Filled dishwasher, sounded like it ran through a cycle but noticed that 3 hours later it was still on Heat dry.... when I opened it some of the plastic had melted and nothing was clean. Tested again and there is no water running through the DW but the heat works.... believe me!
-   After running the dishwasher through a wash cycle, I find that all the dishes are still dirty, and the soap is now lying in a pile near the float thing at the bottom left corner. The heat and water do work.
-   jng442
Jan 05, 2009
-   Yes, I have the same problem. Do you have a solution yet?
Will not fill with water and clicks red light to dry heat.-   kittymcneill
Jan 03, 2009
-   I have the same problem, and mine is also only 2 years old.-   sthicks14
The problem appears to stem from the float and float switch. The float is a mushroom shaped plastic part that resides on the bottom left, just inside the door. It appears that the float does not release the float switch, causing the dishwasher to think it is full of water, and won't allow the dishwasher to fill. It's a relatively straight forward repair, but even with a new part, the same scenario is likely to repeat itself until the float or float switch is modified by Kenmore.
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #2
posted on Jun 26, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Where is the reset button found on a Kenmore 587 model dishwasher???...HELP!!!!!!!!!!!
Solution #3
posted on Sep 20, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Did you ever find a solution to this problem? We are having this exact same problem with a brand new dishwasher.
Popular Solutions for Kenmore 16602 / 16604 / 16609
I can't figure out how to take apart the spray arm on my Kenmore dishwasher to see if there's...
(More)
I can't figure out how to take apart the spray arm on my Kenmore dishwasher to see if there's anything stuck in there. The dishwasher is making a loud noise and I think there could be something stuck. I tried to unscrew it but it won't budge. Is it supposed to come off some other way?
dishwasher not cleaning dishes as good as before. is there a filter that needs cleaned or changed...
(More)
dishwasher not cleaning dishes as good as before. is there a filter that needs cleaned or changed somewhere?
