Question about Whirlpool Duet GHW9150P Front Load Washer
My washing machine stop in the middle of washing
H and F keep on flashing
  • 5,911 Answers
The following link explains the "FH" error and how to diagnose and repair:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
There's a lot of information on this error code, so read through the link carefully. This can be a tricky problem to diagnose as there can be multiple causes to the error code. So, check all possiblities.
However, before you go through all of this, unplug the washer for AT LEAST 30 minutes to reset the Central Control Unit (CCU). This is the main computer for the washer. In many cases, resetting the CCU is all that is required to correct momentary glitches. If the error code reappears, then you know you have a problem somewhere.
I hope you find this information helpful. Let me kow if you need further assistance.
Posted on Nov 14, 2008
  • 367 Answers
This means that the washer is not detecting water passing through the valves. Or if the valves stay open on the washer for 8 minutes it says the same thing.
Check to make sure that no hoses are kinked. also check to make sure that your drain pump is working also. The next thing to check is your pressure switch and hose. If all of that is good then you most likely have a bad CCU.
Machine stopped in middle of cycle ,wash flashing something on screen, tried to restart wont't run water could it be out of level for it not to run water
It's probably flashing an error code. Write down the code and look it up in the owners manual or online to find out what the issue is.
Aug 17, 2014 | Samsung WF328AA Front Load Washer
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
My whirpool locked light keeps flashing and wont wash
Hi
The light is flashing due to the door lock error. The door lock is activated as the machine experienced an error or was stopped in middle of a cycle. Or the door was being pulled while the machine was running a cycle. Try unplugging your washer and restart the washer to check if you are still getting the same blinking light. If error is still not resolved then start the rinse/spin cycle & stop the cycle, now press and hold the cancel button for 5-10 seconds. However, if you are still not able to get the door open then you'll need to open the door manually by disassembling the washer.
Hope this helps... Please post back for any further assistance.
Daniel
Apr 18, 2011 | Washing Machines
Amana nfw7200 washer stopped in middle of cycle and is flashing ''nd''
is it full of water? if so there is a drain problem and may have to clean out the pump
Aug 23, 2009 | Maytag NFW7200TW Front Load Washer
Stops in middle of wash cycle and F51 codes keeps flashing
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the Bad Board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
Mar 20, 2009 | Kenmore Elite 45986 Front Load Washer
LG Washer / WM2487H*MA...2 days old. Wash setting...."Bulky/Large QUESTION:::When attempting to select additional "wash options" from the Option Buttons panel, I keep getting a display...
My LG Tromm washing machine just stopped in the middle of the cycle, It started flashing the letters LE, what does that mean. I have had it for 4 years and this has never happened.
Jul 27, 2008 | Washing Machines
WF320P Water fills on wash cycle drum starts to rotate. After 30 seconds or so middle three red error lights flash and cycle stops.
Hi there swamib lets see if we can help you out. If the lights in the middle of the appliance flash led 1,2,3 that means there is a problem with the heater it is most likely it is open circuit replace this and it should solve the problem keep in touch noffie......
Apr 08, 2008 | Washing Machines
Washing machine stops in middle of cycle
This problem used to happen to me with an older washer. It also had a buzzer as well as a flashing light.
I discovered it was the "off-balance" warning.
Next time, try shifting the clothes around so that all the weight isn't on one side of the washer drum
Feb 06, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
78 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
