Selectric II return problem
I have a selectric II. It works but when you hit return it goes past the left margin. The print mechanism then gets jammed to the left of the margin control. Specifically, the plastic R - S slider thing on the printer mechanism contacts the margin control when you try to hit return.
Any help is appreciated!
  • Evanston Nov 18, 2008
    Thanks. I found the machine had a bunch of tabs set. I cleared them. After that the printer stopped at the left margin just like it should.
    Thank god the selectric ii was made so well that this problem didn't cause damage.
    John
    Scholar:
  • 183 Answers
This one is hard to diagnose without actually seeing it, however if it is hanging up on that slider, you can simply remove the slider without any harm to your machine. the slider is a throwback to when "ditto" machines were used for printing. all it does is stop the ribbon from working when it is in the "S" position, and you can do the same thing by removing the ribbon. to remove it, move it to the left and pull till it comes out. if the spring that is attached doesn't come out with it, just pull it out.
however, if the carries goes past the margin all the way to the left of the machine, then this is not going to stop that. what usually causes that is a little lug that faces the carrier on the l. h. margin set lever, if there is a crack in it, it will need to be replaced. also check that when you hit the "mar rel" button the margin rack pivots up then back when you release it. if the rack is stuck in the up position, then that is your problem.
Posted on Nov 17, 2008
Testimonial: "Awsome!"
When I hit the spacebar it reads one "hit" as 7 or 8 spaces every time, how can i correct this?
hi i will look for any dirt, dust or any small pieces inside also make sure nothing is lose
in some chases a good clean can sort a lot of problems
Apr 22, 2015 | IBM Correcting Selectric II
Selectric II Pitch-shift lever won't change from 12 tom 10
If you haven't changed the pitch for a long time the lubricants dry up, if you have some WD40 spray it in the slot inthe margin bar where the L. & R. margin levers ride. Give it a few minites to work.
DickyO
May 16, 2012 | IBM Correcting Selectric II
IBM selectric II carriage stuck in right margin
There is a thin metal ribbon in the back that has come off the wheel. It is a devel of a thing to get back on.
Remove the cover and watch ... you will see what I am talking about.
It may have come un-attached ... equally difficult to fix without the little thingie the typewirter mechanic uses.
good luck
Oct 14, 2009 | Office Equipment & Supplies
My IBM selectric II typewriter carriage stuck in right margin
Sounds like the return lever arm is not putting enough pressure on the return clutch, or the clutch is slipping. The exp key uses the same clutch but the pressure comes from your finger. Theres no way you can fix this yourself. Get an IBM mechanic.
Oct 14, 2009 | Lexmark Wheelwriter 15 Series II...
IBM Selectric II keeps returning to right.
Check the pitch lever on the top L. of the cabinet it may be in between positions.
DickyO
Sep 08, 2009 | IBM Office Equipment & Supplies
I have a IBM Correcting Selectric II and I'm having trouble clearing out the margins. Can you help?
space to the right side of the machine, hold down the tab clear key and hit return.
If the carriage stops partway back, one of the tab stops has rotated too far on the tab bar.
remove the platen and paper pan, go to the stuck stop, rotate it to the rear of the machine to line up with the other tabs
Jul 16, 2009 | Nakajima AE-710 Typewriter
IBM Selectric II-return goes past the margin stop
The margin release mech. is probably gummy and allowing returns to go past the margin. If thi is a dual pitch machine see if the pitch selector lever will move easily. If not use some WD40 on the margin rack.
DickyO
Mar 11, 2009 | Lexmark Wheelwriter 15 Series II...
IBM Selectric II
R152
Sounds like you have a broken torquo limiter tension spring you should have it professionly serviced.
DickyO
Jul 07, 2008 | Office Equipment & Supplies
IBM Selectric II
The return clutch torque limiter is off or broken. If you take the right dust cover off it is on the turning hub around the middle of the typewriter. a small spring about 1.25 inches long with a hook on the end. I have been fixing these for 35 years. good luck. Lawrence
Jun 06, 2008 | Lexmark Wheelwriter 15 Series II...
Correcting IBM Selectric II Typewritter correcton ribbon won't engage
Selectric I and II type elements are identical (88 char) where Selectric III uses a different element (96 char). The 88 character element will have white lettering and the 96 character element will have yellow. Directly underneath the lift-up tab to remove the element will be a 3-digit number. That's the last 3 digits of the element's part number, which will be preceeded by 1167 for 88 character, or 1352 or 96 character. For example, if you have a '052" stamped on the element, and it's an 88 character style, the P/N will be 1167052.
The correcting mechanism is an intricate additional function of the backspace function. To test it/adjust it/or repair it requires the machine be hand-cycled using a hand cycle wheel which is screwed into the right hand side operational shaft. It's unlikely that an un-trained party would be successful repairing this..
May 15, 2008 | IBM Wheelwriter 30 Typewriter
75 people viewed this question
jasbo
jasbo
