Question about Epson Stylus C86 InkJet Printer
Epson Service warning
Hi, I have an epson C86. I have the message that i need to get printer serviced. This is due to the ink head cleaning counter.I have cleaned up the pads etc. I now need to know the sequence of button pressing required to get my printer to come back on. I have 2 red lights flashing alternately at the moment.Please can you help. Thanks.
  • Anonymous Jul 17, 2008
    I have a C84 and the ink and paper lights are flashing alternately. I have downloaded the ssc utility but don't know what to do next. What should I run to try to fix the problem.
  • Anonymous Mar 18, 2014
    Complete message reads...This is validation sensorself-cleaning start message. Wait for a while. Then Cleaning failed. Please call a service person.
    Problem Solver:
  • 5 Answers
Hi, try downloading the ssc utility (just google it). it lets you reset the ink counters, individual ink cleaning etc. once you've opened the main screen you need to right click to get all the other bits. hope this helps
Posted on Nov 30, 2006
SOURCE:
Epson C86 Message says "service
This is a common error with ALL Epson printers and you can find out more about what it means, what you can do about it and even instructions for fitting a waste ink kit for your printer via here:
http://www.octoink.co.uk/waste
In terms of resetting the waste ink counter, the SSC utility should work but you may need the AdjProg (Adjustment Program) instead depending on whether the printer firmware is willing to talk to SSC or not.
Hope that helps.
Martin
Nov 24, 2010 | Epson Office Equipment & Supplies
Epson Stylus C86 printing blank pages.
Ensure the proper procedures for installing an ink cartridge was done. Next, perform at least two cleaning cycles (hold down the ALT and the Pause button on the printer panel to initiate a cleaning cycle). Print out the demonstration page (press the ALT button while applying Power). If the problem persists and there is no improvement, take the printer to an Epson Authorized Service Center.
Oct 28, 2010 | Epson Stylus C86 InkJet Printer
I think my printer head have dry ink in the pins. Can I do this repair? I have an epson Stylus C86.
your best option is to apply damp to the printer head, simply feed a wet wipe/ baby wipe under the printer carrige, when it is off of course, and leave it overnight this should leech out anything in the nozzels and get ink flowing again. it is simply a matter of time and effort and most service centres wont have either.....
Nov 14, 2009 | Epson Stylus C86 InkJet Printer
Using Epson c86 printer. black Ink dots appear
It may be caused by waste ink at bottom plate of head. Print blank pages about 10.
Nov 12, 2009 | Epson Stylus C86 InkJet Printer
Epson C86 print head/cartridge head won't move.
Hi Beverley
There is some confusion here. You say "ink sponge needs replacing" in an Epson C86 (although you have your query posted under HP Officejet 5610!) - I presume you mean the waste ink pads. If so, you need to dismantle the printer - the pads are not under the print head but deep inside the case. I can provide all the information you need to complete this task if you really want to do it yourself. Please post a new comment requesting this assistance if you do.
Apr 23, 2009 | HP Officejet 5610 All-In-One InkJet...
Epson C86 sat idle 6 weeks. Now will not print.
I assume that you aren't getting any error messages or flashing lights and that the paper is going through but coming out clean. If so try doing 4 to 5 head cleans, wait about 10 hours for the ink to soften and do another 3 or 4 cleans with a nozzle check after each. You should see a gradual improvement in the nozzle checks. If there is no improvement then you need a head cleaning solution such as this one:
http://www.powerklin.co.uk/?gclid=CNGDypir-JgCFQ4yQgodZlC4lw
Others are available just try googling "inkjet head cleaning".
Hope this helps.
Please take a moment to rate this solution, thanks.
Mar 26, 2009 | Epson Stylus C86 InkJet Printer
Service required error
Try unplugging it for an hour first.
Thanks,
Lee
Jun 18, 2008 | Epson Stylus Pro 4800 Color Photo Printer...
Epson printing not printing
If you have already tried 3 consecutive head cleanings and nozzle check from the computer, tried reseating the inks and tried replacing the ink and it still acts like its printing but just provides a blank page chance are your printer already has hardware issue. The ink delivery system is already clogged. If your printer is still within the 1-year warranty period I suggest that you call Epson Tech support for more options otherwise, you would need to get the product repaired by an Epson certified service center. To locate a servicer in your area click on the link http://www.epson.com/cgi-bin/Store/support/SuppProductSearch.jsp?BV_UseBVCookie=yes
Jun 03, 2008 | Epson Stylus C86 InkJet Printer
Epson stylus C86 printer
If you have already have done 3 consecutive head cleaning and nozzle check from the computer, reseated the ink and replaced the inks, you printer already has a hardware issue. The ink delivery system is clogged and needs to be serviced. If your printer is within the 1-year period I would recommend that you contact Epson Tech support for other options otherwise, you would need to get printer repaired by an Epson certified service center. To locate a servicer in you area click on the link http://www.epson.com/cgi-bin/Store/support/SuppProductSearch.jsp?BV_UseBVCookie=yes
Apr 02, 2008 | Epson Stylus C86 InkJet Printer
Epson Stylus C86 InkJet Printer Logo
350 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
