Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Problem for Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Dirty Water drops behind shampooer
By valerie_puls on Nov 14, 2008
When I use my Bissell Pro 2X it leaves dirty water droplets when I go forward with the shampooer. If you absolutely do not make sure you go over that area it will leave dirty spots all over. Why does it do this??????
Same Problem
Mar 02, 2009
-   Dirty spots of water leaking out of the bottom of the vacuum. Scrubbing heads don't work.  There is very little info out on the web on how to troubleshoot a bissell.  Good work covering it up, Bissell Corp..
This is the second Bissell I've owned and it has broken after three uses.  I'll not buy or recommend another.-   Guest
Solution #1
posted on Nov 25, 2008
Not Rated)
VacExpert
Rank: Guru
Rating: 88%, 41 votes
You are over sudsing your recovery tank. The machine is made to shut off the air flow if water starts to be pulled into the motor, but bubbles want trigger that. So if there are a lot of bubbles in your recovery tank, the get sucked into the motor (Which will destroy it eventually) and then the moisture gets exhausted onto the floor from the motor.
Solutions
1. Use less soap (Read the directions, you may be using too much)
2. Use a different kind of soap (The concentration might not be right for your machine)
3. Use a defoamer (Rug Doctor has a defoamer)
Was this helpful?
Yes
No
Popular Solutions for Bissell 7901-1 ProHeat
Questions and Unsolved Problems for Bissell 7901-1 ProHeat
Do you recommend Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum?
Answer
Answer
When using cleaner water is not ejecting from the tank. Checked and cleaned all, still nogood. Why?... (More)
Answer
I am having problems with my Bissel 7901-1. It isn't working at all. If I remember right it didn't... (More)
Answer
belt assembly diagram. Looking for a picture to see if something is missing holding the belt on.
Answer
I want to clean fluff from underneath the transparent front panel of my Bissell 11 7901. I have... (More)
Answer
my bissell cleaner is not picking up the solution and my my knob to switch it from carpets to tools... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bissell 7901-1 ProHeat...:
Top Vacuum Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Vacuum Experts
Top Vacuum Repair
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
