Question about Epson Stylus CX9400 Photo Printer
Printing envelopes Can't seem to load an envelope for printing. Quick guide says to see the on-screen Users Guide. Does not tell you how to access it!
  • Epson Master
  • 541 Answers
Use the software that came with the printer and it will show how to do it
Posted on Nov 17, 2008
How to load envelopes in a canon mg3250 printer
Hi
Please find below a fairly comprehensive guide to using envelopes on your machine
The address is automatically rotated and printed according to the envelope's direction by specifying with the printer driver properly.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif You can only print on envelopes with the computer.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Do not use the following envelopes. They could jam in the machine or cause the machine to malfunction.
- Envelopes with an embossed or treated surface
- Envelopes with a double flap
- Envelopes whose gummed flaps are already moistened and adhesive Prepare envelopes.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif Press down on all four corners and edges of the envelopes to flatten them.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif If the envelopes are curled, hold the opposite corners and gently twist them in the opposite direction.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif If the corner of the envelope flap is folded, flatten it.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif Use a pen to press the leading edge in the inserting direction flat and sharpen the crease.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif The envelopes may jam in the machine if they are not flat or the edges are not aligned. Make sure that no curl or puff exceeds 0.1 inches (3 mm). Load envelopes.
(1) Open the front cover gently, and extend the paper support.
(2) Use the right paper guide (A) to slide both paper guides all the way out.
(3) Load the envelopes in the center of the front tray WITH THE ADDRESS SIDE FACING DOWN.
The folded flap of the envelope will be faced up on the left side.
Push the envelopes all the way to the back of the front tray.
Up to 5 envelopes can be loaded at once.
(4) Slide the right paper guide (A) to align the paper guides with both sides of the envelopes.
Do not slide the paper guides too hard against the envelopes. The envelopes may not be fed properly.
Do not overload envelopes by stacking until the top of the stack touches the paper guides. (5) Open the output tray extension.
Open the paper output tray.and extend the paper output support.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Be sure to open the paper output tray when printing. If not open, the machine cannot start printing. After loading envelopes
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image003.gif Select the size and type of the loaded envelopes on the print settings screen of the printer driver. You may find it easier to download the manual from here
Canon PIXMA MG3250
and install it on your desktop for future reference
Cheers
Nov 13, 2014 | Canon PIXMA MG3250 All-in-One Inkjet...
How do I print an envelope on my Canon MP510?
Envelopes must be fed from the Auto Sheet Feeder. Use either European DL or US Comm. Env. #10-sized envelope.
Important :
  • You need to print from the computer to print on envelopes.
  • Do not use envelopes with embossed or treated surfaces, a double flap, pressure seals, or sticker flaps.
  • Select either DL Env. or Comm. Env. #10 in the printer driver according to the envelope size you are using. If you do not, the address will be printed in the wrong direction.
1 : Retract the Paper Support.
2 : Load the envelope against the Cover Guide (the right side of the Paper Support).
Load with the front face UP and the rear flaps DOWN on the left.
A maximum of 10 envelopes can be loaded at once.
*1 Printing orientation
*2 Make sure the flaps are folded.
Important : Make sure that the Cover Guide is set upright.
3 : Pinch the Paper Guide and slide it against the left side of the envelope.
4 : Press the Paper Feed Switch so that the Auto Sheet Feeder lamp lights up.
5 : Set the Paper Thickness Lever to the right.
In the printer driver, select 'Envelope' in Media Type, and then select 'DL Env'. or 'Comm. Env. #10' in Page Size.
Jun 21, 2011 | Canon PIXMA MP510 All-In-One InkJet...
I've had the printer for about 18 months with no problems. I need to print envelopes for the first time, and can't figure out how to do it. Any help out there?
Load the envelope against the right side of the back paper tray.
Load with the address side facing UP and the rear flaps DOWN on the left.
Set the Paper Thickness Lever to the right, return to the left after finishing printing.
The Paper Thickness Lever is located inside where the paper come out of printing.
Specify the settingin the printer driver.
