Question about IBM ThinkPad T20 2647 Notebook
T42 Turns on for a split second then turns off.
Good evening, Yesterday my IBM T42 unexpectedly turned itself off. Since then every time I try to turn it on it comes on for a split second before switching off again.
I have been trying to to turn it on with the powercord in.
I recall that it did not make the warnign noise before it switched off to say the battery was dead, it just turned off.
  • 2 more comments
  • msdehder Nov 20, 2008
    yes it comes on then truns off in a split second
    yes the light lights come on as normal, the amber and green lights, the only thing that doesnt light up is the circle symbol with what looks like a z in it.
    I tried changing the fuse on the powercord with no luck
  • comment
    comment May 11, 2010
    I need more detail.. I understand the compuer starts up momentarily, and then shuts off.. THis is not the question I need answered,, The question is about the lights ( illuminated ICONS ) only.. Here is the question again..
    When you plug in the AC, does the amber charge light ( ICON ) come on? And, is the AC ( green light (ICON) ) on?
    Also, if you lightly jiggle ( side to side slowly ) the AC power cord where it enters the computer, do you get any lights or not.. You may have to try to hold the position of a few seconds while checking this.. Have you checked where the AC cord from the wall plugs into the power module?
    At this point, I'm not concerned whether the computer itself starts or not, just the lights ( lit icons)
  • comment
    When you plug in the AC, does the amber charge light come on? And is the AC ( green light ) on?
OK. What you can do is to take out the battery then the HDD the plug in the unit and try to start it
If is doing the same thing definitely you got a bad SODIMM. If you have two of them try removing one and another to see which one is bad.
When you take out the HDD and memory remember to dismantle battery first and disconect the main.
This is the way to avoid damaging your memory and HDD
Posted on Nov 21, 2008
My IBM THINKPAD T42 screen turns to black after 30 to 40 seconds when i turn it on.
This indicates a hard drive problem, have it tested to confirm, because the hardware may need to be replaced. First try and reload windows with cd installation disc if that does not work the hard drive must be suspect.
May 01, 2012 | IBM ThinkPad T42 Notebook
My ibm thinkpad t41 turns off after sometime when i turn it on...it show cmos checksum bad
Hi:
It is time to change the CMOS Battery Backup, its located inside the unit is the size of an nickle.
Dec 19, 2010 | IBM Thinkpad T40 Thinkpad T41 Thinkpad T42...
I have a T42 IBM laptop, and its screen turns black whenever I remove the charger. Why?
bad battery.
keep using charger at all time before you use a new battery.
good luck.
Nov 26, 2009 | Acer Aspire 4520-5582 Notebook
On screen display of volumn keys on IBM T42
check it on the IBM site for the programme
Sep 03, 2009 | IBM ThinkPad T42 Notebook
IBM thinkpad t42 boot up problem.
The most common reason is memory.
First, try to reseat (remove and reinsert).
If still a problem, test one module at a time.
Hope this helps.
Aug 17, 2009 | IBM ThinkPad T42 Notebook
Computer turns on and off all by itself.
check out wall power
change the smps
may be software problen unintall and reinstall operating system
Aug 05, 2009 | IBM Thinkpad T40 Thinkpad T41 Thinkpad T42...
Ibm t42 display turns off as if I had shutdown
You can test the computer this way. Connect the video output at the back of the laptop's base to a known working monitor. If the problem disappears completely then you know it is a screen problem, mostly likely. But if the same thing happens with the known working monitor connected to the Thinkpad, then you very likely have the BGA problem, a part that was soldered less than well (due to the restriction of lead not being allowed in the solder due to government regulations). And it may also be caused by flexing the base due to moving the laptop with poor support for its weight and resulting motherboard flex on rather delicate microsoldering. There are several services that "reball" the Ball Grid Assembly, and there are motherboards available as well that can replace the non-working ones. This is not a cheap fix to undertake but it can be done.
Mar 21, 2009 | IBM ThinkPad T42 Notebook
Turns off autometically
How far does it get on the boot process? Does it open the operating system completely before shutting down? Do you get any error messages, and does it go to a black screen stating Windos wasn't shut down properly? Answer these and I'll have a better idea of what's going on.
Aug 26, 2008 | IBM ThinkPad T42 Notebook
Shuts down autometically
Also, have you changed anything lately? and, Did this just start happening out of the blue, or did something happen to cause this, ie... power failure, kicked the plug out, ran the battery completely dead, overheated, etc...?
IBM ThinkPad T20 2647 Notebook Logo
500 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
