Question about Dryers
Dryer keeps tripping circuit breaker
My indesit condensing tumble dryer keeps tripping the circuit breaker out every time i try to use it do you have ant ideas
  • fwulf1 Nov 26, 2008
    My dryer keeps breaking the circuit, but it is only breaking it half way. At some points the dryer is working but the heat is not and other times when it trips the dyer stops all together, is it the dryer or is it the breaker???
Jimster
  • 240 Answers
SOURCE: whirlpool electric dryer keeps tripping main circuit breaker
First off, be sure the pigtail is wired correctly to the back of the unit. Black and red to the outside terminals, white to the middle, green to the frame or cabinet (should be a green screw close-by). If that is ok, you probably have an issue with possibly a bad pigtail, bad outlet, wiring issue, or possibly a bad circuit breaker or breaker box. Probably going to be more of a electrical problem than a appliance problem. Good Luck!!!!
Posted on Feb 02, 2008
aborcass
  • 2651 Answers
SOURCE: my whirlpool tumble dryer keeps
if it trips it off immediately after starting or wont even let you reset the breaker, you have a direct short(wire off a terminal ) or your heater element has broken and is hitting against side wall
Posted on Mar 24, 2008
thedayos
  • 57 Answers
SOURCE: My new maytag centennial electric keeps tripping
Hi Matt
I'm not sure that swapping out the breakers to higher rated ones will give you a solution so I'll throw in 2 cents to see if my advice holds true. Let's start by asking this. Is the appliance "rated" at 220 volts at 30 amps per leg. I assume this from your post as to what it has been rated. Next - How long is the "run" of wire from the junction box to the outlet where the appliance plugs in? This usually does not matter in most households but if the run is of significant length it may need a larger gage wire to support the current draw of the appliance. Lastly, and perhaps most importantly, are the lugs and wire connectors tight at the outlet, the plug, and the breaker box. A loose connection will ramp up the current fast. This is assuming the first two items were met. Tell me if any of this helps and we'll work it out from there.
Thanks.
Len
Posted on Feb 28, 2009
  • 3 Answers
SOURCE: Tumble dryer trips electricity
I own the same machine and this happened to me, if the internal working of the machine get wet it will cut off causing the electrics to trip. This model is a condenser dryer, at the bottom of the machine if you open up the flap you will see the condenser on the left hand side, the manufacturer recommends that you clean this unit once every month and also empty the reservoir and clean the fluff filter after every use. While this may seem like a lot of hard work there is a very good reason for this. I suspect that your problem is due to a build up of fluff and or gunge in the condenser and bottom of the machine. Remove the condenser and give it a good clean of all fluff, you can run water through it either in the sink or bath as the best way to do this it is very fiddley using just your hands. Next check to see if there is a build up of water in the back the machine where the condenser usually sits, you will have to lie on your stomach and reach into the back of the machine (OBVIOUSLY ENSURE THAT YOU HAVE UNPLUGGED FROM THE MAINS SUPPLY BEFORE YOU DO THIS!) along the floor of the machine you will feel a channel cut into the plastic which runs into the sump at the back of the machine, if you have not cleaned the machine properly this is probably blocked and is the culprit. With this blocked the water is unable to travel to the pump that takes the water from the condenser into the resevoir at the top of the machine, and therefore it stays in the machine and can get thrown about onto the electrics and could cause the machine to cut out and trip your electrics! If this is not blocked check the black rubber pipe leading from the pump to the reservoir is not blocked, failing that perhaps the pump (in the plastic case at the back of the machine) is faulty and will need to be replaced. If water has built up in the machine you will also need to check to make sure none is sitting in the heater coil compartment (it did with mine) to get at this you will have to unscrew the metal plate at the back of the machine and let any water out. Leave the machine for a few hours to make sure it is dry and then give it another go. If your machine is still under warranty though i would call indesit first as they may get a little funny if you remove any of the machine covers yourself and refuse to look at your machine.
Posted on May 28, 2009
SOURCE: Circuit Breaker is tripping when tumble dryer is
Circuit Breaker is tripping when our tumble dryer, creda 522vw, is turned on. Have removed back and top of tumble dryer and cleaner all excess lint, checked connections and exhaust. Any ideas please
Posted on Oct 03, 2009
My indesit condenser tumble dryerwont start
try door interlock......................cheers
Oct 07, 2016 | Indesit Dryers
My white knight condenser tumble dryer keeps
is it just shutting off or is it tripping ur breaker?