Select Envelope in Media Type
Select DL Env. or #10 Env.
Select Landscape in Orientation.
Jan 18, 2011 | Canon PIXMA MP470 All-in-One Printer
Where to place envelope.
This should be in your manual complete with pictures.
You can print a single envelope using the photo/envelope feeder. Insert the envelope into the photo/envelope feeder with the side to be printed facing down and the flap to the left.
You can print multiple envelopes (max 20) from the bottom tray. Temporarily remove the top (output) tray. Slide the paper guide in the bottom tray to the left. Load your envelopes to the far right with the side to be printed down, flaps to the left (I like to tuck the flaps into each envelope so they are less easily jammed, but this is optional). Slide the paper guide to the right snugly against the envelopes. Replace the output tray. Start printing.
Dec 21, 2009 | HP Deskjet 6940 InkJet Printer
How do you load an envelope in the printer?
Hi, Please follow these steps to load :-
1.Turn on your printer. Make sure it is in ready mode (green status light on) and it is not printing or running any other operations.
  1. 2.Determine whether your printer uses a top-feed or bottom-feed. Blank paper stands upright in a top-feeding printer and lays in a tray on a bottom-feeding printer.
    3.Load your envelope in portrait mode for envelopes that are 8.5 inches wide (standard paper size). Fold the flap down and place the envelope with the side to be printed on facing you. Load the envelope so that the side with the flap enters the printer first.
    4.Load your envelope in landscape mode for longer envelopes that cannot fit in lengthwise. Close the flap. Load the envelope so that the left side enters the printer first (the flap will be on your left).
    5.Set the paper guides. This guide is the sliding piece on your feed tray (it will usually be on the left). Slide it over so that the paper is held straight when it enters the printer.
    6.Set up your printing preferences. Go to "File > Page Setup" or access your printer’s properties page. Under orientation, select portrait or landscape mode depending on how you loaded your envelopes. If your printer has this option, select “Left” for bottom-feeding printers and "Right” for top-feeding printers
    7.Take a look at the "Print Preview" (usually found under "File" menu) and make sure everything looks good. Then print.
  2. Thanks!
Oct 02, 2009 | Office Equipment & Supplies
I am looking for instructions on loading envelopes
Try the link below, it's to a on-line user's guide for your printer. To the left you should see a list of subjects, just click the one that says "Load Paper" then click on "load envelopes".
http://files.support.epson.com/htmldocs/nx400_/nx400_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Aug 01, 2009 | Epson Stylus NX400 InkJet Printer
I have a Lexmark C510, how do I print a business envelope?
You can load up to 10 envelopes in the standard tray. Try a sample of any envelopes you are
considering using with the printer before buying large quantities. See Loading envelopes in the
standard tray
for instructions on loading envelopes.
When printing on envelopes:
To achieve the best possible print quality, use only high-quality envelopes that are designed
for use in laser printers.
Set the Paper Source in the Paper Menu based on the source you are using, set the Paper
Type to Envelope, and select the correct envelope size from the operator panel, the printer
driver, or from MarkVision Professional.
For best performance, use envelopes made from 90 g/m2 (24 lb bond) paper. You can use up
to 105 g/m2 (28 lb bond) weight for the 250-sheet standard tray or 105 g/m2 (28 lb bond)
weight for envelopes as long as the cotton content is 25% or less. Envelopes with 100%
cotton content must not exceed 90 g/m2 (24 lb bond) weight.
Use only new, undamaged envelopes.
For best performance and to minimize jams, do not use envelopes that:
Have excessive curl or twist.
Are stuck together or damaged in any way.
Contain windows, holes, perforations, cutouts or embossing.
Use metal clasps, string ties, or metal folding bars.
Have an interlocking design
Have postage stamps attached
Have any exposed adhesive when the flap is in the sealed or closed position
Have nicked edges or bent corners
Have rough, cockle, or laid finishes
Use envelopes that can withstand temperatures of 170°C (338°F) without sealing, excessive
curling, wrinkling, or releasing hazardous emissions. If you have any doubts about the
envelopes you are considering using, check with the envelope supplier.
