Question about Denon AVR-1604 Receiver
No sound on Denon AVR-1604
I turned the unit on and I am not getting any sound whatsoever. Working backwards, I checked the speakers on another system and they work fine. I then checked the speakers with the speaker wires hooked up to another amp and they work fine. So I've concluded that the problem is in fact with the receiver. I checked all the connections and tried to run a speaker test and nothing happens. Help !!!!!
  • michael451 Feb 11, 2009
    Got a refurbished unit of the 2809 model. Exact same issue. Were you able to resolve yours?
SOURCE: Denon reciever avr-487
If your tv is putting out mono you will only get the center and sub speakers. This can be because the tv is only mono, or the output is set to mono in a menu of the tv. If you have cable or sat run the digital audio out to you receiver; it usually sound better that way anyhow. Set your receiver to Dolby mode for best sound.
Posted on Aug 27, 2007
tech48
  • 624 Answers
SOURCE: Denon AVR-3802
I have repaired many of these Denon receivers over the last few years.
Since the headphones work, that means if you dis-connect the speakers it will turn on and not go into protect (when power cuts off a few seconds after turning the unit on).
The most likely problem is a bad speaker. to find out which speaker is causing the problem, do this.
Start out with just one speaker connected and then turn on the unit. If it turns on and plays music, you know that speaker is good.
Now turn the unit off again and add another speaker and keep the first speaker connected. Once again, if the unit plays, that speaker is also good.
Keep doing this same procedure one speaker at a time. As soon as you connect a speaker and then try to turn on the unit and it goes into protect, the speaker you just connected is bad.
To confirm that this speaker is the bad speaker, dis-connect all speakers and only plug the suspected bad speaker into a speaker jack that worked with one of the other speakers.
If the unit still goes into protect you know then that you have found the bad speaker.
If the unit still goes into protect, that speaker is bad and you will need to take it in for repair or replace it.
make sure you use 8 ohm speakers. if i remember correctly these Denons can use 6 ohm speakers, but those are harder to find and most home speakers are 8 ohms.
If the unit does not go into protect and that suspected bad speaker plays in one of the other speaker jacks, what you really have is a bad channel in the amplifier, the channel that the suspected bad speaker was previously connected to.
If you find out you have a bad channel, you will need to take it in to an repair center. Preferably an authorized Denon service center. There are not very many of those around. I work at the only authorized Denon service center in the entire state of Michigan.
If I can be of more assistance, don't hesitate to ask. And a good rating is always appreciated. :)
Posted on Jun 22, 2008
SOURCE: Denon AVR 900
well its possible you have it on stereomode put it on prologic ceneter mode on normal for best sound
Posted on Nov 05, 2008
  • 93 Answers
SOURCE: Denon AVR 2807 with Bose Acoustimass 15
Well,i can tell you are not very focus,cause you posted Denon AVR-2807 with Bose AC 15 problem,but under your details,you put down AVR-5807!
First of all,it is so unfortunate that you are NOT able to gain and experience to true ability in sound for this wonderful receiver when you are using a dual tweeters speakers and expect to have good sound separation as a TWO WAY speakers(a tweeter and a midrange-for true high frequency and mid frequency sound separation.)
Secondly,you have defeated the audio configuration of the Denon AVR-2807,since all your speakers are control BY the Bose subwoofer.
Now,i could show you a way to hook this up,and it doesn't matter how you connect them, they are the "bicycle tires" installed with a "Porche"engine if you know what i mean.
If you want a good recommendation for your "beast",i will more than happy to show you the way!
Cheers,
solutiondoct
Posted on Nov 06, 2008
vortash
  • 431 Answers
SOURCE: WIRELESS SPEAKERS
There are many kits at Maplins or Radio Shack that will do this for you , you can search for them at http://www.maplins.com or http://www.radioshack.com you may even be able to build one yourself from circuits available off the web .
Yes you will be able to use your own speakers and your options are basicaly down to what you can afford .... Regards Vortash
Posted on May 02, 2009
My right speaker no longer works. It was fine yesterday. When I do the speaker test, the left one gives out sound but the right is silent. I'm getting no sound whatsoever when I play You Tube videos.
well go to ur speaker icon on the right hand..next to the clock and open it up..volume mixer...make sure the lide is full on the top and not muted...if it is undo muted ...also check ur cable to ur pc..if it was working yesterday...well something gone wrong with the wireing..
Oct 04, 2013 | Acer AL1717 17" LCD Monitor
Main Speaker Not Working
IS there a circuit board inside that speaker? You are correct about the general loss of sound quality that usually occurs with speaker failure. Best way to check is with a meter or a scope
May 04, 2013 | Mackie SRM-450 System
I'm having problems with my Creative Labs Gigaworks S700 speakers. Last night they were working fine, and this morning there is no sound whatsoever. I have them plugged into my laptop, and the laptop...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 16, 2011 | Audio Players & Recorders
Radio working just fine But no sound coming from speakers
if the radio still has power the audio amplifier ic in your radio has failed.
take your radio to an electronics repair shop or, replace the radio; this not something you can fix unless you know how to use an oscilloscope.
Aug 01, 2010 | Harley Davidson 426290 AM/FM Radio
Speakers are not working
try these. remove ac adapter and battery. press and hold on the power button for 15 seconds. plug back ac adapter and battery. download the latest bios for your system from the manufacturer's website. if still same problem try a system restore from the time when everything was working fine. try an external speakers check if the audio jacks are working. if all fails replace mobo. if external speakers ok then replace laptop internal speakers.
Apr 03, 2010 | Computers & Internet
46" Samsung LCD, no sound output whatsoever
First try hooking up a different source such as a DVD player or Cable box and see if you have audio. If you do then check the audio output from the computer. If you do not have audio then make sure the tv audio is up half way and turn off the set. When you do this you should hear the down chime provided you have the chime turned "on". If you do not hear the down or up chime then the sudio circuits on the Main bd are bad and the Main bd will have to be replaced. A quick way to check to see if the audio circuits are working is to listen for the up or down chime when turning on of off the set coming from the tv speakers speakers.
Jul 14, 2009 | Samsung HPT5054 50 in. HD-Ready Plasma...
Speakers aren't working
Is speaker Power indicator is working fine ?
If not, then u need to repair ur speaker.
If Power is fine then follow the steps :
1. Play any MP3 files in any media player. Did u get any error ? if yes then u need DRIVER for ur sound card.
2. If player plays file, and e\equalizer of player is animated then please check speaker jack(back of ur MotherBoard)
3. If still problem then please check configuration from control panel of your windows.may be volume of speaker is muted
If you have any problem let me know.
Thnaks,
Mukund
Einfochips
WWW.einfochips.com
May 15, 2009 | Dell A215 Computer Speakers
Kenwood hac 9152d, was working fine now doesnt output any sound
Check the fuse on the amp.
My girlfriend had the same thing, light was on, no sound whatsoever. The fuse on the amp had blown, but I'm guessing some current must have made it through to just put the light on. Make sure you have a 40 amp fuse in it, that's what it needs.
Good luck
Dec 10, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Z-680 optical acting very strange
I bought a new cable. The old one was bad.
Mar 18, 2008 | Logitech Z-680 Computer Speakers
Denon AVR-1604 Receiver Logo
142 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
