Question about Kenwood KM300 Chef Stand Mixer
Kenmore 201 Mixer
I have a Kenmore 201 mixer that is very old but has never been used. There is grease leaking from the vertical shaft. On looking in the filler hole on top I can not see any oil/grease (the gear is exposed). Your site talks about the same problem and says to use vegetable grease. What is vegetable grease. The leakage is a brownish colour.
  • Anonymous Mar 15, 2009
    I had the same problem when I got mine from my Mom. I cleaned up the grease whenever it showed up and I just used it it. It Lasted a long time.
Oil leaking from the attachment head
The grease leaking out of the KitchenAid mixer can be a common problem. Here is the cause, and how to fix it, and prevent this issue from happening in the future.
The KitchenAid mixers use a Benalene 930-2 grease inside of them. It is a dark, thick grease that can break down and leak out of the mixer. The grease is a non-toxic vegetable based grease, basically it is a food grade grease. Over time, or if you do not use your mixer often the grease can break down, so it would appear that there is oil leaking from the mixer. It is most common for it to leak from the beater shaft (agitator shaft) and from the drip ring.
What you need to do is take the mixer apart, clean out all of the old grease, replace it with about 6 ounces of new food grade grease (http://www.mendingshed.com/kagrease.html). It is also recommended that your replace the o-ring on the center shaft (http://www.mendingshed.com/67500-55.html) and the gearbox gasket (http://www.mendingshed.com/mixergasket.html).
To prevent the grease from breaking down in the future if you do not use the mixer very often, it is recommended that you pull the mixer out and run it for about 2 minutes every 3-4 weeks, this should stop the grease from breaking down as quickly.
Please let me know if you have any questions.
This applies to mixer models, K45, K45SS, KSM75, KSM90, KSM103, KSM110, KSM150, KSM151, KSM152, K5, K5A, K5SS, KSM5, KSM50P, KP50 AND KPM5
Thank you,
Colleen
Customer Service
MendingShed.com
customerservice@mendingshed.com
800-339-9297
Apr 15, 2013 | KitchenAid KSM150PSGR - Artisan Series...
Oil leak
instead of putting a gasket on tell him to take out all of the old grease out that is what has broken down and turning into oil causing a leak and if he can repace the seal around the agitator shaft replace the old grease with a high temp bearing grease or a good quality lithium grease
May 25, 2010 | Hobart A200 Stand Mixer
My kitchen aid mixer is leaking oil or grease from the center shaft. When I opened the planetary there was grease in it. is there suppose to be grease there? is there a seal needed for the center shaft?
Hi TIOBEAN, by the symptoms you describe it appears the Center Shaft ‘O’-ring and quite likely the Transmission Gasket need to be replaced. You don’t mention how old your Artisan mixer is, but I assume it is out of warranty.
The internal gears of your mixer are factory packed with enough grease to last a 'lifetime'—whatever that means, and depending on the age of your mixer, where it was stored, degree and intensity of usage; these factors all contribute to the breakdown of the grease into its constituent parts (oil and suspenders), which have seeped beyond the gasket and ‘O’-ring, down the planetary (agitator shaft). Gravity can be very insidious. The residue coming from the agitator shaft is the gear lubricating grease oil that has come out of suspension.
So how bad is this oil leak problem and what can you do to fix it? First, if the amount of oil found leaking was small and if your mixer otherwise works normally with the missing oil you really don’t need to take your mixer apart to ‘fix’ it. The good news, though, is that you can take the mixer apart and 'fix' it, if you feel it is necessary.
It would be helpful to have the Part List manual as a reference. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home. Having the Parts List on hand will also be helpful as you will have to disassemble and reassemble your mixer to replace the ‘O’-ring and gasket.
Click on Customer Care>Locate Manuals & Guides> and enter the 6 character model number, KSM150 and select the file KSM150PSWH0.pdf (773.44 KB) listed for your model that appears under Parts List (61), and save that file to your PC.
Turn to pages 6 & 7, titled:”Case, Gearing And Planetary Unit” and locate Illus. No. 28, Center Shaft & O-Ring; particularly Illus No. 15 & 16, Transmission Gasket and ‘O’-Ring respectively. I suspect these parts have failed and will need to be replaced. Now the real fun begins!
To get to the Vertical Shaft you’ll need the following tools: a regular or Phillips screw driver, retaining clip pliers, and a small drift pin punch and a small hammer. After removing the Gearcase Motor Housing (mixer top) you will need to remove all the lubricating grease from the transmission housing and gears. This will allow you to remove Illus No. 11, 13, & 14, Bevel Pinion Center Gear, Pin (Vertical Center Shaft) and Groove Pin, respectively.
