Question about Whirlpool LCE4332P 2.1 cu. ft. Top Loading Washer
Portable washer noisy and leaves tiny brown puddles
A little while ago my portable toploading whirlpool washer became SO noisy only during the spin cyle. And then it started leaving dark brown splashes underneath it. Kind of the colour of soy sauce. They dry quickly, and I don't think it's a leak but something is clearly broken. It runs fine, but I don't want to use it until it breaks completely. What could it be? It's not an unbalanced load because it always does it, even if I run it empty (which I did once by accident, don't drink and launder) : ) Thanks
    President:
  • 878 Answers
Littlesnook, from what you're describing it sounds like the gearcase is starting to go bad. I have changed out a number of these and it is no fun. You do have a 5 year warranty on the gearcase and related parts. Labor would probably run around 130.00 bucks. Check your purchase date and the best thing to do would be to call for service. Changing out this gearcase on this model is quite a job....Catriver..post back.
Posted on Nov 22, 2006
Cabrio washer wtw5500xw0 loud spin and grease on floor
FIXED Cabrio has loud noise during spin - ApplianceBlog
www.applianceblog.com/.../16339-Cabrio-has-loud-noise-during-spin
Aug 21, 2009 - 10 posts - ‎5 authors
Help Jake I have a Whirlpool Cabrio model WTW6600SW2 it is almost 2 ... a week just started making a very loud noise only during spin sounds like ... size washer (110.297) (loud whirring and grease splatter) and am trying to ...
How to tell if your bearings are bad on a Whirlpool Cabrio ...
? 1:01
https://www.youtube.com/watch?v=5rHn13lKjzc
Jan 19, 2012 - Uploaded by RenewAppliance
http://washerdryerrepairhelp.com/whirlpool-cabrio-maytag-bravo-and-kenmore-oasis- ... My floor under the washer machine hasgrease/oil marks. ... and make the suspension bad when it spinsmine has been like this for about 2 months now ... Noisy WhirlpoolCabrio washer during spin - Duration: 0:54.
Jan 16, 2016 | Washing Machines
Noisy during agitate cycle whirlpool washer
Originally posted as solution to Kenmore 24992300 failure to agitate and loud whirring noise during spin cycle.... Hope this helps:
The problem as I noticed it was that the washer would start making a super high-pitched and very loud whirring noise during the spin cycle, and that when I would open the lid, the drum would not be spinning, but when I would close the lid, the drum would start spinning. I was okay with this during that load but after reading here and taking it apart, I realized what had happened:
The agitator dogs are supposed to have a 3-toothed profile on each one, but they become worn over time due to being made of a soft plastic. The dogs should "throw out" into an inner ring gear during normal operation, turning the entire drum. But when they became worn enough to slip, they would still throw out, grinding them at very high speed into the inner ring gear. Since they are made of a softer plastic than the gear, they were just getting more and more worn.
I assume the way this was supposed to fix itself was that when the outer tooth on the dog became worn, the next one would engage, but that didn't happen.
Because the dogs are made of such a soft plastic, I was able to cut a new tooth profile into each one, so that when they were put back in they would function correctly. It takes very little effort and a few minutes with an x-acto knife to cut the right profile.
I'm going to buy the replacement dogs, which being a manufacturer substitute will hopefully be made with a better tooth profile, from harder plastic, or both.
As another note, who knows how long the dogs weren't engaged correctly during agitation, causing clothes to sit without really being washed, but without the high pitched air raid siren. So probably a good idea to replace or repair them immediately, even if you can get it to work intermittently.
Sep 12, 2013 | Sears Parts Direct Whirlpool 4313896...
OK during wash and rinse cycle but suddenly became very noisy during high speed spin cycle
If noise occurs only during spinning cycle, then the 2 bearings and seal need to be replaced.
May 23, 2010 | Maytag Neptune Washer
Kenmore Calypso Washer is leaving dark brown stains on clothes
hi is the machine noisy on spin cycle if so ur bearings have gone
May 11, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer whining when washing and spinning leaving brown stains on clothes
Turn water off. Remove hoses and clean the rust out of the strainers at hose end. If they are clogged they will sound funny when water goes through them.
May 04, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
NAV6800AWW - noisy
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 04, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Lsb6300pw whirlpool topload
does it wash have you tried on wash since youve had the spin promblem
Jan 13, 2008 | Whirlpool LSB6300PW Top Load Washer
Cabrio he toploader leaking on towel/sheet cycle only
It is possible that the dispenser is leaking. It is typically the left front dispenser, you may notice a puddle on the left side. ???
Jan 09, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool LCE4332P 2.1 cu. ft. Top Loading Washer Logo
93 people viewed this question
Sal De
Marvin
Marvin
jimorris77
