Question about Texas Instruments TI-83 Plus Calculator
Window Range When I am using the calculator and I hit either trace or graph, it immediately says ERR: WINDOW RANGE. I can't fix it. Any ideas?
  • 7170 Nov 17, 2008
    whenever i try to graph y=-1.5x^2 err:window range comes up. What should i do?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
A problem exists with the window variables, for example Xmax < Xmin or Ymax < Ymin.
Press WINDOW to bring up the window editor and examine the values for any inconsistencies.
Posted on Feb 18, 2010
Every time i press graph on my ti 83 plus it says ERR:Window Range 1:Range how do i solve this problem so i can graph
You will have to hit the window button on the face of the calculator that is just below the screen and change the values making sure the max value is larger than the min value.
May 02, 2011 | Texas Instruments TI-83 Plus Calculator
Grr, wenever i try to graph it says ERR: Window Range
This is because you have your windows set to amount that are invalid. Hit the windows range button (2nd f3 I believe) and set xmin to -10, xmax to 10, step/interval = 1, Ymin to -10, Ymax to 10, step/interval = 1.
Mar 17, 2011 | Texas Instruments TI-83 Plus Calculator
For my ti-84 I try to graph & it says ERR:window range...but when i try to fix the range it won't allow it...is there a good widow range to have for all graphing purposes?
There is no one good window range for all graphs, since graphs can have different areas of interest.
Press the ZOOM key, then select ZStandard. This will restore the window settings to the default range, which will at least allow the graph to be displayed. You can then change the window range and/or zoom as desired.
If this doesn't do it, please reply to this post, giving the function(s) you're trying to graph and your current window settings.
Feb 15, 2011 | Texas Instruments TI-84 Plus Calculator
Calculator all of a sudden stop graphing. When i hit graph it says err:window range
Press the WINDOW button (2nd from the left, very top row) and check the window limits. In particular, make sure that Xmin and Ymin are less than Xmax and Ymax respectively.
If that's not the problem, append a comment to this post listing the window variables and the function you're trying to plot.
Jun 24, 2010 | Texas Instruments TI-84 Plus Calculator
ERR: WINDOW RANGE 1: QUIT
There's something wrong with your window limits, for example Xmax < Xmin or Ymax < Ymin. Press WINDOW to bring up the window editor and examine the values, making sure there are no inconsistencies.
If you don't see anything wrong, post a comment here listing all of the entries in the window editor.
Feb 19, 2010 | Texas Instruments TI-83 Plus Calculator
My calculator doesn't graph anything just says err:window range and 1:quit and the graph is weard!!help meeee please !!!!!
Try using the standard Zoom.
If you are drawing Y=f(X) functions, press [ZOOM][6:ZStandard]. The window dimensions will be [-10, 10] for X and the same for Y.
If you are drawing polar graphs, in addition to the X,Y windows dimensions, you have Theta min =0 and Theta max =2*Pi =(6.28)
Feb 08, 2010 | Texas Instruments TI-84 Plus Silver...
ERR: Window Range
Press ZOOM and select Zoom standard (ZoomStd).
Alternatively, press the WINDOW key to access the window range setup
Set Xmin=-10
Xmax=10
Ymin=-10
Ymax=10
These are the standard dimensions of the window.
You can change the dimensions as long as Xmin is less then Xmax, and Ymin is less than Ymax. Do not make Xres close to Xmax-Xmin.
Jan 10, 2010 | Texas Instruments TI-83 Plus Calculator
Graph not working
The window ranges you chose may be wrong. Use ZoomStd ( Zooom standard) or use values that satisfy inequalities Xmin less than Xmax and Ymin less than Ymax. make sure the ranges Xmin, Xmax and Ymin, Ymax cover the area of the graph you are interested in.
Hope it helps.
Dec 07, 2008 | Texas Instruments TI-86 Calculator
Graph feature not working on my TI-83 Plus
Simple:
Hit this sequence:
"ZOOM" "0"
That is for the "Zoom Fit" option. The calculator does not like the window you have for the equation you've given it. With this option, it will automatically give you the best fit in the window for the equation!
Nov 14, 2008 | Texas Instruments TI-83 Plus Calculator
TI 83 Plus
Try hitting "ZOOM" then "0". This is for the "Zoom Fit" option. It will automatically adjust your window range to best fit your equation!
Sep 27, 2008 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
242 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
