Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Sound but no picture on my HD-52725 (slightly over 1 yr old). The TV menu DOES come up but other than that, it's just a blank screen. I replaced the lamp about 3 weeks ago. It was working fine yesterday but all of a sudden while watching it, it just went out. I think I remember noticing the blinking green light as it was cutting itself off. Thank you for any help you can give.
  • Chad Hendrix Nov 20, 2006
    Okay, I just solved my own problem and since I haven't seen anyone come up with this solution to an apparently simple but common problem, I'll tell you now and maybe it's that simple for you too.
    I simply pulled out the access card on my DirectTV cable box and put it back in....LOL...It wasn't the TV at all. The cable box just needed to be reset. I was on the verge of getting a repairman out here and wasting a bunch of money...So, I've got $400 to spend now, who's up for a drink?!
    Thanks.
  • dodger 1 Dec 21, 2007
    I have a mitsubushi WD 525725 with no picture. I took out the lamp and the bulb was visibly bad, Ordered new bulb and TV worked fine for about a week then started taking longer for the picture to come on. At times as long as five minutes. A few times the red light came on steady and pushing the reset button would do the trick. Then nothing would work so I took out the bulb cartrige and took it to thr nearest Mitsubish approved repair dealer and he tested the bulb and said it was defective. The place I bought the new bulb from is going to send me another one. The manual only says that the bulb is bad if the red light comes on. The first bulb had over 4,000 hours on it but the second had less than 50 hours. The repair shop said that something could have caused the second bulb to go out. what is your comments on this?
    Problem Solver:
  • 5 Answers
The new bulb that went bad I purchased for less than $130.00 from http://www.Discount-Merchant.com/ . When I called them they immediatly sent me a new bulb free. Their number is 1-619-710-2637. A very good coumpany to do business with. They are also considering selling ballast for dlp TV's for around $200.00. The TV repair place that I have been going to told me that maybe the ballast made the bulb go out and it would cost between $600.00 and 800.00 to have them fix it. My TV is a Mitsubishi WD52725. dodger1
Posted on Dec 29, 2007
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Sound, but screen blank
When pressing the menu button on the tv remote does the menu show on the screen. If not likely the backlight is out. The panel is bad. replace the tv. Repair is not cost effective.
Feb 27, 2013 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
No picture
By blank, do you mean a white screen? If you have a white screen and sound, then the LCD panel has failed, either the internal panel or the T-Con board driving it. Only an expect can tell you if it can be fixed. Lots of these sets die within 3 yrs. The cheap brands faster than the better brands.
Apr 30, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Aquos LCD tv no pic or sound on HD tv
The tuner is one board but I wouldn't suggest anyone but a qualified technician to replace it.
Oct 17, 2009 | Televison & Video
Screen has gone blank. Is this common? Fixable?
Contact us to join our group who is taking action for the same issue. dorje@forexcafe.org
Jun 02, 2009 | HP PL4260N 42 in. Plasma HDTV
Black/white checker pattern on screen. Sound okay
Sounds to me that the menu is in convergence adjustment mode. Try the menu key on the remote and follow the prompts.
Oct 21, 2008 | Mitsubishi WD-52725 52". Rear Projection...
JVC i art 32" flat screen
your tv is under shutdown state, there is a protecting circuit that prevent the tv from turning on when there is a short
Sep 10, 2008 | Televison & Video
Does anyone know where can I buy a screen for a 27" LCD Insignia TV. Model is NS-27LCD? My screen creaked. I checked out e-bay and have not found a broken TV with a good screen. Does anyone know where I can buy a screen at.
Thank you all for you time.
JC
Jul 22, 2008 | Televison & Video
Pixalization
Is the TV connected to both the DVD and the Cable box via component inputs? I gather the cable box is a HD box? If they both show up through component try connecting them to the composite video inputs (yellow connections) and see if the problem still shows up.
Feb 28, 2007 | Toshiba 30HFX84 30" TV
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
211 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
