArea_Text" section. A few most used color codes are as follows:
Black - 0x00000000
White - 0x00FFFFFF
Green - 0x0000FF00
Blue - 0x00FF0000
Purple - 0x00C000C0
Red - 0x000000FF
Yellow - 0x0000FFFF
Indigo - 0x00FFFF00
3. Now save the file with name "Desktop.ini" (including quotes) and copy the file in the desired folder which is "Setup" in our example.
4. Thats it. Close the folder and re-open it. Now it should show the wallpaper as background.
on Sep 10, 2010 | Computers & Internet
I restored the factory settings on my phone. All the files, messages, contacts, etc. were deleted. The Ovi, Communities, and other applications were also gone. I can't even
In my opinion there is no solution.I thought that you have selected "Restore All" while you restore the phone.For the application you can recover by flashing or you can download. Nokia Store: Download games, themes, wallpaper, ringtones and mobile apps on your Nokia phone.Good luck
Apr 02, 2012 | Nokia C3 Cell Phone
How do you change the screen on a samsung conquer
Hi
Press menu.
Swipe side to side until you arrive to the wallpaper option.
Tap on wallpaper.
Select the desired wall paper option and tap on it.
Scroll the desired wall paper and tap on set wallpaper.
Good luck
Feb 23, 2012 | Samsung Cell Phones
To set wallpaper to maximum size
Sorry buddy . .
Unfortunately you can't set full screen wallpapers in phones like Nokia n72 and n70..
To have full screen image, it should be part of theme!
So the only possible way is to create a theme using the image, but it isn't so easy.
try to make your themes with desired wallpapers in www.ownskin.com
Hope this helps...
Sep 02, 2011 | Nokia N72 Cellular Phone
Nokia 5800 everytime is press to go on the internet it says packet data connection lost what or how do i fix this ?!!! grrrrr
Do a Master Reset:
CAUTION: A "master reset" changes the phone settings back to default. This process will erase all contacts, downloaded settings, and downloaded applications (ringtones, wallpapers, graphics, etc). This process cannot be undone.
Enter*7370# from the standby screen. And the default phone code is 12345
Feb 23, 2011 | Nokia 5800 XpressMusic Smartphone
How do you get just a picture on the front of your phone
If you want to get a picture on the front of your phone do this:
Go to Menu--Settings--Display and Light--Wallpaper (If you have the picture in the wallpaper gallery then select it and click 'Set' and if you've got the picture in the different directory then go select 'images' and then go to the desired directory crop and click 'Set')
I would recommend this software Samsung Wallpaper Creator small in size but handy for creating wallpapers for your mobile where you can have 3 wallpapers in one and slide according to your choice on the phone.
Click on the link and go to the download Tab on the top and download the Zip file which is of 2.5 Mb aprox. Install on the PC and start creating wallpapers.You should use 240 * 400 size wallpaper aprox.each in the box.
If there's more help you need let me know.
Good Luck.
Jan 22, 2010 | Samsung SGH-S5230 Cell Phone
How do i put wallpaper to screen size on the s5230
Click on the link and go to the download Tab on the top and download the Zip file which is of 2.5 Mb aprox. Install on the PC and start creating wallpapers.You should use 240 * 400 size wallpaper aprox.each in the box.N you can always search for the pics on Google.
Good Luck.
Jan 18, 2010 | Samsung SGH-S5230 Cell Phone
HOW TO SET THE DRIVER SEAT
  1. Adjust the seat to a desired position.
  2. Press the memory set switch. A chime confirmation will be heard.
  3. Press the desired switch (switch 1 or switch 2) within 5 seconds after pressing the memory set switch. A chime confirmation will be heard.
  4. The position is now stored in the memory. The position is now available for recall.
Nov 26, 2009 | 2000 Oldsmobile Bravada
Background keeps changing everytime i shake my cect i9 phonee
hey yes you can diable the shake feature on both the wallpaper and the music player
1. go to settings
2. hit phone setup
3.on the next menu go allll the way down to the bottom and you will see Gsensor swich wallpaper
and gesensor switch song. trust me its there u just gotta keep scrolling.
4. click off on them both and you have it.
hope this hepls, cuz hat shake is annoying
Dec 31, 2008 | Dual Electronics CECT P168 Cellular Phone
JVC KW-AVX706 Car DVD Player Logo
110 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
