Question about AOC FT720 (Black, Silver) 17 in.CRT Conventional Monitor
Menu display When I turn on the PC, the monitor menu is inmediately displayed, and there are no way to remove it (the exit button doesn´t work). Help me.
  • Anonymous Aug 06, 2008
    i have the same problem too, my menu keeps on displaying
    how can i remove it?
For me the same but if i press the exit it works and then appeared again what is the problem with this one..
Posted on Oct 24, 2008
Hi, you can change the push bottom of the control user, i am repair various for the same problem
Posted on Feb 16, 2007
Brightness/contrast locked
All computer monitors, whether they are LCD or CRT style, have a built-in feature called the on-screen display (OSD) lockout that prevents users from viewing any images on the monitor. If your computer screen has accidentally been set to the OSD lockout setting, there are several ways you can remove the lockout.
Power off your computer and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in. Power the computer back on and check to see if the OSD lockout message is still being displayed. Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lockout message. Find the OSD lockout heading and read the method that your particular model uses to remove the lockout. Attempt generic lockout removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom of your monitor for 15 seconds and wait to see if the OSD lockout message disappears. Press the "Menu" button again if the lockout message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings. Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lockout.
Mar 02, 2013 | Dell Inspiron 580 Desktop Computer...
Tip
Service menu codes hitachi misc.
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes.
PROJECTORS :
* Press the {MENU} & {RESET} buttons and then press
the {RESET} button again and hold it for at least 5 seconds.
* The Service Menu will be displayed.
* To exit, turn the Projector Off.
MISC :
1.
* Turn the TV on.
* Press the {MENU} {MENU} {8} {SELECT} buttons on the remote.
* Use the {UP} {DOWN} buttons to select items.
* Use the {LEFT} {RIGHT} to change the data.
* Press the {EXIT} button to exit the Service Menu.
2.
* Turn the TV off.
* Press and hold the {INPUT} button on the TV then press {POWER}.
* Hold both buttons until the TV powers on
with the Service Menu displayed.
3.
* Turn the TV off.
* Press {POWER} & {INPUT} buttons on the TV for more than 3 sec.
* The letter "P" indicates picture and "A" indicates audio.
* Press the {EXIT} key to exit the Service Menu.
on Apr 29, 2015 | Hitachi Office Equipment & Supplies
My HP 1730 monitor is showing "OSD Lock Out" message. How can I remove this msg?
The following site has step by step instructions on steps you can try: http://www.ehow.com/how_5008634_fix-lockout-display-computer-monitor.html
I'll paste them below: All computer monitors, whether they are LCD or CRT style, have a built-in feature called the on screen display (OSD) lock out that prevents users from viewing any images on the monitor. If your computer screen has accidentally been set to the OSD lock out setting, there are several different ways you can remove the lock out, depending on the make and model of your particular computer monitor.
1 Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
2 Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
3 Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
4 Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
5 Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out.
Mar 01, 2011 | HP 1730 LCD Monitor
The monitor menu appear suddenly in the display and I can´t erase it.
usually this is caused by having your keyboard too close to the monitor and the keyboard bumps the menu button..
look at the buttons on your monitor itself. One of them should say "menu" pressing that one again should close the onscreen menu. if that doesn't work look for another button marked "exit" or an "exit OR close menu" selection within the menu itself. Use the menu button to get in the menu, use the left , right, up or down to navigate through the menu and usually the "menu OR select" button to make chnages.
Apr 22, 2010 | HP L1706 17" LCD Monitor
My hp 1740 monitor is displaying osd lockout and menu back ond forth and i cant get rid of it
  1. Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
  2. Step 2 Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
  3. Step 3 Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
  4. Step 4 Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
  5. Step 5 fix-lockout-display-computer-monitor-1.5-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep5 span.image a:first').attr('href','http://i.ehow.com/images/a04/or/7q/fix-lockout-display-computer-monitor-1.5-800X800.jpg'); }); The OSD Settings Menu Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out.
Apr 15, 2010 | HP L1740 17" LCD Monitor
How do i do a full reset? I would like it back to factory settings.
Click on Start, All Programs and click HP My Display, Again Click HP My Display and than you can follow the on screen display to reset it.
Also you can use the front panel buttons
Power Turns the monitor on and to standby or sleep mode.
? NOTE: The power button is located on the top or front of the monitor depending on the model.
- Menu Opens, selects, or exits the OSD menu.
-Adjusts the volume level.
-Opens the Quick View menu to quickly adjust settings for gaming, video, photo, and text.
– Navigates backward through the OSD menu and decreases adjustment levels.
+ Navigates forward through the OSD menu and increases adjustment levels.
Auto Auto-adjusts the display
Select Enters the selected option.
Jul 30, 2009 | HP w1907 LCD Monitor
Monitor continuously displays the menu option
click on the monitor menu button and change settings after save and exit.
Jul 09, 2009 | HP mx705 17" CRT Monitor
There are buttons on the front of the monitor. Why
The first button is the E-power button for the Auto preset function.With it you can select presets like text, standard, graphics etc. depending on your use.
When you select any button the options are displayed at the bottom of the window. These tell you what button to press to select the next option.
For example press --menu-- > -- > -- menu , to adjust the horizontal and vertical position.
To turn off the monitor you must press and hold the --circle with the line -- button for a couple of seconds.
Jan 27, 2009 | Acer X193W LCD Monitor
Screen menu displays locked & unlocked
possible faulty VGA Controller board.
Dec 03, 2007 | Gateway FPD2275W LCD Monitor
AOC FT720 (Black, Silver) 17 in.CRT Conventional Monitor Logo
128 people viewed this question
Top AOC Computers & Internet Experts
Raj Patel
Mohammed Ebrahim M
Mohammed Ebrahim M
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
