Question about Eureka 5892AVZ Bagless Upright Cyclonic Vacuum
The vacumm over heat?
I change the belt, but it got burned so fast and the motor it was over heat.
  • 328 Answers
The filters are clogged and need washing or completely cleaned. Also check all hoses and dust channels to ensure the model is completely cleared out.
Posted on Mar 27, 2009
What is wrong...My Eureka commercial vacuum C2094g smells like burning rubber, replaced belt (style RD) but it was smaller in size and very hard to put on. Am I using the wrong belt? it looks like the...
Replace the Roller Brush. Sounds like bearing in it is locking up and the the belt is slipping and not turning the Roller Brush as it has a locked up bearing. You will need to go ahead and get a replacement belt just in case you have stretched the older belt to a bigger size. I had this same experience with a Hoover and it solved my problems of "rubber burnt smell".
Apr 27, 2014 | Hoover S3765-040 WindTunnel Bagless...
I have a dirt devil dynamite vacumm and am unable to get a new belt on, as I am not strong enough to stretch it far enough. Can you help me? Thank you
if you put the belt on the motor shaft first then put the brushbar through the belt then pull into position,here's the manual with instructions.
http://dirtdevil.com/file/244/
Nov 23, 2012 | Vacuums
Hoover H3030-006 240 V Motor making a loud sound and burning smell
If you have little to no suction, that sound is happening because you most likely have a clog some were in the vacuum.
smell is probably your motor over working itself do to the clog.
also double check your belts on your brushes that they are moving with the motor. smell and sound could come from the brushes being jammed which would cause the belt to freeze and heat up and could burn the belt and or your motor.
if it is still running though your not in the red yetm so triple check that the machine is cleared off all clogs and jams in the belts and brushes.
Jul 02, 2011 | Hoover H3030 FloorMate SpinScrub 500...
My bissell 6590 works fine with hose attachment. Motor shaft turns when belt and roller are off. When belt and roller are on it's noisy and smelly. Now one end of the roller actually melted in the holding...
replace the roller,belt and before instalation clean motor shaft where belt rolls. you can turn on the vacumm and using a knife scrape the motor shaft from the black dirt.
Feb 19, 2011 | Bissell 6590 CleanView Bagless Upright...
HI, my motorized brush barely turns.It makes a hot rubber smell. I took apart and noticed the spindle the belt turns on discolored from heat. Cleaned it, but still no turning of the brush.The vac is a...
That means that the belt is stretched and it is slipping on the motor shaft, that is why it is hot and smells like burning rubber. You need to replace the belt. Here is the correct belt you need:
Hoover Windtunnel Canister Belt
Dec 24, 2009 | Hoover S3765-040 WindTunnel Bagless...
I have a Eureka Altima vacuum. The model number is 2996. I don't think my vacumm is sucking any dust. Plus, it smells like a burning leather. What should I do? I have tried to get help from others and they...
Sounds like the belt for sure. Here is a link with the owners manual. It shows how to get to and change the belt.
http://www.eureka.com/index.php?option=com_productdisplay&view=productdisplay&task=getproducts&productid=2&product_model=2991AVZ
Sep 18, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
I need to replace the belt on my Sharp Vacuum Cleaner: Model ECTU4609. Can't find Owner's Manual and can't figure out how it goes on .
i have replaced vacumm belts before .. Normally it is located underneath..flip over the vacumm unscrew some screws.. open the cover..youll see a large roller pin type object remove it carefully noting how it is placed..pull it out.. and replace the belt...you can also clean off the debris while doing this..an added plus..for vacumm maintenace..
PLease indicate whether this has helped you at all ..Thank You
Jul 05, 2009 | Sharp Twin Energy EC-TU4606 Bagged Upright...
Powerhead no longer working
If you can hear the power nozzle motor running, but the belt doesn't spin, it is most likely the belt. You will have to get the belt from an Aerus dealer or a Vac shop. If you want to put the belt on yourself, you can. There or five or six screws on the bottom of the power nozzle that need to be removed and the cover should come off. Once the cover is off, you will see the belt and how to change it. Good Luck!!
Dec 15, 2008 | Electrolux Epic 6500 Vacuum
Smell
hi
check there faq page from here http://bissell.com/Search/FAQ.asp see if they can answer that ?
riz.
May 31, 2007 | Bissell 6594 PowerForce Bagless Upright...
Eureka 5892AVZ Bagless Upright Cyclonic Vacuum Logo
93 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