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Oct 13, 2014 | Dryers
My white knight tumble dryer wont start
Nothing works or drum fails to turn (tumble dryers)
Ensure that the power supply to the dryer is switched on, the timer is set to the desired drying time and the door is correctly closed. If you have a condenser model, also check that the bottle is empty and is fully pushed into the machine.
http://www.whiteknightrange.co.uk/whiteknight/faq.html
The first thing to establish when troubleshooting the clothes dryer is whether the dryer will start or not. If it won't, start by checking the outlet and the circuit breaker. Is the dryer plugged in or has it tripped the circuit breaker? If the breaker has been tripped, flip it back on and try the dryer again. The drum should turn without a problem.
If both plug and breaker are fine, you'll need to inspect the door switch as you continue to troubleshoot the tumble dryer. When you close the door on the dryer, a plastic peg should click and operate the switch which allows the dryer to work. The peg might be bent or broken, in which case it won't connect with the switch. You can try to straighten the peg, but if it's broken, you'll need to replace it. If the peg is fine, the switch has probably failed and will need to be replaced.
http://www.doityourself.com/stry/troubleshooting-a-clothes-dryer-drum-doesnt-tumble#b#ixzz3FOOQgtAT
Oct 06, 2014 | White Knight Press Genuine Tumble Dryer...
When drying the laundry,(Miele T7744C) water does not get into the properly closed condenser unit at the top anymore but is accumulating on bottom of the dryer, I hear it sloshing under the drum. Also some...
test this steps and fix it. God bless you
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating Element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it. The proper ohm reading can be found in the service manual or sometimes on the tech sheet located somewhere on your dryer (9- 13 ohms is a common reading). Electric heating elements aren't repairable.
Thermal fuse / Thermal Cut Out / Thermistor
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel or behind the front cover. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing They are also round and made of metal and plastic. The thermistor is located on the blower housing usually. If any of the fuses do not have continuity replace it. Check for continuity if none replace, But before replacing check for obstructions. The fuses are very inexpensive
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. Check all connections, make sure they are tight. Loose connections can lead to a fire. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jul 31, 2013 | Miele T7744C Dryer
How do you remove the water pump on an indesit idc75 condenser drier?
This easy to use white Indemnity condenser dryer will make a welcome addition to any kitchen. The 10 minute cool tumble and reverse tumble option will help keep creases in your fabric to a minimum. Energy efficiency ratings & performance: Energy efficiency rating: C. Maximum drying capacity 7kg. Condenser dryer features: 160 minute timer. Including 10 minute cool tumble. 2 dryness levels. Manual control. Reverse tumble option. Reservoir full indicator. Fluff filter. Size H85, W59.5, D58.5cm. Drying programmes Freshen up cycle. Manufacturer's 5 year parts and 1 year labour guarantee. Technical specifications: Energy consumption: 4.48kWh per cycle based on dry cotton cycle. Energy consumption: 336kWh per year based on dry cotton cycle.
please comment on my post or vote for the solution.
Dec 21, 2010 | Indesit Dryers
Our Zanussi condenser dryer, trips the house circuit breaker, at change of tumbling direction
I myself would say you have a bad Motor.Something in that motor is not working correctly.
Nov 20, 2010 | Zanussi TC7102W Electric Dryer
Tumble dryer keeps tripping the mains
The twin breakers for the dryer circuit should be rated at 30 amps. Have the current draw checked on each wire leading from both breakers (with a clamp-on ammeter) while the dryer is operating. If the breakers trip just as soon as the dryer is started, there is very likely a short to ground/neutral within the dryer case (usually the heating element).
Aug 04, 2009 | Dryers
Indesit washer dryer won't heat up in dryer mode
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Nov 27, 2008 | GE Profile Harmony DPGT750GC Gas Dryer
My whirlpool tumble dryer keeps tripping the circuit breaker
Mar 24, 2008 | Dryers
Dryers Logo
953 people viewed this question
Top Dryers Experts
