Question about Sanyo PLC XU35 Multimedia Projector
Projection issue I turned my Sanyo Pro xtra x mulitverse projector on one day and the image is skewed to the right. The projector is mounted to the ceiling and immovable. I tried thigns on the remote, but got nowhere.
  • 3 Answers
Sounds like you might need to change the KEYSTONE settings
Posted on Feb 05, 2009
Hello Is there anyone who can help. My problem
It's allways best to check your User Manual for any LED signs, go to your providers website, input your device, and download if any manuals for it. there you will find what the trouble is.
i presume that the bulb on your projector has gone bad. hope this helps!
Aug 18, 2017 | Sanyo PLC XU50 Multimedia Projector
We have inherited a Sanyo Pro-X multiverse projector without an instruction manual. The projector was fixed to a ceiling but we would like to use it freestanding. When attempting to use the projector this...
You need to turn off the ceiling mode to get the picture to project correctly. This is in the Settings Menu. See page 37 of the manual which is currently available here: http://cncms.com.au/SANYO-IMs/Commercial-Industrial/plcsw30_im.pdf .
Press Menu. Then use the left/right arrows to move to the icon with the projector and screen shown. (Note: right now this row will be on the bottom of your screen and the icon will be to the left side of the row.) Press the down arrow and move to the Ceiling icon with the R. It should be the seventh icon from the upside down "Up" arrow; it's next to the Capture icon with a camera. (Normally, ceiling icon shows as an upside down R when your image is projected right-side up. There is also a rear-projector icon with a mirror image R when the image is right-side up.) Press Select and then use the arrow keys to choose the On/Off options. You may need to press Select again to save the setting.
I hope this helps.
Oct 11, 2017 | Sanyo PLC-SW30 Multimedia Projector
My dell projector image is at an angle not striaght
hi,
Check it's lense angle & take it in correct angle OR check setings of its angle.
Sep 22, 2009 | Sanyo PLC XU35 Multimedia Projector
Picture dull colours incorrect on sanyo pro xtra x projector
reset to factory default settings (from the menu). after that if it's not where you want them, you can go into the menu and set them to where you like them.
Aug 04, 2009 | Sanyo PLC XU35 Multimedia Projector
Yellowed image projection
The yellow you see is all dust on the mirrrors inside your projector.
If u are lucky you can get the mirrors cleaned by a pro, if you are unlycky as i was, the blue mirror has burn and u need to replace it.
Take your projector to someone who repaire tv:s ot other electronics, they will help you. If its only the cleaning its cheap, if you need to replace a mirror its expensive.
Good luck
Oct 23, 2008 | Sanyo PLC-SW30 Multimedia Projector
HC 1500 skewed image issue
Hi there
I've worked on a few Mitsubishi's in my lifetime and one of their most common problems is the DMD Board that goes faulty and this makes the image go all pear shaped.
If you've only had the unit for 3 months now it should still be under warranty and the warranty covers these kind of repairs.
Hope this helps you !
Mar 26, 2008 | Mitsubishi HC100U Multimedia Projector
Power Point Presentation Using Sanyo Pro Xtra X Multiverse Projector
Don't forget to select the Fn key and F4 on HP laptops. It could also be the Fn key and F8 depending on the laptop brand. It is the apple key and the F7 key on a Mac notebook. On Laptops this will toggle the video to the aux port where the monitor cable connects to the projector. There are 3 modes. video on the laptop screen, video on the laptop and projector, or video to the projector only.
Master Rod
Mar 11, 2008 | Sanyo PLC XU35 Multimedia Projector
Sanyo Pro xtra projector - warning light
We have a similar situation with our Sanyo Pro Xtrax. It will be on for about a hour and then the "warning temp" light would come flashing red, and the project would turn off on its own.
Feb 08, 2008 | Sanyo PLC XU33 Multimedia Projector
Sanyo PLC XU35 Multimedia Projector Logo
305 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
