I have a Logik L19LID628 and the built-in dvd player was working fine until yesterday when halfway through a dvd it froze. Now when i put in a dvd it makes a screeching sound and ejects the dvd....help please?
  • Mitzigollop Apr 24, 2009
    i have the exact same prob. mines only 4 months old.
sandrew
  • 2961 Answers
SOURCE: Insignia DVD/Cassette combo player
I imagine you have checked the disk for scratches top and bottom, if so you can purchase a cd/dvd lens cleaner cdrom as the laser may need realigning and cleaning.
Posted on Sep 06, 2007
SOURCE: dvd wont eject
hi jodestar,
i am having the same problem with my player. how did you end up fixing yours?
Posted on Dec 03, 2007
Slinteriors
  • 8617 Answers
SOURCE: dvds wont play
sounds like the optical pickup is faulty in your DVD player, have you tried the DVD in another unit?
Posted on Jan 17, 2008
IrishDruid
  • 2712 Answers
SOURCE: Have a 37 inch flat
1. Try this - hold the menu button down for 10 seconds. TV should power up; you will have to turn off front panel buttons on menu.
2. You can also try plugging in the TV through the USB on its panel to a computer or USB charger, and it may work. However, this is only a temporary solution.
3. Powering down the set or putting it in standby may have allowed the power supply to cool. Weak capacitors often go out of spec when they cool, thus preventing a section of the power supply from firing up properly again. There is a simple trick...just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use the hairdryer, but don't hold the dryer too close (say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Resetting the TV after it fails to turn on is the key. Also, just leave the TV on. Don't turn in off. Since it is LCD, it doesn't take much power...only a few bucks extra a month for your utility bill.
4. A circuit board may crack about some of the larger components mounted on it. You can inspect the PCB's for fractures, and then repair them. It may also be poor soldering that has failed. I would be checking for these things first.
5. If you want to go in for a long term solution, you can easily replace the whole power board or just change the faulty capacitors. You will have to open the back panel and take a look. You can make out which are faulty, because their caps will be swollen on top. Here's a sample pic (not same model):
Check the specifications of the faulty capacitors, and get the replacements from your local electronics shop. If you are comfortable with this, you can use a pair of needle nose pliers to G-E-N-T-L-Y pull out the defunct capacitors. Once that is done, solder in the new capacitors carefully. If are unsure how to do this, try to get a friend who knows how to do this kinda stuff do it for you, or get a qualified technician. Warning: If you do not have a background in electronics repair, or are inexperienced, get a qualified technician to do it for you.
REMEMBER there are very dangerous voltages inside a TV that can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECT THE POWER BEFORE YOU DO ANYTHING.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 07, 2008
SOURCE: dvd player will not play
Well, I will look into more about this. But, from my experience, any TV that has a build in DVD, VHS, it going to be a problem either now or sometime in the near future. They share the same motherboard inside the TV; when one thing goes wrong on the board it effects everything else as well. Let me ask you this, Is the TV working ok? If it is then the problem could just be in the laser eye within the DVD player itself. If this is the problem, then you can usually just replace the parts within the DVD player, and they might solve your problem.
Posted on Jul 21, 2008
My Funai WV805 DVD player quit playing DVDs
Hello
If the DVD do not spins inside the playere, this type of fault can occur. Open the top cover of the player and insert a dvd. See whether it spins inside or not. If not, replace the motor that spins the disc inside. This motor is known as Sled motor.
If disc spins inide and the player do not read or play it, replace the Laser Pickup Unit. It is faulty.
Mar 01, 2012 | Televison & Video
Soniq tv with built in dvd player says no signal on dvd mode
DVD unit has gone to dvd heaven. Not cost effective to repair. See if you have inputs so you can use an external player.
Feb 20, 2012 | Televison & Video
Up until yesterday our dvd player was fine, today I put in a dvd and there is no sound. I have put a couple of dvds in and there is no sound except for one dvd I put in this works fine?
the dvds you put in are not compatible to your dvd player.but you can clean the lens and see what it does.good luck.dvds work with region.check the region of your dvd player and dvd you are attempting to play.
Mar 04, 2011 | Televison & Video
TruTech tv with built in DVD player not playing DVD's
the possible of dvd, its lince, its possible damage, specialy when use dvd has scrahts. try to clean useing cotton bads only, clean smothly, then try to use,
Apr 17, 2010 | TruTech PLV16190 Television
Tv manual
Most likely this is a generic TV made either for the company you bought it from or a Manufacturer having it made for them. You can usually compare the TV to other brands and find one that is identical just made by someone else
Aug 31, 2009 | Televison & Video
DVD+R stuck in logik ldvr808 recorder
Pull out the power cable and leave for a few minutes then plug it back in. Now before the DVD player tries to play the disk press EJECT or OPEN/CLOSE button continously until it releases the disk.
Jul 10, 2009 | Televison & Video
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Electro Med Services...
