Question about Hotpoint HSS25GFP Side by Side Refrigerator
No water the water has stopped coming out of the water dispenser. Sometimes in the past it would stop working, then in a few days it would work again. It has now stopped completely! What should I do?
I was having the same problem.  I was told that the water line in the door is frozen.  I was told to open up the door and take everything off door and put towels in front and around the ice maker and the rest of the freezer to keep the cold in and  leave my door open and tape the light switch so it would turn off.  Then keep the door open, for 1-2 hours, I checked it in 1 and it still did not work so I continued for another and it now works just fine.  My ice maker was working but the water was not coming out of the dispenser.
Posted on Nov 18, 2008
    New Friend:
Gypsiediver2 nailed it. Same problem fixed in 1.5 hours.
Posted on Apr 13, 2013
Water and ice dispenser does not work---the switch clicks when you press it but there is not response, also the ice maker just quit working
Three things could be wrong:
Solenoid switch where the water comes into the unit has gone, this control the flow of water into both the ice maker and the water dispenser.
If the switch is good and then you need to check your filters, sometimes inside the door top right. or on one of the corners on the bottom front.. You should be able to unscrew them with you hands.. make sure water is off behind unit or where ever your shut off is at.
One last thing.. check for kinks in the water line behind the unit if it was pulled out lately.
Aug 10, 2015 | LG LFX25960ST Stainless Steel French Door...
There is no water coming from door water dispenser
I don't have a GE side by side, I have a Cafe bottom freezer. Water dispenses from the inside. Occasionally, the water has stopped working. Each time I've replaced the water filter, and that has solved the problem, not immediately, but after a few hours to a day. That's the best suggestion I can come up with, but remember ours is a similar, but not identical, refrigerator.
Jun 10, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Arctica PS123SGNA every fall the water dispenser stops working although the ice maker continues to work. Any ideas??
Strange, obviously the colder days dont effect the ice harvest so water is still coming in, has to be the water dispenser itself or the water filter may be freezing up stopping the flow.
Nov 24, 2013 | Refrigerators
Water won't dispense
Which pump did you replace? Are there a few?
May 13, 2013 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Ice dispenser not working, temperature display off then on
If you pull out the collecor of ice can you then hear and see rotater arm rotating in the back of freezer. If not you need to remove panel and check for voltage at notor and inspect motor.
If you have 120vac and no motion you'll need to replace motor. We have them same day shipping 704-819-6657
Mar 14, 2009 | GE Profile¿ Arctica® Energy...
Water dispenser in my Maytag french door refer has suddenly stopped working. We use it every day and the filter seems to be fine. It almost sounds like it is frozen. Please Help!!!
We have a hd2560 (bot 10/04), french door with inside water dispenser and it had stopped working a year ago, but started working a few months later. I couldn't figure out what happened, but suspected the water line was frozen. I later found out that the water reservoir is located behind the fruit and vegetable bins, so look there to see if the water is frozen.
Two weeks ago, our frig/compressor stopped cooling after making humming/clicking sounds for weeks. Fortunately, Maytag has a 5 yr parts & labor warranty on the compressor, so we were covered. Evidently, there are quite a few faulty compressors out there.
I believe that the compressor had been over-cooling in the past and caused the water lines/tank to freeze. This would also cause frozen produce/fruit. I would immediately contact Maytag/Whirlpool if you suspect a faulty compressor as well.
Oct 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
Ice maker not makeing ice. It slowed over the past few days and now has stopped. Drinking water dispenser still works but freezes up easily.
Normal ice making problem water flow is low ,cheak the machine waterpipe in let line blockage clean the pipe line
Jun 15, 2008 | GE Refrigerators
Bleach and fabric softener dispensers full of water
This is a problem common to virtually all front-loaders. Pull the dispenser drawer right out (it is designed to come right out - you might just need to give it a bit of a jiggle to get it past the stop) Remove the cover/caps from the drawer (sometimes this is a snap-on cover over the back of the drawer, sometimes a top-hat shaped cover over the siphon spigots). Give everything a thorough clean off with hot water (scrubbing with an old toothbrush helps), then reassemble. A.
Jul 16, 2007 | LG WM-2277HW Front Load Washer
Hotpoint HSS25GFP Side by Side Refrigerator Logo
380 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De GO PATS
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