You should now be able to tap the Vertical Center Shaft (Illus. No. 12) down through the Lower Gearcase housing to access the ‘O’-ring.
Besides ordering a new ‘O’-ring (Illus. No. 16) and Transmission Gasket (Illus No. 15), you’ll also need to replace the grease you removed with new grease. Do not try to reuse any original grease as it may have ‘debris’ in it. You should use a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call).
With your mixer apart and the grease removed from the gears you can check them for any other unseemly wear and tear, too.
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com (for grease). You should search for ‘food grade grease’ online (although I’ve seen automotive bearing grease used too – your call). Prices can vary widely between vendors, so do some comparison shopping.
Here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble, determine what’s wrong, order the correct parts and reassemble your mixer.
Good luck. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Feb 09, 2010 | KitchenAid KSM150PS Artisan Series Stand...
How do you change the grease in a D-300 Hobart Mixer?
Depending how old the mixer is they used to use oil,now they use grease.Regardless it sounds like a seal is worn.Where is it leaking from?
Mar 28, 2009 | Hobart D300 Stand Mixer
Model KSM90 10 speed ultra power stand mixer leaking oil at the shaft where mixer tools attach. Is there a repair kit which includes a oil seal or something like that at a reasonable price?
Hi. Your mixer needs to be serviced, have old grease and oil removed, parts cleaned, then re assembled with new grease. Remove the tapered-pin from the planetary gear, remove planetary gear, clean lubricate and re install. Chevron FM ALC EP-2 is a "Food Grade" lubricant, meaning that it's safe for human consumption if it accidentally gets into food. There are no seals, only bushings. The existing bushings will hold back the new grease. The oil has separated from the base of the grease. If you don't use your mixer very often, start it up about once a week to keep the grease properly mixed.
If you'd like more info on your mixer goto kitchenaid.com, look up your model # download the PARTS drawings. Use these drawings to re-assemble and to determine if you need any replacement parts. Be prepared to wait at least a month for your parts to arrive.
If this Solution assisted you, please rate it. ricardok45
Mar 06, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Food made with KitchenAid Stand mixer tastes like grease
The likelyhood of grease coming from the mixer is extremely small. As long as the beater & bowl were washed first and the shortening you used was fresh, there shouldn't be a grease taste.
Feb 17, 2009 | KitchenAid KITCHEN AID 5 Quart Artisan...
Oil leaked from Kenmore mixer- model mumber 201
This kind of unit are lubricated with grase paste. If the unit stays inactive for a long time, or if the motor and gears are overheating the grease paste gets melted into thin oil, and that will cause the leak.
The oil leak is usually coming from the gear box inside the appliance.
To fix the problem the unit must be taken apart, and cleaned. After this step, there is need to spread again the grease, using special foodsafe grease paste.
Disassemblying the gear box is not that easy, you will need previous experience and a gear puller to do the job properly and safely.
This appliances are also held with security screws to prevent the users from taking apart the unit, and can only be disassembled using a Security screwdriver tip.
The grease can be purchased here, check at the bottom of the page: Kenwood chef food mixer Grease.
Nov 18, 2008 | Kenmore KSM100 Stand Mixer
Hobart A200 oil leak
grease coming out the planitary on bottom normally means it needs taken apart completley cleaned out of old grease and new seal and newer stile spacer seal goes around with the O-ring on it. and factory grease. the noise impossble from here to tell.
Sep 10, 2008 | Hobart A200 Stand Mixer
Item: kenwood chef km201 Problem: Leaking grease from mixer shaft
How old is the machine?
The leaking comes from the lower gearbox assembly, ther are two kind of gearbox. There are two kind of vertical drive shaft, 14mm and 12,7mm that goes through the gearbox.
You can try to replace the grease, make sure that is vegetable grease.
May 02, 2008 | Kenwood KM300 Chef Stand Mixer
Mixer leaking oil
I called KitchenAid about this issue with my mixer. The agent on the phone told me they are aware that it tends to happen to some mixers after they sit for some time. Basically, a "lifetime" of grease has been packed into the assembly and it is normal for it to release grease on occasion. I was told to run the mixer at 10 for at least 2 minutes to get it going and I should see a reduction in the oil leak. I had about a tablespoon worth of oil dripping down off the assembly. I was told that if over time it seemed to amount to about 1/4 cup then I should call to see about repairs due to a potentially bad seal. I was also told that the repair for that would most likely NOT cost the same as a new appliance.
Nov 26, 2006 | KitchenAid KSM90 Ultra Power Series Stand...
Kenwood KM300 Chef Stand Mixer Logo
100 people viewed this question
Top Kenwood Food Mixers Experts
ashburton
jason
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
