Question about Amana ABB1927DE Bottom Freezer Refrigerator
Bottom freezer door handle loose
The door handle on the bottom freezer is loose. I do not see any provisions for tightening from the outside. Can you help me as to how to tighten the handle?
  • 1 more comment
  • mortgmike Nov 24, 2008
    My 2 year old Amana refrigerator/Freezer (Freezer on bottom) stopped making anythiung cold . Any suggestions besides cleaning the coils and rear vent which I have already done. Their is no frost on the back wall. Im also sick of re-mounting the freezer door handle. Whoever engineered that was an idiot. I cant wait to get my consumer reports product questionaire this year
  • snappy33169 Dec 09, 2008
    i can't open my bottom drawer freezer with the handle. It comes off in my hand!!!! This is nuts on a 2yr old product!
  • h2oworks Jan 19, 2009
    Bottom freezer door is very loose, I'm sorta hoping it will come off so I can figure out what holds it on.
There is a plastic card that you are supposed to slide under the right side of the handle. Once you have done this correctly the whole handle should slide off to the left.
Posted on Jan 19, 2009
How to tighten loose set screws on freezer door handle on ken more fridge with bottom mount freezer, model no. 269-76353019
I think that the handle is attached either to the door edge or the face. In either case the screws are usually hidden behind a small trim panel. This needs to be removed to expose the screws. I don't know what type of screws have been used. They're usually cross heads but occasionally they require an allen key to remove them.
Jul 19, 2015 | Kenmore Refrigerators
The bottom freezer handle on my gb2fhdxwq07 is loose...how do I tighten it?
check your handle does not have a cover that you lift off. to get to your screws.
Mar 03, 2015 | Refrigerators
GE GFSL6KEXLS Stainless Steel (2585 cu ft) Bottom Freezer French Door Refrigerator Problem: Freezer handle is all stainless steel is loose. How can I tighten it? I looks like I would have to go through...
look for a small hole on one side of the handle. There should be a set screw there you can tighten. (the handle attaches to a ball shaped peg under the handle, and does not attach from the inside of the door)
Nov 28, 2010 | GE GFSL6KEXLS Stainless Steel (2585 cu ft)...
Door handle are loose
get a 2.5 allen wrench and tighten the bottom side of the handle
Nov 15, 2009 | Fisher and Paykel RF201ADUX Bottom Freezer...
Loose freezer door handle
There is a "set screw" on the underside of the posts that connect the handle to the mounting posts on the face of the door of my Jenn-Air bottom freezer. Use an Allen wrench to loosen the set crew, which is very small (my Jenn-Air requires a 3/32" Allen wrench), and then tighten the bolt on the mounting post on the face of the freezer door. Position the handle over the post, then tighten the set screws with the Allen wrench. Cynthia
Jul 21, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Handle on bottom freezer drawer is loose.
Take the handle and slide to the left as far as it could go to tighten handle. This worked for me.
Jun 26, 2009 | Maytag MFI2568AE Side by Side French Door...
Freezer door handle loose
u could always set the handle in place where it needs to be and use caulk or super glue to go around the handle and that should help it stay in place if that doesnt work the website www.amana.com to see if it has warranty for the broken handle good luck
May 26, 2009 | Amana ABD2233DES Bottom Freezer...
Loose handle on door
The door handles mount on hex bolts sticking out of the door, the door handles have key hole inserts that match with the bolts. The door handles are then slid in one direction to lock the handles in place. Removal is the reverse. To tighten the door handle screw the bolt out enough that you can still put the handle over the bolt heads and slide the handle to lock the handle in place.
Apr 12, 2009 | GE Profile Stainless Bottom-Freezer...
Bottom Freezer door handle
I had the same problem. It took me an hour to figure out that the bottom freezer handles clips onto the door using butterfly clips. To tighten the clips you have to remove the handle by sliding it to the right (or left??) It snaps right out with a quick **** exposing the clips underneath. A quick tightening of the clips and the handle snaps back in.
Nov 07, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
1,153 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
