Question about Brother Office Equipment & Supplies
I have a brother printer mfc 7420. It wont print; it says that the back cover is open. There is only one big door in the back which I used to get a piece of paper that was stuck. It is now firmly closed. Can you please help me?! Thank you. Ben Aguirre aguirre@udel.edu or 302 731 8289
  • 3 more comments
  • Benigno Nov 14, 2008
    the advice I received did not solve the problem.
    I am still faced with the same problem. I could not find the sensor inside the back door. I also used an air blast duster in this area, shaked it real well, but nothing happened
    I could not find any piece of the sensor anywhere inside the machine
    there is no paper jam, I removed the tray and also looked from the back
    I am trying to remove the cartrige and I am having a hard time. I do not see it in the back.
  • 73 Answers
Hi there
This is case where the message is used for several situations, include a paper jam. Try this
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000600/000096/faq000696_001.html?reg=us&c=ca&lang=en&prod=mfc7420_all&Cat=4
I hope this helps. If so, please take a moment to accept and rate my solution accordingly
Posted on Nov 14, 2008
  • 1 more comment
  • pmgca Nov 14, 2008
    Note, in the case of the tutorial below, the paper jam is internal
    Sorry, I meant the tutorial above
    To locate the elements, follow the images in the tutorial
    Genius:
  • 1,913 Answers
Remove cartidgw thwncheck there is noyt any paper jam.
also refix cartidge again.
then try/.
  • kishor khatri
    kishor khatri Nov 15, 2008
    check in the back side of your printer to .
    therre must be paper jam.
  • kishor khatri
  • 1,879 Answers
Sensor fails to detect the closed door. Either open the back of teh printer and look for the sensor or try giving it a nice slap on each side first.
    Scholar:
  • 181 Answers
Remove all the connections of the device.ust totally off the printer.and tap slowly on all the sides of the printer.it has a sensor that detects the door that sensor is slightly moved from inside and need to be adjusted properly..then just connect the printer and check the error should go.
  • fixyy Nov 14, 2008
    also if u have a air blower machine blow in the device from all the sides if any thing getting that sensor blocked it will be blown and that sensor can come to its position easily and starts working.
    if that sensor is broken due to any reason it will not detect as there is no sensor.it is very delicate and very thin.shake the device up side down and check if any broken piece falls down.and it could be also possible that it is blocked very firmly so not been able to come at its position.
    then servicing your printer is the option remaining as in servicing all the parts of the printer will be opened and cleaned.so it will clear every thing.
My brother mfc 7420 says that the back cover is open
When this happens it is just telling you to go through the steps of opening and closing the back cover. The back cover may not be completely closed.
Oct 18, 2012 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 printer says back cover open...close back cover, but nothing is open
hello there
try this remove the toner of the printer and put it back again and closed properly make sure door close and turn off the printer remove the power plug from the outlet and ppower cord from the printer and wait for some time and turn it back on.
thank
Mar 09, 2011 | Brother MFC 7420 All-In-One Laser Printer
I'm printing and stoped and it says back cover open and I don't see anithing open?
sounds like the back cover is lossing to open, try to use some tape to seal it and try, if still not working, please let me know.
Feb 15, 2011 | Brother MFC 7420 All-In-One Laser Printer
Paper jam rear, open back cover. Paper jam has been removed but message is still there and not allowing printing
Hi Good day!!! Turn off your brother and check the back cover be sure to close it. after that turn back on your brother.
Thanks for using FixYa
Don't forget to vote thanks
Nov 04, 2010 | Brother MFC 7420 All-In-One Laser Printer
Back cover open, wont print, scan or copy.
All covers must be closed before the unit will operate. Double check that the back door is closed completely and latched on both sides.
Jan 07, 2010 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 keeps saying - back cover open - close thre back cover? How do I reset the printer orf find the underlying fault?
First be sure you close the back cover and remove all the jammed paper. after that, turn off your printer for 1 min to see is it okie.
Jun 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
Message on brother MFC7420 "back door open" when it's not
Actually, you need to double check the back cover and front cover, open them all to check all paper jam.
Besure to check the back cover, normally all paper jam is from the back.
be sure to close the front cover at the last cover to close.
Apr 01, 2009 | Brother MFC 7420 All-In-One Laser Printer
Toner replacement on Brothers MFC 7420
Open the front cover and try to pull it out strongly.
then use the duster to clean the machine.
then you should able to replace your cartridge easily next time.
mightbe too dirty or you use ODM toner? if yes that's the problem issued from.
Nov 18, 2008 | Brother MFC-7420 Laser Printer
Printer won't work
What it really means is that another piece of paper is still stuck in the printer, closer to the back. Pull out the paper tray and open the back to look again.
Sep 17, 2008 | Brother MFC 7420 All-In-One Laser Printer
47 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
