Question about Apple iBook G4 (Z0AZW13397068) PC Notebook
Can't play dvds
Ibook g4 doesn't play dvds at all. reads the disc. but divx player and quicktime and itunes are unable to actually play the dvd.
  • Apple Expert
  • 560 Answers
First open the "Device Manager" to check for any error messages related to the device and click on "Start" and select "Control Panel" .
Now double-click on the "System" icon then click on the "Hardware" tab and click the "Device Manager" button. A new window appears, and displays whether the device is working properly. If there are any errors, click the "Troubleshoot" button and follow the given onscreen instructions.
Check the DVD that you are trying to use to and ensure that it is free of dirt and scratches and the proper format compatible with your drive.
Now uninstall any drivers that may be on your computer from previous DVD drives.
Now download the latest driver updates for your DVD drive model from Toshiba website & install it.
Also check on Toshiba website that your machine has the minimum requirements to operate the drive.
Now restart your computer & check your DVD drive.
I hope issue has been resolved.
If the same problem is still occurring, get the reliable technical assistance at http://www.vtechsquad.com/toshiba-support/ for troubleshoot all kind of Toshiba PCs(laptop and desktop) problems.
Posted on Sep 20, 2012
    Sergeant:
  • 237 Answers
What type of dvd are you trying to play? Is it an international dvd?
There are some dvds needing a different software to play. Let me know, and maybe i can help.
Posted on Nov 17, 2008
Getting a C 13 70 disc is dirty message only for DVDs that I'e burned recently. I bought a new pack of blank DVDs, the same kind I've always used, but every movie I burn on these new ones, they...
Hello, welcome to Fixya!
Was this player playing previously? And how long have you been using this player? I suspect the lens of the player. Once the lens of the player becomes weak, it won't play discs any longer.
The first thing my mind goes to, is the lens. The lens id responsible for reading/loading data on discs. So if the lens is unable to read the disc, there is no way the player is going to play the disc.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or probably, a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
Nov 03, 2011 | Sony DVP-SR200P DVD Player
Tip
How to convert Blu-ray and DVD movies to QuickTime Player compatible format on...
Apple has detailed it clearly on its official site that QuickTime will attempt to open files with file extensions associated with audio or video formats listed as below:
Video formats:
QuickTime Movie (.mov), MPEG-4 (.mp4, .m4v), MPEG-1, 3GPP, 3GPP2, AVI, DV
Audio formats:
iTunes Audio (.m4a, .m4b, .m4p), MP3, Core Audio (.caf), AIFF, AU, SD2, WAV, SND, AMR
More than that, QuickTime can play movies using the following codecs:
Video Codecs:
MPEG-4 (Part 2), H.264, H.263, H.261, Apple ProRes, Apple Pixlet, Animation, Cinepak, Component Video, DV, DVC Pro, Graphics, Motion JPEG, Photo JPEG, Sorenson Video 2, Sorenson Video 3
Audio Codecs:
AAC (MPEG-4 Audio), HE-AAC, Apple Lossless, MP3, AMR Narrowband, MS ADPCM, QDesign Music 2, Qualcomm PureVoice (QCELP), IMA 4:1, MACE 3:1, MACE 6:1, ALaw 2:1, ULaw 2:1, 24-Bit Integer, 32-Bit Integer, 32-Bit Floating Point, 64-Bit Floating Point
Obviously, Blu-ray (.m2ts) and DVD (.vob) are out of the above mentioned range. Even though you purchase QuickTime MPEG-2 Playback Component from online Apple Store and install it on your Mac, it is still unable to play commercial DVDs (such as Hollywood movies), because they are usually encrypted with special CSS anti-piracy technology, not to mention the much more strictly protected Blu-ray movies. However, that doesn’t means you are totally banned to watch Blu-ray and DVD movies in QuickTime. Actually, an available Blu-ray and DVD ripper for Mac will definitely do you a favor to remove copy protections, and rip the movies to a Mac QuickTime Player compatible format. Go to find a step-by-step tutorial about how to convert Blu-ray and DVD movies to Mac QuickTime Player supported format.
The decryption software we recommended is Pavtube Blu-Ray DVD Ripper for Mac. It is an independent and professional utility to rip both Blu-ray discs and general DVDs to your wanted HD or SD media formats. With full Blu-ray disc support, it is able to remove copyright protections of your BD disc, no matter BD+, or AACS, even the latest MKB V17 is supported as well. See the detailed tutorial as below.
Step 1: Free download, install and launch this blue ray ripper Mac.
Once you run it, click "BD/DVD Folder" or "IFO File" to load your BD or DVD files.
