Question about Nintendo DS Console
Old style ds changed bottom screen and lost black fixings
Have recently changed botom screen and have lost black fixings on ds
    Scholar:
  • 50 Answers
Well, this is quite tricky. You will have to use your imagination to understand my drawings, and it will be trial and error, but if you persevere then it will work.
First, you cut a piece of paper the EXACT size of the ribbon, then you fold it up like this:
Sorta, well you leave just a bit flat and the rest should be folded up...
Then you insert that where the cable goes, then you put the cable in on TOP of it. Close up the system and you system should run very, very smoothly.
It is fairly tricky, as I said before. You can post another comment if you still don't understand.
This is only for the TINY ribbons that have the LITTLE BLACK FIXINGS.
I don't know how the Live Chat works, but we could possibly try that if it still doesn't work.
Posted on Nov 15, 2008
When i turn my son's ds lite on, the green light comes on, however the screen both top and bottom remain black. when i close the lid the green light is steady, not flashing. it has not been dropped, as he...
I had that issue also.
I opened the DS, and I saw that a connector was not attached to the mainboard. I connected it, and the problem was solved.
Be careful opening the DS.
Nov 03, 2010 | Nintendo DS Lite Console
Dent in screen with black spot oin screen and
looks like u broke the colour crystals in ur ds screen. soz to say that dat cant b fixed.
Mar 05, 2010 | Nintendo DS Lite Console
My Action Replay DSi starts up with white screen.
i saw a vid that shows you how you MIGHT be able to fix this heres the link: http://www.youtube.com/watch?v=l7jshKuBcaI
Feb 20, 2010 | Video Game Consoles & Games
Flashes when you turn it on but won't turn on
there is likely to be a short between bottom screen and motherboard or one of the motherboard components needs replacing. difficult to pinpoint without having it in my hand. as the bottom screen been replaced just recently?
Jan 25, 2010 | Nintendo DS Lite
Ds console powers off after replacing screen
Well, looking at the diagnosis there are two possible problems. You could have both, or just one. Here they are and the solution.
1. Blown F2 fuse. The F1 and 2 fuses get blown most often. Between the two, it is the F2 if the system charges. Here is a website that will teach you how to solder it back together. This site has old and new DS systems on it. Before you solder make sure to check that it is broken with a multimeter.
http://www.m3wiki.com/index.php?title=Nintendo_DS_Lite_:_Repair_a_broken_console_(blown_fuse)
2. Misconnected Ribbons. The easier, and more common problem is that a cable isn't in all the way, or it is crooked. You should just check all your ribbons, and double check them. Take them out, put them in again, make sure all the fixings (little black things that hold the little ribbons) are in, and the snaps are snapped. If you have lost a fixing, just post and say that and I will tell you how to MAKE a new one.
Nov 12, 2008 | Nintendo DS Console
Touch screen doesn't light up
Your problem is with the LCD behind the touch screen. The bottom scren on your DS is actually two screens. An LCD and a touch screen on top of it. Either your cable has come loose inside the DS or the LCD is possibly bad. This can be fixed.
The other option is that the electronics feeding the LCD have gone bad in which case you might as well buy a new DS. But check the screen first.
If the DS is under a year old you can send it to Nintendo for free repair.
Mar 04, 2008 | Nintendo DS Console
DS Lite touch screen
You'll need a tri-wing screwdriver, a small cross head screwdriver a new touch screen and a lot of patience.
1) Remove the screws from the botom case, 3 tri-wing, 3 cross head and the battery cover and battery.
2) Carefully split the bottom case and remove.
3) Open the clip that clamps the touchscreen cable from the back of the connector with a small screwdriver, just carefully lever up the back edge.
4) Carefully part the botom screen from the touchscreen.
5) Attach the new touchscreen to the bottom screen.
6) Re attach the ribbon cable to the clip.
7) Carefully refit the bottom case taking care not to break the power switch.
8) Re fit the screws.
HTH
Mar 01, 2008 | Nintendo DS Lite Console
DS power problem
Hi Nerts,
These cables or ribbon cable and wire connects directly inside the upper LCD monitor. it is not feasible to replace these wires only.  I suggest you see about getting a replacement upper LCD screen which will give you the wires you need and a new screen to boot. Another porblem is the case itself is very hard to disassemble.  You will come near destroying the case to ge to the lcd.  You must disassemble the unit fully and put the correct curl in the ribbon cable to get it to fit right. In short, the price being what it is for a replacement LCD, and the trouble you have to go though to get this problem fixed, It may not be totally worth repairing. If you dont care and wish to do a repair, then my wishes for luck are with you.
Oct 18, 2007 | Nintendo DS Console
Touch screen's going black.
Your back light for your ds and sp may have went out, unfortunately it is impossible to fix a lcd screen with the black light going out other than buying a new screen and installing it. Sorry.
Aug 22, 2007 | Nintendo DS Lite Console
Nintendo DS Console Logo
23 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
