Question about Hotpoint WMA48 Front Load Washer
Hotpoint wma48 wahing machine will not pump out water
Could this be the filter needs cleaning, if so where is it?
  • j_leese Nov 15, 2008
    Thanks for your help. Fantastic. We have fixed it.
  • Anonymous Mar 13, 2014
    cleaning wahing machine filter
  • 135 Answers
It does have a filter but its in an awkward place. first remove the access panel at back of machine. To the right you will see the pump. Follow the pipe from pump to drum and you will notice that its much bigger where it meets the drum. remove pipe at this end and its there.best to take machine outside first.
Posted on Nov 14, 2008
Drainage pump help.
The plastic clips are a pain to remove but basically push a screwdriver into the clip to pull it apart, buy stainless steel hose clamps to replace them.
Mar 10, 2012 | Hotpoint WMA48 Front Load Washer
Where is the filter on the machine
Unplug the washing machine and turn off the water.
Open the small trap door next to the drain hose connection on the back of the washer to gain access to the filter.
Take care.
Jan 11, 2011 | Hotpoint WMA48 Front Load Washer
Wahing machine washes but will not spin Hotpoint auquarius extra wm836 cant find filter
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Feb 17, 2010 | Hotpoint Aquarius WMA56 Front Load Washer
I have a Hotpoint wma48 and it will not drain the water. It is full of water and none of the programmes will now work, any ideas what might be the cause?
Probably a blocked filter.
Remove the lower rear panel of washer.
Remove the large black hose fastened to bottom of drum.
Remove and clean the plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here.
This should solve the problem.
Dec 14, 2009 | Hotpoint WMA48 Front Load Washer
Does the hotpoint wma48 need a hot water supply connected?
This is true. Just check if the machine has one or two water connections. If it has two you need a hot connection also
Mar 01, 2009 | Hotpoint WMA48 Front Load Washer
Manual WMA48
To get the information you require you need to type in your browser bar the following. hotpoint user manuals
In the list on the left click on manuals-user guides-handbooks-hotpoint service
Then in the search box type in your model number of washer, and download instructions, as req'd.
PleaseThankyou. rate my solution to your query.
Jan 27, 2009 | Hotpoint WMA48 Front Load Washer
Wont drain water
inside hose at back ,take back lower panel off black hose filter inside.
Dec 19, 2008 | Hotpoint WMA48 Front Load Washer
Hi there please my problem
Make sure the rinse hold button has not been selected, deselect if it is, possible pump blockage
There is a filter located in the sump hose at the rear of the m/c.
Remove lower rear panel and undo large hose onto drum , filter inside there, remove and clean if neccessary.
Make sure nothing is stuck inside pump, try a drain only prog and you should be able tohear and see if oump is working BE CAREFUL.
Dec 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius Extra WMA48
firstly you will need to take out the soap drawer and thoroughly clean it and the spray holes that are above the soap drawer. secondly i would reduce the cold water pressure to a fast trickle/jet that way it will not be spraying all over the place. the filter sounds as though it will need cleaning out. unplug machine, from the rear is a metal plate, remove it to gain access to the bottom hose-this incorperates the filter. undo secure jubilee clip and lower hose. remove debris and check the hose and pump for further obstructions. you should be ok after that. try to beat out the dog blankets outside b4 washing to remove as many hairs as poss. tone.
Jun 11, 2007 | Hotpoint WMA48 Front Load Washer
Hotpoint WMA48 Front Load Washer Logo
339 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