Step 2: Select H.264 Video (*.mp4) as output format for QuickTime
Follow "Common Video" > "H.264 Video (*.mp4)":
Step 3: Click "Settings" button to adjust video and audio parameters
Notice that which parameter to select has close relationship with the hardware configurations of your computer, so before your adjustment, read the following info attentively.
To play HD video, a large amount of data must be processed by your computer. A powerful system will deliver the best playback quality.
Recommended hardware configurations for H.264 HD playback on Macintosh:
For 1280x720 (720p) video at 24-30 frames per second:
[*]1.8 GHz PowerMac G5 or 1.83 GHz Intel Core Duo or faster Macintosh computer
[*]At least 256MB of RAM
[*]64 MB or greater video card
For 1920x1080 (1080p) video at 24 frames per second:
[*]Dual 2.0 GHz PowerMac G5 or 2.0 GHz Intel Core Duo or faster Macintosh computer
[*]At least 512MB of RAM
[*]128MB or greater video card
Now you are ready to set advanced settings according to the hardware configurations of your computer. Our computer satisfies the above mentioned "1280x720 (720p) video at 24-30 frames per second", so we changed the settings as below:
Step 4: Click "Convert" button to start Mac Blu-ray ripping.
Once the ripping task is completed, you can click "Open" button to get the output H.264 .mp4 videos for your QuickTime Player effortlessly. Have fun.
Learn more about how to use Mac Blu-ray ripper.
on May 02, 2010 | Audio Players & Recorders
Cannot play certain dvd discs the make is panasonic model num nv vp33
Panasonic NV-VP33 is a DVD/VCR combo unit. These are good, but limited in DVD media playback formats. It depends on the types of DVDs you are trying to play, and their region codes (if they apply).
This model will NOT play:
DVD-ROM / DVD audio / DVD+R (unfinalised) / DVD-RW / Blu-Ray (obviously).
This model WILL play:
DVD-R (finalised) / DVD-RAM (no finalising required) shop-bought DVD movies / CD-R (for JPEG/MP3/DivX) / DVD-R DL (finalised) / DVD+RW (titled or with a top menu to make them compatible with other players, but again, finalising not required).
You didn't specify which DVDs do not play in your unit.
I would be very concerned if your player didn't read ANY DVDs at all. I assume the image below is what the model looks like. I have never had any problems with mine.
Mar 11, 2011 | Televison & Video
I cant Play dvds on my ibook g4 notebook
Make sure you have the right software first VLC is good software and will play almost everything.
Does your version iBook even have a DVD optical drive?
Is the optical drive failing?
Feb 03, 2011 | Apple iBook G4 Mac Notebook
Can not download divx player on my mac ibook g4
What do you mean? go to
http://www.divx.com/en/downloads/postdownload/divx/mac
i got it just fine.
Nov 30, 2009 | Apple iBook G4 Mac Notebook
As far as I understand it the current version of divx player is for intel macs only you can pick up the divx player 6 for the mac at
http://www.freedownloadscenter.com/Best/divx-player-6.html
which should work on your G4 machine
Nov 30, 2009 | Computers & Internet
Can`t get it to play dvds from the computer which are AVI.
the AVI discs are DIVX I am assuming.. Does your player support DIVX media? I am not sure what your model is, but I am thinking that your player will not support DIVX. If this is the case, you might need to burn new DVDs in the traditional VOB format that it can see. Check your owners manual to see about DIVX support.
thanks!
Stan Skaggs
Oct 19, 2009 | Zenith XBV342 DVD Player/VCR
Does not play divx/mpeg4 files on dvd disk!!
The player plays strictly DIVX files, but not variants like XVID (which today is more common since divx became not free).
Divx is actually the same than XVID. After spending days converting my files from xvid to divx, realized that changing only the FOURCC code of the files works.
Look for a program named videoinspector. It allows to edit the fourcc for a video file. for all xvid and variants change the fourcc of the files to DIVX. The change takes a second instead hours of conversion, and movies in xvid that used not to play on this device, now will be played without problems.
Apr 08, 2009 | Philips DCP851 Portable DVD Player
DivX certified player cannot read DivX files on DVD+R
Is there a Divx logo on the player? Does this particular DVD player capable of reading DVD+R disks?
If you used the Divx converter program, there is a way to create a DVD in Divx format with menus. Did you use that particular program? If you didn't, you may have the DVD in a data format and the player can't read it that way.
Dec 10, 2008 | Sony DVP-NS67P DVD Player
Prblem with samsung dvd hr-737
Hi, I have the same problem. Have called Samsung, those **** don't know ****. The player also doesn't recognize DIVX. This is what you get when you buy Korean cheap ****. I've sent mine in the garbage. I was smiling as the garbage collectors came and took it to hell.
Mar 16, 2008 | Televison & Video
Computers & Internet Logo
308 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
