Cant get setup disk to load - Computers & Internet
  • pitweb
    pitweb May 11, 2010
    Could you please specify more what you would like to acheive?
    Scholar:
  • 58 Answers
Try going to Start > My Computer (Or click it on your desktop). Then, right click on your CD drive icon and click "Open". Now try finding a file that may say "autorun" or "setup" and has an icon next to it - it's most likely the setup program. If it still doesn't work, then either you have a scratched CD, or you are trying to install an incompatible program.
Posted on Nov 14, 2008
I cant get ubuntu 11.10 to load onto my compaq nx9030 the disk runs fine but when i go to install it doesnt work
Use the Windows installer for dual boot. Easy! Or test as Live CD (no-install)
A full install may require partition and Linux disk / file format. Along with setup files destinations options. This a full commit install.
Nov 08, 2012 | HP Compaq nx9030 Notebook
I cant see disks in disk management how do i install operating system in my pc
You may not have created a partition on your hard disk. To install OS in your PC.
1. Insert your bootable CD in your CD/DVD-ROM Drive.
2. Press any key to boot from CD. Setup will then load the necessary files.
3. Once everything is loaded. Press "C" to create partition. You can specify the amount of disk space on your primary partition. You can also create another partition for the remaining disk space.
4. Select the partition where you want to install your Operating System then press "Enter".
5. It will prompt you to format the partition. Choose NTFS format and press Enter.
6. Once complete, it will reboot your PC several Times. If you're ask to press any key again to boot from CD...DO NOT press any KEY...Just wait for it to load. And it will continue with the setup.
7. Just follow the next steps...
Mar 21, 2011 | ASUS Eee PC 1000HEee PC1000Eee PC 901 Eee...
When bootin up my dell optiplex170l says cant find sata, i messed about with some settings on bios screen but cant get it to work... it had virus so i put a disk in to sort it out but accidentlly turned pc...
At this point, it might be good to take your computer to a qualified technician, before you make things "worse".
Restart your computer.
Enter BIOS SETUP.
Select LOAD BIOS DEFAULTS.
Select to SAVE the settings.
This may eliminate the 'SATA' message.
Given that a new disk-drive (SATA or EIDE) will be about $50 for 200GB to 500GB, I recommend that you buy a new disk-drive, and reinstall Windows. Then, connect the "old" disk-drive as a "slave" disk-drive, and copy all your "stuff" from the "old" disk-drive to the "new" disk-drive. It never hurts to have *TWO* copies of your files.
Aug 16, 2010 | Computers & Internet
I cant get lifecam disk to load I put the disk in nothing happens
With the CD in the drive and using explorer, go to the CD drive and look for Setup.exe.
Double-click on that file and it will start the install procedure.
Dec 31, 2009 | Microsoft LifeCam VX-1000 Webcam
I put 2 disks in raid 0 array on this controller
When you say "after merging the driver via a floppy at the txt setup" I think you are referring to pressing the F6 key to load the raid drivers. But I don't understand "restarting setup".
You will need the correct XP64bit drivers loaded on a floppy for this to work.
Maybe a good place to start is a temporary install of XP using 32bit drivers to prove all components are working.
Nov 01, 2009 | Adaptec 1220SA (2232100-R) Storage...
Cant detect hard drives during the process of loading xp
Just pres F2 key on startup. Go into bios. In bios find HDD and press enter next to mode. Select IDE mode and press f10 to save changes and exit. You can install XP now. Alternatively you can use USB floppy drive to load SATA drivers.
Let me know if you need assistance on that
May 26, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
I have a wd sata hard disk and i cant setup windows xp on it, it the monitor says ..... " windows can not find any hard disk instal into your motherboard " i need to solve this problem please thank you
Windows XP didn't have support for sata drives. You will need to load the driver by pressing F6 when you start the Windows setup. You will see the message
Press F6 to load 3rd party drivers at the bottom of the screen when Windows is installing.
Apr 06, 2009 | MSI Computers & Internet
Acer Aspire5170. Vista. Was running fine, i uninstalled a few unwanted programms, cant remember which, it needed a restart inorder to complete the uninstalls, but i didnt. my sister then closed laptop, so...
U HAVE TO ENTER THE SETUP FUNCTION WHEN U FIRST TURN ON THE COMPUTER , PAY ATTENTION TO THE SCREEN AND IT WILL TELL U WHAT KEYS TO HIT IN ORDER TO ACCESS THESE MENUS. CHANGE THE BOOT ORDER TO BOOT FROM THE CD AND THEN PLACE UR DISK IN THE COMPUTER BEFORE EXITING THE SETUP SO WHEN U RESTART THE COMPUTER IT BOOTS FROM THE DISK INSTRUCTION
Aug 04, 2008 | Computers & Internet
When try to load windows it says cant find drive to load to
go to the f12 menu & then select the boot device as hard disk & chk if u r able to boot.....else try chking in system setup if the hard drive is getting detectd....
Jun 27, 2008 | Dell Dim.9150 Pentium D 820 Dual...
I cant finalize my DVD recordings on my magnavox recorder.
Try this. In your SETUP options, ensure that AUTO FINALIZE and FINALIZE AT END OF TIMER are turned OFF.
Insert DVD to be finalized. Quickly press SETUP button. Be patient while DVD loads. (You will not see the "loading" bar on your TV screen. You will instead be mesmerized by the SETUP options!)
Once DVD has loaded the DISK FINALIZE option will be available. You can then FINALIZE.
I found it cheaper to get DVD-R from Radio Shack (about $5 for 25) for VHS movies that I know I want to keep. They do record up to 6 hours, even though the packaging is unclear on this point. Picture quality is as good as the expensive DVD's.
Mar 13, 2008 | Philips Magnavox DVD/VCR Dual Player
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
