Question about Samsung Televison & Video
Picture flutter mostly at the top....IF it were a VCR, you'd be reaching for the tracking knob...Samsung HT D5610
    Scholar:
  • 181 Answers
Remove the plug of the tv for sometime then reinsert. and check out.
Posted on Nov 14, 2008
I have a Hitachi VT-FX665 VCR. It has a picture, but no color.
Could be caused by dirt on the video head, poor tracking, which can be adjusted, or a fault in the colour circuit.
Tape cleaner tape for the head. Press the tracking controls on the remote and you will need to see a repair man for the last one.
Mar 28, 2015 | Samsung Televison & Video
I play a tape in my Sony SL-5200 Betamax VCR. It plays normally for about 5-10 minutes and then the picture starts fluttering which lets out this loud buzz on the Hi-Fi audio track and cuts it out to mono....
It could be some kind of tracking problem. The cause could be dirt on the tape head, or perhaps something worn such as a drive belt etc. Check to see if it gets worse or better with the cassette nearly at the end of the tape or at the start of it. Indicating a tape tension problem, on the reels or drive.
Jul 28, 2011 | Sony Televison & Video
Noise in sound track and picture flutters.
Sounds like it could be dirt on the video heads. A good clean up with Servisol Video 40 might do the trick.
Jan 25, 2011 | Panasonic PV-V4620 VHS VCR
Samsung VCR SV-5000W Tracking Problem Symptom: I've used Maxell VCR Head Cleaner VP-100. Still having small white streaks across screen. I can apply small amount of pressure to bottom or top of VCR deck...
Your chassis ground is intermittant. Remove the VCR cover and look just behind the head drum. You will see two copper tangs sticking out, these supply the ground to the grey chassis and are a pressure fit. Remove the 7 screws from the grey chassis, two are underneath the VCR, two on top near the VHS tape opening, and three larger screws are on top of the chassis (2 near back and 1 near front). This will allow you to lift the grey chassis about a 1/2" and you can then reach below the copper tangs and gently pry them up. Reinstall the 7 screws and the VCR cover and the snow will disappear.
Nov 26, 2010 | Samsung SV5000W VHS VCR
I have a Sylvania SRD3900 DVD Player / VCR Combo that I purchased about 6 years ago. The VCR part is causing problems. When I try to play movies the picture is distorted with no sound, but it plays back...
The tracking needs to be adjusted. Sometimes it's a knob on the VCR, and sometimes it's a control on the remote. Adjust it for the best picture, and the sound shoud be restored.
Good luck, and hope this helps..
Nov 01, 2010 | Sylvania SRD3900 DVD Player/VCR
Picture rolls and the tracking is off.
do the heads need cleaning? sounds like the heads are seriously out of alignment? take off the vcr cover get a philip scrdrv. put tape in. and play. theres an AC head just to the right of the drumhead. jiggle it around gently. u may have to adjust those 3 screws (precison) to put it back in proper adjustmant. also take the tapes u used in that vcr. open the top flap and inspect. are there marks? is there a line going the bottom portion of the tape. if so , it definitely is out of alignment.
Aug 14, 2009 | Philips Televison & Video
Samsung dvd home theater HT d5610
This sounds like a short circut (check speaker and other conections to make sure none are touching each other or a metal contact!
That should fix ya!
Dec 18, 2008 | Samsung DVD-R155
Tracking problem
Suggestions: 1. Do a "reset" by unplugging VCR for 30 seconds or so. Doubtful to fix- but worth a try. 2. Pull the top cover, load a tape and play. Does the tape seem to wander up and down across the video or control heads? If so, this is a mechanical problem- perhaps a tape guide is broken. 3. Electronic problem: If this is the case, probably trash the unit unless unit is a high dollar ($250 or up). VCRs (like most other consumer electronics) are throw away items these days.
Feb 18, 2007 | Samsung SV5000W VHS VCR
Televison & Video Logo
Henry  Thomas
Henry Thomas
