Question about Siemens D1675 Motherboard
I put 1gb memory stick first slot no boot up
I just got the right stick for my D1675 a 1g stck
put it in slot 1 still no boot up, I don;t get the 4 beeps
but no boot up still..
  • Siemens Master
  • 4,806 Answers
The bios may not support the bus speed of the ram or they maybe some dirt on the brass contacts, clean these with a standard eraser, make sure its pushed into the dimm slot properly ( you'll hear 1 or 2 clip sounds ) check your motherboard manual to see if it supports the bus speed, if it does put your old ram back in boot windows and flash the bios ( download bios update from motherboard manufacurer's support website ), if you have no ram you have get some and flash through windows, you can also flash the bios via floppy ( THE "FLOPPY" METHOD IS NOT RECOMENDED ) if it goes wrong you'll kill the motherboard
good luck
Posted on Nov 14, 2008
DC7600C memory
As the HP DC7600C it is an older computer, it seems to have a maximum of 3 GB RAM memory. You can mix module sizes, eg a 2MB + 1MB
Jan 31, 2014 | HP dc7600 PC Desktop
I recently purchased Two PNY 1Gb ram to upgrade from original 512mb. When I put both 1Gb ram in the slots, the computer will not boot up. When I take one out and put the original 512 back in with the other...
I don't know your specific model, but some of the Emachines had some memory directly on the motherboard. With the 1Gb and 512Mb sticks installed, boot the machine and report how much memory the system sees. Perhaps the onboard memory is causing you to exceed the 2Gb limit.
Please post the memory size you get here with the above sticks.
Thanks,
Dan
May 12, 2011 | E-Machines W6409 (7234) PC Desktop
I have msi motherboard p4nsli with 1 stick 2gb memory but in booting the memory shows only 512 mb instead of 2gb,..what seems to be the problem & a posible solution for this? Thank you.
Your MSI motherboard may use Interleave RAM. This means you need to insert 1Gb RAM modules in each pair of memory slots.
If your motherboard has 4 memory slots and they are color coded in pairs, then this motherboard uses Interleave RAM. Insert 1Gb RAM modules into the menory slots that have the same color.
May 07, 2011 | Computers & Internet
I am trying to expand memory by inserting 2 PC3200 (DDR400) but total amont of memory size does not changed (still 512 MB) First slot (DDR1) APACER-512 MB Second slot (DDR2) LG Electronics - 1GB
Take the stick of 512 out of the motherboard and insert the 1GB stick in DIMM 1 slot and switch the machine on. If it comes on check whether it has registered it as 1GB. If it has turn the machine off and just put in the 512 stick.
If the machine won't boot up with the 1GB stick then it could be faulty or the motherboard doesn't support 400MHz (which it should).
Regards.
Oct 20, 2010 | Asrock 775VM800 Motherboard
About my ram of p4m800-m7 rev 3.1 i have a 512mb ram already installed and i buy a new ram with a 1gb size and i would like to install it but my question is is it okay to put them together? my 512mb ram is...
The black rectangular chips on the side, or sides, of the ram module are DRAM chips. Dynamic Random Access Memory.
('Chip' is slang term to denote IC, or Integrated Circuit)
Each Dram chip is of a specific size, (or can be said as Amount)
There are manufacturers who make the Dram chips, and then the chips are used by the ram memory manufacturer.
Doesn't matter how the Dram chips are arranged. The ram memory manufacturer could put them all of one side, if they designed it that way.
1.Your motherboard will support, (Use), DDR at 333Mhz, or DDR at 400MegaHertz.
(PC2700 and PC3200, respectively)
2.The ram memory module must use 2.5 Volts.
(JEDEC has set the voltage standard for DDR Sdram at 2.5 Volts, so no worries here. Only time to check this, is if you have some High performance ram, that may be set to use a higher voltage)
3.It must be Non-ECC ram, and Unbuffered.
4.Cas Latency should be 2.5 to 3.0 (Ram Timings)
Short solution?
Computer off, and unplugged from power. TOUCH the metal frame of the computer case to relieve your body of Static.
Handle the ram 'sticks' by the body of the stick, and refrain from touching the gold plated contact pins, on the bottom.
If the 512MB stick is in SLOT 1, remove it. Install the 1GB stick in Slot 1. Make SURE it is seated!
