Question about Teledyne Laars Laars Lite 2 Pool Heater 125,000 Btu / Propane Gas
Need wiring information
Rats have chewed my wiring on my pool heater. Model EG125 serial #c8048834. Natural Gas.
  • cwilson1316 Nov 14, 2008
    I need a wiring diagram to have it re-wired.
  • 3 Answers
There are wiring diagrams found in the manual at this site:
https://www.parts4heating.com/v/vspfiles/images/pdfs/EPG_EPM.pdf
Posted on May 23, 2009
My pool heater does not run,I turn it on and I get a Flow sign and the pump does not run
It would be a big help, if you assist us who would like to help you! Provide more information, be more specific. What heater manufacturer and which model and are you using natural gas or liqu it would be a big help, if you assist us who would like to help you! Provide more information, be more specific. What heater manufacturer and which model and are you using natural gas or propane?
is it a furnace style heater, or is it a heat pump?
otherwise anybody who decides to assist you, is only guessing.
May 19, 2015 | Pool & Spa
Convert Laars eg125 to LP gas
cannot do anymore company will not warranty should have told them lp if given to you you need to chenge the orfice if available then need to put a regulator on it not a safe move
Nov 27, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
DDTC reads off at all times even when pool is circulating. It usually reads the pool temperature. Also, i don't have a green pressure LED. Can't start the gas heater either.
If you have a control system (i.e...aqualink) controls on the heater should be set to remote. If that is the case and it still gives no temp reading, it is the thermistor (temp sensor). it is very common for rats to chew through the wire.
Oct 13, 2011 | Pentair Minimax NT Heater
Buyer does not ignite after several attempts
Take off the front and see if you can see the igniter come on. It should glow bright red and be easy to see. If not, then your problem could be several other things: Hi limit temp sensor, thermostat, pressure switch, overflame sensor, or even a disconnected or chewed through wire (rodents love to chew on these wires).
If you can see the igniter come on then you have a gas supply problem.
Hope points you in the right direction.
Apr 17, 2011 | Rheem 266K to 399K BTU Swimming Pool...
Blows thermal fuse on raypack heater?
If you are talking about the "Roll out sensor" located on the lower left hand side, you have a problem with ventilation..Soot,debris, or possibly a rodent nest on the heat exchanger (Located just under the top cover of the heater). If it is electrical, you may have a bare wire touching the heaters housing (somewhere inside) causing a short. Rodents love to chew the insulation off low voltage wiring.
Oct 08, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
I have a natural gas pool heater. When I release
Replace the pilot generator. For a quote on the part, send us your heater make and model using the contact form at www.arrowpools.net
Jul 16, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
5 year old Laars 25,000 LX won't ignite.
The low pressure indicator is for the gas pressure not the water pressure. The heater won't ignite because it's not getting gas to the igniter. Check gas supply, if okay, check gas connections, valves, etc.
The 1 HP motor should be fine on the jacuzzi.
May 26, 2009 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Teledyne Laars Laars Lite 2 Pool Heater 125,000 Btu / Propane Gas  Logo
310 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
