Question about True 3 Keg Direct Draw Beer Dispenser, Black
Cooler is freezing my Beer!!
I am all about ice cold beer, but not frozen beer. Especially when we are selling it. It can ruin my beer if it freezes and then thaws. The thermostat is turned all the way to the lowest setting. Everything in the cooler freezes. The coil has also been cleaned. What now? What could it be?
  • 237 Answers
Could be the thermostat isn't working and the unit is just running and running all the time. To me that seems the most simple explanation right now. Can you check the temp inside when on the lowest setting for a day, then turn it up to the highest for a day and see if there is a huge difference in temps? Does the compressor motor ever turn off or does it run continuously? Suspect that t-stat...
Posted on Nov 24, 2006
What is the correct temperature for beer? Or wine. Or pop? Please
Hi Laraine:
Beer:
- If you're British, warm. Canadian, wet. Otherwise, who cares?
Wine:
- white - chilled, red - warm. If you're Canadian, wet.
-Pop - cold, but if you're Canadian, stick to beer and wine so....... Who cares?
Cheers
Jun 06, 2016 | Furniture
If the dial is labled 0-9 what nimber is the coldest?
0 is warmwst,9 is the coldest.set it at +2C so that wine/beer dont freeze.beer is best served at 2c.
Dec 31, 2010 | True TBB-2 Beverage Cooler
The temp guage does not work and when the keg cooler is plugged in it gets down to 20 degrees and freezes the beer. Can this be fixed?
This solution probably costs more than you care to spend on the problem, but you can buy an external temp controller like this one:
http://www.amazon.com/gp/product/B0002EAL58
You run the probe into the fridge and plug the fridge into the controller. Then the controller will only turn on the fridge if it gets warmer than the temperature you specify.
You might be able to find it cheaper on ebay, too. I'm using this on a kegerator and can keep my beer at a consistent temp.
May 10, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
True cooler frezzing kegs of beer
If I am not mistaken, the True line-up of coolers have a temp control on them that is labeled 0-9.
This particular type of temp control is a coil temp control. I measures the temperature of the coil rather than air temperature.
Always set the control to the warmest setting and move it colder by one number at a time until your product reaches and holds designed temp. Do not go by cooler air temperature as there will be a great swing in temp especially if the doors are used frequently. Always temp the product. In the case of beer, your ideal holding temp is between 35-38°.
If you set the temp control to the warmest setting and the cooler is still freezing product, you will need to have the cooler serviced be a refrigeration tech. It will most likely be a bad control but there may be underlying problems.
Jan 08, 2010 | True TBB-2 Beverage Cooler
I own a true 2 keg beer cooler and it has recenty been not able to turn off the cooler and freezes the beer. is this a problem with the thermostat or something else?
This is probably the thermostat stuck closed and bad. Turn the tstat all the way to left or counter clock wise. The compressor should turn off.If the compressor continues to run the tstat is stuck and bad. A good replacement tstat would be Ranco # A12-1560.
Nov 08, 2009 | True TD-50-18 Beverage Cooler
Beer cooler keeps freezing
Could be but sounds like it may be low on gas. What emp do you set it at. Should be about 35 degrees if you have it set to low it will ice up on you. Russ
Jul 21, 2009 | Beverage-Air DW49 Stainless Steel Beverage...
I have a Sanyo kegerator that will not cool enough. I have set the thermostat as cold as it will go and it will only go down to about 42 degrees. What can I look for?
Drop thae stat it's a screw on the left side that controls temp.Don't rush this you don't wnt to freeze your beer. 1,5 turns to the left will take you down to ice cold beer.
Nov 18, 2008 | Sanyo Refrigerators
Keg freezing!!!!
Same problem here. Can you give me their number? cheekychap@bellsouth.net
Feb 20, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
BEER COOLER ICE PROBLEM
First, dont overstock your beer, good circulation is key. Make sure your condenser coils are clean. Find a happy setting with the help of a thermometer to cool between 35 - 42 degrees. To defrost I put big zipl-loc bags of ice on top of beer. Turn temperature all the way up (the compressor will cut off but the fan will keep running) for a few hours. When the ice is thick i put HOT water in a squirt bottle and spray sections in the ice. Play around with that and see if it works. Hopefully you don't have a bad condenser. Good luck!
Jan 31, 2008 | True TD-95-38-LT Beverage Cooler
True 3 Keg Direct Draw Beer Dispenser, Black Logo
871 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a True Refrigerator Expert? Answer questions, earn points and help others