Adjust the width guide to fit the width of the envelopes.
Load only one size of envelope at a time in the tray. Envelopes may only be loaded in the
standard tray. Load them with the flap down and the flap to the left of the tray.
A combination of high humidity (over 60%) and the high printing temperatures may seal the
envelopes.
Loading envelopes in the standard tray
The recommended stack height is 10 envelopes; however, in normal environments as many as 15
envelopes may be loaded. In high temperature or humidity environments, only seven envelopes
should be loaded.
1 Pull the standard tray completely out.
2 Squeeze the length guide tabs together as shown in step 2 on page 42. Slide the guide to
the correct position for the size of envelope you are loading.
3 Squeeze the width guide tabs as shown in step 3 on page 42. Slide the width guide to the
correct position for the size of envelope you are loading. Notice the size indicators on the
bottom left of the tray.
4 Push the envelope stack aid tabs toward each other. They snap into place.
5 Flex a stack of envelopes back and forth and then straighten the edges on a level surface.
Press down the corners to flatten them.
Fan the envelopes. This prevents the edges of the envelopes from sticking together and helps
them feed properly.
6 Load envelopes flap side down with the stamp area and flap on the right. The end of the envelope with the stamp area enters the printer first.
7 Insert the standard tray.
Feb 26, 2009 | Lexmark C510 Laser Printer
Ink smudge on envelope
dvlknc
The paper thickness lever is not on the front...it is on the floor of the "paper output tray" chamber. It is hard to see without directed light.
Refer to Loading Paper section of the Quick Start Guide....p 15 2 Prepare to load paper
(4) Adjust Paper Thickness Lever
(See diagram)
Or look at the "User's Guide on-screen manual" as directed by the Note on p. 17
I really had to search to find this lever while attempting to resolve my problem with a badly aligned printing head. I am going to have to buy a new printer. It definitely won't be a Canon due to the rip off cost of print cartridges.
Hope this is helpful.
kellyplus
Nov 14, 2008 | Canon PIXMA MX310 All-In-One Printer
HHow do I print envelopes on a deskjet940c. What is the set up.
Here is a how-to for the printer, but I'm not sure if you mean the printer, or in a program.
If this is not what you need, let me know.
HP Deskjet 920c and 940c Series Printers - Printing Envelopes s.gif s.gif s.gif
gtabblt.gif Loading a single envelope gtabblt.gif Loading multiple envelopes gtabseps.gif Loading a single envelope Preparing to print
  1. Place the envelope, with the flap side on the left and facing up, into the single envelope slot.
  2. Push the envelope forward until it stops. See Figure 1.
Figure 1: Inserting the envelope c00104463.jpg Printing guidelines
  • Verify that the Out tray is in the down position.
  • Avoid using envelopes that have clasps or windows.
  • Avoid using envelopes that are shiny or embossed, envelopes with thick, irregular, or curled edges, or envelopes that are wrinkled, torn, or otherwise damaged.
Loading multiple envelopes Preparing to print
  1. Pull out the In tray.
  2. Slide out both paper guides and remove all paper from the tray.
  3. Place no more than 15 envelopes -- with the flap side on the left and facing up -- in the tray.
  4. Push the envelopes forward until they stop.
  5. Slide the paper guides snugly against the edges of the envelopes, then push the tray forward until it stops. See Figure 2.
Figure 2: Inserting multiple envelopes c00104464.jpg Printing the envelopes Each software program is different and requires different steps to successfully print envelopes. For instance, in many versions of MS Word, clicking Tools , and then Envelopes and Labels , accesses the envelope-printing feature. Other software programs will differ from this procedure. Consult the Help menu on a software program or User's Guide for instructions for the particular application. Printing guidelines
  • Never place more than 15 envelopes in the In tray at one time.
  • Align the envelope edges before inserting them.
May 27, 2008 | HP Office Equipment & Supplies
Epson Stylus CX9400 Photo Printer Logo
127 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
