Remote Controls
Problem for Remote Controls
Generic problem for all Remote Controls
Need help programing a RCA NITEglo rem...
By jogar40022 on Nov 14, 2008
The remote is a RCA NITEglo does not have a product # also does not have a indicator light. these remote it has 4 botton on top wich they are OFF-TV-VCR and a botton that light up the VOL-CHAN-INFO-SEARCH-MUTE& GO BACK.
Same Problem
Apr 22, 2009
-   Read it again It has no code search and no indicator. I have the same problem and same remote. Go to the store and buy a new one. Worked for me..... :)-   Guest
Dec 10, 2008
-   I found the following:
Programming the NiteGlo Remote.
1. Manually turn on the TV.
2. Press and hold the CODE SEARCH button until the INDICATOR LIGHT lights, then release the CODE SEARCH button.
3. Press and release the TV button (the INDICATOR LIGHT will blink then remain lit).
4. Enter the code for your TV.
After your code is entered, the INDICATOR LIGHT will turn off.
5. Aim the remote at your TV and press the POWER button. Your TV should turn off.
Note: If your TV does not respond, try all the codes for your brand.
6. With your TV on, press CHANNEL UP. If the TV responds, no further programming is required.
However, it did not work for me. I got stuck at number 2! The indicator light never came on.
-   gretajane
Best Solution
posted on Aug 11, 2009
Very Helpful)
emamamma
Rank: Apprentice
Rating: 100%, 1 votes
IF YOU DO NOT HAVE A CODE , and you need to do a CODE SEARCH, then do the following...
turn TV on
press CODE SEARCH button till it lights up
press TV button
slowly push CHANNEL UP button until tv changes channel
hit the ENTER button
Code will NOT LOCK IN unless you hit the ENTER button.
* It can take several pushes on the channel up button before you find your code. I have a Sanyo tv, & my magic number of times to push channel up button is 50.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on May 05, 2009
Not Rated)
JRW636
Rank: Apprentice
Rating: 0%, 0 votes
This remote was also supplied by RCA for their VHS player, model # VR629HF.
The instructions to program it can be found in the user manual for the VHS player:
http://www.retrevo.com/support/RCA-VR629HF-VCRs-manual/id/19241ag112/t/2/
1-Turn on the TV
2-Find the brand and code number(s) on the code list on the next page
3-Press and hold the TV button on the remote.
4-Enter the code from the code list.
5-Release TV, and then press CHAN up or down. If the TV responds to the remote commands,the remote is programmed.
6-If the TV does not respond, repeat these steps using the next code in the list.
Was this helpful?
Yes
No
Popular Solutions for Remote Controls
Questions and Unsolved Problems for Remote Controls
Answer
What universal remote should I buy to operate my Hitachi Model # CT-7894BC. I have two IR on my... (More)
Answer
I am looking for the remote control codes for a HD Tivo series 3 to control a Magnavox 106cm (42... (More)
Answer
i have a phillips clo34 but it does not have a set up button i already used all the programming... (More)
Answer
remote and manually not working ,batteries ok,power on ok ,no obstacles blocking remote,turned off... (More)
Answer
can I make my omnitech universal remote operate my panasonic SA-HT05 receiver
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Remote... Experts
Top Audio & Video Equipment Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
