Question about Viking VGSC306-4B Gas Kitchen Range
Viking Gas Oven VGSO-166 flame too high
VGSO166 36" VIKING Gas Oven:
Just installed a single VGSO 166. We are on LP (Propane) tank gas. We have numerous other gas appliances in the home....the WC for the LP gas (whole house regulator) is adjusted properly (around 11").
The problem: The flames which arrise from the burner tubes are almost 4" long. The flames are yellow tipped even at max air shutter (yes, worse with closed shutter) and indicate excessive gas flow/pressure and/or insufficient air. There is (already) some sooting after just a few seconds of run-time.
Any clues? This unit has an internal regulator. The orifices are extremely difficult to turn, so we are not very motivated to unscrew/loosen them to verify that the adjustment was correct. One orifice DID tighten a little bit more--this seemed to improve the flame on the that burner tube.
Anyone ever worked on one of these? (below is the background on the installation)
Per the instructions from Viking (not very clear) the regulator cap was 'flipped' and the spring (under the reg. cap) was left in place. The force required to secure (bayonet lock) the reg. cap was higher than expected. Also per instructions, the 2 main gas burner (oven) orifices were adjusted (per the manual; counterclockwise--we interpreted this to mean 'screw the orifices into the gas tube further, as opposed to loosening the orifices back towards the air shutters'. We have the broiler orifice ready to be installed, but didn't have time to drop the broiler after trouble shooting the oven (3 wires were loose after shipping).
HELP!!!
  • 2 more comments
  • taterhed Dec 21, 2008
    Consulted with a local tech....he suggested that the orifice must be VERY tight. The instructions indicate "...tighten to the pin..." or some such nonsense. The tech suggested 'tighten till no threads are visible'. This did the trick.
    Thanks for the help.
    The flames are still quite high for the size and shape of the flame deflector. Cooks like a charm though!
  • taterhed Dec 22, 2008
    Is the #57 orifice the same 'variable' screw down to adjust orifice that comes stock installed on the unit?
    Thanks.
    Thank you so much! I'll get the #57 orifices and install them to settle my mind.
    I've read a lot about pre-mature burnout of the flame dispersion pan/oven floor. Seeing the level of the flame and the glowing metal, I'm going to try and avoid that.
    The oven is certainly not short-cyling.
    Thanks so much!
    By the by....are the orifices just standard #57's ? Nothing special I'm guesing?
    That was my idea. Thanks.
    Again....super job!
    Wish the company could have just supplied the two burner orifices along with the broiler orifice (the broiler works precisely as it should!)
    Cheers.
  • 42 Answers
Make sure the hood orifice is a #52. (orifice to bake burner)you can go to the local propane gas company and see if they have one they will sell you.
Posted on Dec 20, 2008
  • 1 more comment
  • Tom Hurley Dec 22, 2008
    the correct orifice for the propane is a #57
    the #57 is the size the variable should screw down to when you tighten the orifice over the needle. by going ahead and using the #57 you know for sure that the size is right when it is snug
    they call it a hood orifice .. i would take the variable orifice off and take it to the gas company just so they will see it is a hood orifice. remember the #57 will have a smaller hole then the variable orifice because your not be adjusting it down as you turn it
Viking grill burner low flame
If this burner has tube type, You can loosen a screw in the front of burner and slide open air rater vent just a little just make sure not to open to far. blue-ish/orange flame is what your looking for
Apr 10, 2015 | Viking 500 Series VGBQ53002RELSS 30"...
Is there a specific regulator for a Viking D3 cooktop or can I purchase one off the shelf?
If it runs on natural gas it has a lower pressure regulator than one that runs on propane gas. Nat gas is 1.1kpa propane is 2.75kpa
May 03, 2014 | Viking D3 RDGSU2605B 36" Gas Cooktop with...
GE Range - oven flames too high after regulator replacement and self clean
You need a Gas tech/plumber there urgently!!!!
If the gas jets in your oven had not been changed to accomodate LP gas then the orifice on your existing jets are still to large in diameter. In other words your using Natural Gas jets ( lower pressure jets) for Lp which has a much higher pressure than Nat. gas, this can be extremely dangerous, & could cause major problems.
Again I strongly suggest you contact a Gas tech/Plumber & do not use your oven until it has beeen checked by a professional.Good luck
Aug 18, 2012 | GE 30" Free Standing Electric Range
What i need to do to convert my viking stove mod. vgsc3064b from natural gas to propane? or were can find the serial number on it?. thanks
Crank down and flip.
Tighten all spuds open all shutters and flip the nut on the regulator from NAT to LP. Directions are HERE
Jan 28, 2010 | Viking VGSC306-4B Gas Kitchen Range
My Viking gas oven is slow to heat?
very likely the thermstat is defective, most likely the oven temperature proble
Jun 21, 2009 | Viking VGIC305-4B Gas Kitchen Range
I have a gas oven. The flame burns yellow and leaves too much soot on the wall near the flame. Is there a way to clean the element thing? Dave
I am not sure. However, people in our area of sc, have had burner problems because a local utility added propane to their natural gas because they got it a bargain. guy
Jun 10, 2009 | Frigidaire FGB24S5A Gas Single Oven
Viking pro gas range propane conversion
Sounds like your range is set up for the wrong kind of gas, or, in the case of LP, your installer failed to make the necessary adjustments once it was hooked up. First step is to insure that you have the proper range for type of gas you are using. If not, the orifices for all surface and oven burners will have to be changed out. That should be done by a qualified service technician.
May 21, 2008 | Viking 37 in. VGSU161 Gas Cooktop
Viking range - no way to simmer
There is a conversion kit to convert the range from natural gas to propane, it is possible that it was not installed or not installed at the time of purchase. There is a part in the regulator that has to be switched from one gas type to another as well as individual burner orafices that have to be changed. You should have the point of purchase service verify that this has been done correctly. The complete information should be in your owners and installation manual or available directly from the viking website.
Nov 19, 2006 | Viking 37 in. VGSU161 Gas Cooktop
Viking VGSC306-4B Gas Kitchen Range Logo
819 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
