Question about Sharp EL-2630PII Calculator
Setting time and date on calculator
After I push the clock/keyboard button what happends next. I can't find my manual to do this. Please help. Cheryl
  • lbrenner Mar 11, 2009
    how do you change the date and time on the sharp el2630pIII machine? no manual.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sharp Master
  • 102,366 Answers
You can download the manual from the manufacturer's web site at
http://www.sharpusa.com/~/media/4B2E9C0179BF49A2A85C6EFB9D6ABB40.ashx?cal_man_EL2630PII.pdf
Posted on Aug 02, 2010
How do I set the time and date on a canon p170-dh
Press the Date and Time button on the calculator. It is to the right of the Feed button and has a small calendar and clock on it. To set the date, press the button once to display the factory supplied date and hold down the Equal ( = ) button that is two buttons below Date and Time until the screen flashes. Input the correct date. Ex: August 20, 2010 would be entered on the numerical keyboard of the calculator at 08202010. When finished, hold the Equal button again. Do the same for the time.
To sum it up:
Press Date and Time button
Hold = button until blinks
Enter date or time
Hold = button again until blinking stops
Aug 03, 2010 | Canon P170-DH Calculator
How do you set the time, date, and alarm?
TIME: Depress the time button and hold until digits flash. Push the right arrow until the time shows the correct time.
DATE: Depress the date button and hold until date flashes. Push the right arrow until the digita display the correct date.
You can download the manual below:
http://www.timexaudio.com/pdf/T311IB57574_35.pdf
Please rate this reply if you found it helpful
Jul 02, 2010 | Timex T311T Clock Radio
How to reset the clock?
Push the button with the clock and calendar, this is directly over the 'cost' button, to display the date or time. Then use the 'Time set' button (this is the one for Memory - Plus - Equal). Hold the 'Time set' button down until the first figure blinks then release it. Use the number buttons to change the setting. When you have gotten the correct date or time entered oress the 'Time Set' button again.
Although it is only printed with 'Time Set' the button works for the date just as well.
Mar 30, 2010 | Canon P23-DH Calculator
How do you set the date and time?
1) press calendar clock button
2) hold the time and date button for 3 seconds, this button is marked with "Time and Date" one the keypad and not on the button itself
3) The date or time should start blinking
4) make inputs of current date and time
5) press Time and Date button again to save changes
6) All set!
Anytime you want to display the date or time hit the clock and calendar button. The calc will hold the display until u switch to the calculation mode i.e. by pressing the CE/C button.
DUHHHHHHHH!!! All these instructions are in the piddly sheet Canon calls the manual.
Dec 28, 2009 | Canon MP-25DV Calculator
How do you set the time? and date
Try these steps.
1. turn on calculator
2. push button labeled GT . RATE SET over to the far right for SET.
3. enter the date (i.e. if todays date is 8/10/2010) as 8.10.2010 and press the clock button
4. to enter the time, do the same thing, entering military time.
Hope this helps!
Nov 01, 2009 | Sharp EL-1801P Calculator
Calender
First Remove the clear tape from the battery compartment on the bottom. Second take a paper clip and press and hold the reset button for 5 seconds. Then press the calendar/clock button. Next press and hold the time set button (M+/=) until the first number starts flashing. Type in the date and press time set (M+/=) until it stops flashing. Then press the calendar/clock button. Next press and hold the time set button (M+/=) until the first number starts flashing. Type in the time and press time set (M+/=) until it stops flashing.
Apr 28, 2008 | Canon P23-DH Calculator
Setting date onCanon P23 DHV
I'm not positive because I pushed several buttons just trying to get it set and stay set -- but I think I did the following: fist push the "time set" button, ie the "memory plus" button then push the "format" button, ie the red "minus" button to change the settings -- continue until you have set the date and time -- then when you are finished you have to push the "time set" button, ie the "memory plus" button again to set it in place -- at least I think that's what I did
Jan 29, 2008 | Canon P23-DH Calculator
Canon p23-DH V
Slide the on/off switch all the way to the left to the "Rate Set" position. Now enter the appropriate tax rate. When entered, slide the switch to the desired "On" or "Print" position and CE/C before your first calculation. You should now be all set to go.
Oct 10, 2007 | Canon P23-DH Calculator
How to set the time and Date-Step by step please
I found this and it seems to work Solution #2posted on Nov 17, 2006 By greeneyes Rank: Guru Rating: 94.81%, 27 votes on the bottom of your calculator is a reset button, with a paperclip or a pen press that button. Then, press the calendar, clock key. next, press the equal sign key until the date is flashing type in the date using 11172006. press the equal sign again and the date is set. Next press the calendar, clock key again the time should show up (12-00-00)press the equal sign again until the time starts to flash. enter in the time using 0903 (9:03) press the equal sign again. Time is set. to display the date and time when not using the calculator, press the calculator, clock key 2x's. to go to compute mode press the red CE/C button.
Sep 03, 2007 | Canon P23-DHV Calculator
How do you set the clock/calendar on the Canon MP25DV?
Nov 04, 2006 | Canon MP-25DV Calculator
Sharp EL-2630PII Calculator Logo
144 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
