Back to:
Tags:
Panasonic Panafax UF-790 Plain Paper Laser Fax
Fax received printed sideways, 50% size
posted by Quenby on Nov 20, 2006
This is in regard to a Panasonic UF-790 fax machine. Faxes received from one party sometimes come through reduced to 50%, sideways, on half a page. I read through the manual and this problem was not mentioned. I tried making changes to the size: changed from Auto to Fixed, 96%. This didn't help. Any suggestions would be appreciated.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Feb 16, 2008
Not Rated (0)
mrfixall
Rank:Wiz Wiz
Rating: 84%, 65 votes
If its not constant its probably on there end. Does it happen with any other party. Lawrence
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on fax received printed sideways, 50% size:
I don't want to Accept this solution
Can you Help with these Fax Machines problems?
Fax Machines
I cannot move my address over far enough to line up the...
Fax Machines
Casio fx-260 solar calculator: (1) How to put in COMP...
Fax Machines
Changed the ink cartridge in my faxJET 525, but the...
Fax Machines
We have a Canon Multipass C30 fax machine but do not have...
Panasonic Panafax UF-790 Plain Paper Laser...
Can anyone tell me how to program the machine to print a...
Loading problems.
Repair Service
Find Fax Machine Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
