Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE Oven XL44-#JGBP28BEA7WH
THE OVEN WILL NOT COME ON. THE CLEAN LIGHT BLINKS ON AND OFF WHEN I SET THE TEMP, THE OVEN WILL WORK IN SELF CLEAN MODE, TOP BURNERS WORK FINE, I HAVE REPLACED THE CONTROL UNTIL ON TOP AND HAVE REPLACED THE BOTTOM OVEN IGNITOR. THE PROBLEM PERSIST. THE IGNITOR WILL NOT COME ON AND OVEN WILL NOT LIGHT. DO YOU GUYS HAVE A SOLUTION. THANKS IN ADVANCE. ALSO NOTHING HAPPENS WHEN I PUT IT IN BROIL MODE THE CLEAN LIGHT JUST BLINKS ON AND OFF. BUT SELF CLEAN DOES WORK????
  • Anonymous Nov 19, 2008
    I have the exact same problem
  • pjhillyer Nov 26, 2008
    I have the same problem. Only it happens after the oven is preheated above 350. I had the F2 error code and replaced the sensor, that fixed one problem now I have the clean light blinking and once that happens the oven doesn't keep the temp it was set to.
5 Suggested Answers
SOURCE: ge spectra xl44
It was the igniter. The gas would go higher and then lower. The oven would take an hour to heat up. The new igniter did the trick. Thanks for your help and that link to the new part.
Posted on Mar 26, 2007
aborcass
  • 2651 Answers
SOURCE: Gas GEXL44: Oven does not work
oven never lights , but shows its on,? never heats past 100 deg?? soundslike a bad bake ignitor to me take down the model number and order a bake ignitor, installs on the bake burner, under the floor of oven, with just a few screws and 2 wires.
Posted on Mar 12, 2008
SOURCE: GE XL44 Gas Stove
This Randy again. I checked out the top of the stove as you suggested and found every thing to be ok. Where might the pilot light be located on this ge xl44? this unit is about 13 to14 years old.
Randy
Posted on Sep 18, 2008
  • 23 Answers
SOURCE: The oven of GE Profile range simply stopped igniting
If it is a ge it would have a glow bar ignitor, either a flat rectangle shaped or a round ignitor. That is want the problem is 95% of the time. It is pretty easy to do. The floor of the stove will come right out and it probably has two screws in the back corners you can see. Remove them and the floor will lift out and you can see the burner and the ignitor.
Posted on Jun 20, 2009
  • 715 Answers
SOURCE: I have a GE XL True Temp gas range/oven. None of
your stove must be plugged in for the auto-pilot to work .do you hear a ticking noise when you turn on a burner?
Posted on Oct 07, 2009
XL44 oven. How do you latch the oven closed for self-cleaning...there is no lever.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Sep 07, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a Ge Profile XL44 range/overn but I can't find the manual - how do I use the self clean. I see the button to press but do I take out the racks before I turn it on?
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!!
Sep 06, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a GE spectra xl44 stove model #jgbp28bea2ct, when I turn on the oven the clean light winks and the oven does not heat up. please help
heatman101
Aug 16, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
SELF CLEANING WILL NOT ACTIVATE, GE XL44 MODEL JGBP32AES OVEN
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 09, 2010 | Kitchen Ranges
Ge xl44 self cleaning gas oven willnot come on
heatman101
Feb 20, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
About six months ago, my GE XL44 gas range (purchased Dec 2002) started showing signs that it's not maintaining the oven temp I set. I tried running the self-clean cycle, but that didn't change anything....
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Dec 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I have GE XL44 range. How long should i run self
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!!!
Dec 09, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a GE xl44 gas oven/stove. I cleaned the
Change the Temp sencor for the self cleaning
Dec 05, 2009 | GE Kitchen Ranges
Oven wont turn on.
I tried several times to get my oven to work and nothing seemed to help. After downloading the manual from this site, my husband locked and unlocked the oven door several times very hard and it knocked something in place and now my oven works. I hope it works for you.
Nov 22, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
113 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