(Slot 1, is the ram memory slot that is closest to the Processor. It is the first ram memory slot that the Processor reads)
Leave the computer case open. (Refrain from putting your hands in while the computer is plugged into power)
Plug the computer into power. Wait 30 seconds. Turn the computer on.
Computer boots up? (Starts)
Okay.
Unplug from power. Install the 512MB stick in Slot 2.
Plug into power, wait 30 seconds. Turn the computer on.
Computer boots up?
You're good to go.
1GB ram memory stick is in Slot 1, and the computer does not boot up?
Incompatible ram memory. Remove it. Reinstall the original 512MB stick in Slot 1.
Nov 26, 2009 | EliteGroup P4M800-M7 Motherboard
When i try to boot my toshiba a75 laptop i receive a boot last good ... it won't boot i removed memory module i installed 2 yrs ago and it boots ... i purchased new memory module and get same error- it...
Below are the specs to the type of memory that can be installed in the A75...it is very specific and cannot be anything else then what is listed. You have 512 mb built onto the motherboard, with one expansion slot. That slot can only hold up to 1 gb stick if the BIOS has been upgraded. Go to Toshiba support and make sure the BIOS on the machine is up to date so it will accept the larger stick of ram memory and make sure all the specs are right on the stick that you have.
Each memory slot can hold DDR PC2700 with a maximum of 1GB per slot.*
  • Maximum Memory: 1536MB
  • Slots: 1 (1 bank of 1)
  • Standard Memory: 512, 768, or 1024MB (512MB non-removable)
  • USB Support: 2.x Compliant
  • Oct 20, 2009 | Toshiba Satellite A75-S231 Notebook
    Adding memory, new total not recognized: IBM Thinkpad R51e-1844
    Ram should always be paired. Same type, speed and size in each slot. You may have 1 SIMM/DIMM/DDR that has 2 sides of chips and the other with 1 which will do exactly what you state. RAM reads across the chips simultaneously. So if you have a different one in each slot it can go bonkers and do goofy stuff on you.
    Jun 14, 2009 | IBM ThinkPad R51 Notebook
    Dell Latitude D600 - RAM not recognized
    One of the DIMMS might be incompatible or faulry.
    Put one DIMM in at a time to determine which is not working.
    If they both work separately then it appears they are incompatible together. Try to get the DIMMs from the same manufacturer, with the same specs.
    Mar 08, 2009 | Dell Latitude D600 Notebook
    Compatability of Memory Upgrade
    DDR RAM needs to be installed in pairs, as in if you have two 1GB sticks these would, in a four slot board, be inserted in slots 1 and 3 or 2 and 4. The other odd 512MB stick could go in any other slot theoretically speaking. But, you would be better off leaving it out. The SPD chips on the two 1GB sticks should match themselves to time at the slowest common or fastest common denominator.
    There is a chance that by having the odd bank population that you said worked for awhile installed as you had, that the MB RAM slots were put under unusual voltage stess. There is a pretty good chance you can remove the 512MB stick, leave the two 1GB sticks in slots 1 and 3 or 2 and 4. But, this is VERY important: consult your board manual or access it online and read what the population requirments are for the slots as in some cases, the two matched sticks go in 1 and 2 or 3 and 4. This little oddity is found from time to time.
    Consult your manual or download it and read how the slots need to be populated and stick with the two 1GB sticks.
    There are memory testing programs you can find for free at majorgeeks dot com and test your RAM once you have it populated correctly.
    In the future, I'd suggest you purchase RAM from Kingston or Corsair directly online as they usually offer a lifetime warranty and this RAM right now for you board is dirt cheap.
    Hope this FIXED, as in ANSWERED you question and was more than helpful. Should you feel compelled to rate this solution after reading, either rate it FIXED or not at all. I know its helpful by default, that's what we do here. But only a thorough answer can FIX your situation. You should be fine if you follow my instructions. But, please consult you manual.
    Regards,
    Worldvet
    Nov 20, 2008 | Computers & Internet
    Cannot Install 2 GIG Memory Upgrade
    you got the DDR 2 RAM right? and wont boot you say means you don have even the power on in the CPU or no display?
    Jun 16, 2008 | EliteGroup GeForce 6100SM-M Motherboard
    Siemens D1675 Motherboard Logo
    215 people viewed this question
    Top Siemens Computers & Internet Experts
    Prashant M
    Prashant M
    john smith
    Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
