Question about HP PSC 2210xi All-In-One InkJet Printer
Faxing and receiving faxes
I have a dedicated phone line to the hp psc 2210xi and all I want to use it for is to fax, receive fax, and copying. I have the phone cord plugged into slot 1 as per the instructions and it runs into the phone jack. when I try to fax, I hear the machine dialing but I do not hear any dial tones. What am I doing wrong???
  • 44 Answers
Hi, are you using the phone cord that came with your printer? If so, try a different cord if you have one. Can you plug a regular phone into that wall jack - does that work (dial-tone)? Are you using VOIP (like Comcast triple play), DLS or regular analog telephone service? If VOIP you may need to slow down your fax machine settings. Let me know how you make out. Good luck!
Posted on Nov 14, 2008
HOW DO I un-lock the scanner on a Brother MFC 7420?
Unfortunately, the MFC-7420 doesn't have a physical lock switch. You need to turn off the all-in-one and wait for the unit to clear its memory. If the error recurs after you press the power button again, wait 30 minutes and try again. (Note: you will lose any faxes that are in memory. See the User Guide page 11-5 to save this information.) You can find the manual on the Brother support page for the MFC-7420: https://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=MFC7420 . Click on the Manuals & Documents tab. Then click on the Manuals on our Online Solution Center for the English version of the manual. The direct link to the User Guide is currently: http://download.brother.com/welcome/doc000387/ALLFB_UsaEngUsr_B.pdf .
You can also try unplugging the all-in-one for several minutes to reset the error codes. If the error persists, contact Brother if the MFC-7420 is still under warranty (1 year). If it isn't under warranty, consider replacing the unit. The repair costs may be unreasonable.
I hope this helps.
Jan 09, 2017 | Brother MFC-7420 Printer
B&w/gray Scanning Is Okay But Color Scanning Problem
Run ink head cleaner routine. If you cannot the list make and model of printer. Thanks.
Dec 25, 2014 | Office Equipment & Supplies
Why is print quality poor after inserting new ink. Copies are faint and have lines
the cartridge is clogged with ink that has dried and reduced the slit. you need to replace the cartridge with a new one. it happens usually if you recharge the cartridge 3 or 4 times with compatible ink.
May 07, 2014 | Office Equipment & Supplies
Prinnter not printing but showing 'put custom in manual tray'
There is still a print job in the queue. Place a sheet so it prints or kill the job.
Open Printers and Faxes. Open printer. Highlight jobs and Right click > Cancel, or Documents > Cancel.
For those stubborn jobs, Right click My Computer > Manage. Choose Services and Applications > Services > Print Spooler. Right click and stop. Then start. This may have to be done from the Print Server if it's network printer. Contact IT to kill.
Nov 09, 2012 | Office Equipment & Supplies
My fax wont work in my ricoh aficio 1515 mf??
Using the 1515 as a fax machine is a pretty simple procedure if everything works right. All you have to do is hook a working phone line up to the phone jack on the back of the copier (the one labeled LINE, not TEL).
Why won't the fax work? If it is giving you an error message, what is the message?
If you are not getting a dial tone when faxing, unplug the fax from the phone line and plug a working phone in, and see if the phone gets a dial tone. If it doesn't, there is a problem with your phone line.
You can also try plugging the fax machine into another phone line. If the fax works on that line, then there may be a problem with the first line.
Are you having problems sending faxes or receiving them, or both?
Jan 05, 2010 | Office Equipment & Supplies
Problem installing drivers for HP 4355 printer in vista 32bit OS
Vista OEM Cd usually doesnt come with drivers.
Printer should have come with its own cd which contains both the software & drivers.
If it didn't come with any
You can try using windows update
or
downloading drivers from hp site
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&cc=us&dlc=en&product=1138373&lang=en
Feb 24, 2008 | Office Equipment & Supplies
HP printer psc 2210 all in one
Chances are that you didn't lock down the scanner when you moved the unit. You can attempt to open the unit and move the scanner bar manually to reset it. HPs are very difficult beasts when it comes to their power up check out. It must be fully functional...including all cartridges...to work in most cases. Good luck.
Dec 20, 2007 | Office Equipment & Supplies
Samsung kicked out hp 3in 1 printer already installed
Don't have your HP designated as the default printer (if possible)when you hook up the Samsung. When the Samsung is hooked up it sees the HP is the default printer. Well it can't have that, they discard the HP drivers. What does Samsung care about HP drivers theres only one printer port setup and thats the USB port you have them sharing. So yes you need to get a second cable. Tim
Jan 29, 2007 | Samsung SPP-2020 Thermal Photo Printer
HP PSC 2210xi All-In-One InkJet Printer Logo
74 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
