Question about Mitsubishi WT-46809 46" Rear Projection Television
Still no HD quality
DirecTV installed a new 5 LNB satellite dish as a free upgrade. The tech had a test set & tested the cable where it connects to the reciever. Good signal there. He wants me to upgrade to the HR20 reciever, but I am under the impression that that will only give me the local channels in HD. I still see no difference in quality when comparing TNT & TNTHD. I'm starting to believe that the TV is not HD compatible, although Mitsubishi markets it as such.
TVtechmaniac
  • 140 Answers
SOURCE: Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Posted on Aug 25, 2007
  • 1153 Answers
SOURCE: WS-55809 HD1080
Nothing but a HD signal!
Posted on Nov 30, 2007
  • 7 Answers
SOURCE: HD Hookup on Dish Network 2nd Location
In order for you to receive HD broadcasting you must have a HD-TV, otherwise you wont get the picture in HD. Also I should point out that you need to make sure that the signal itself is being broadcast in HD.
Posted on Jul 19, 2008
SOURCE: I have a Mitsubishi HD 1080 series 65" set. I just got digital cable and I can get HD channels but it only shows in 480i. When I go to menu on the tv to advance settings if gives the option of 480i an
Connect your component cables to the DTV connections.
Posted on May 01, 2009
rulds2008
  • 3866 Answers
SOURCE: Tv goes off, then comes on, and volume goes to max
OMG! Verizon Fios at it again with changing boxes! Well let me tell you if you do not loose signal on a DVD using these same inputs ITS NOT YOUR TV!
Whats going on is further into Verizon system you loosing the signal from the VDSL slam outside in the pill box. This thing will need to be replaced and they are going to blame your TV until you just give up and buy a new TV only to figure out its not your TV.
1. Call them back
2. tell them to check there network
3. if that dont work tell them to check it again
4. if you have HDMI use that instead of the scart connections.
I hope you have luck with Verizon Fios there internet rules but there TV service is sub par!
Thanks
rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jul 17, 2009
TV picture not clear
First we need to know a little more details about the kind of TV you have, the kind of service (Cable, Satellite or off Air).
Comparing showroom to your home is also something we need to know. Was the showroom using Cable or Satellite. Satellite will always have a better picture quality wise.
If you are using composite input for the signal path between TV and source this would not produce a High Dif picture Composite = Yellow for video, red and white for audio. If you are using Component source that will produce a HD signal cable is RED/BLUE and Green with different audio.
The best quality is using an HDMI cable, this is all in one cable and the sources is the best. One last thing, if you are using the RF *cable as source it will not give you a quality signal.
Apr 22, 2014 | Intellian i9P US HD System with 85cm Dish...
No signal on my starview s2828+ box
Three things here the unit the cable or the LNB.
Simple things first Cable
1.cable
Check the satellite plugs on Both ends are correctly fitted and there is no shorting of the core central cable and the shield. Check the cable with a meter put a loop( connect core to shield at one end) on the other end and check resistance.
2. Unit
Check your unit with a know good setup a friends perhaps.
3. LNB the unit on the arm of the dish
You should be able to get a signal from the LNB with a alignment meter. or replace with known good to test
hope that helps
Dec 06, 2013 | Televison & Video
Can't get to correct channel for satellite reception
Use the menu button on the face of the receiver. Go to settings-satellite-signal strength-view signal meter. At that point, if your readings are zero, it's one of of four things: misagligned dish, defective LNB, defective cable/fitting, defective receiver.
Aug 21, 2012 | Emerson EWF2004 20" TV
We have an old dish network dish and LNB with a new dishnetwork receiver. When we can get the signal up to 5, the screen goes blank and we cannot lock the signal in. Diagnostics state there is no...
Hi mfpayton with the install of the brand new receiver wealways want to make sure all connections are tight. And after all connectionsare hand tight we will need to run the Check Switch Test. It will provide thestrongest signal to your home and you will see the signal move up into the 65percent range. If after the Check Switch Test it still is a low signal we mayneed to check the connections from the Dish and LNB that is an issue we wouldneed to come out on. I will leave the link to show you how to do the CST.http://www.dishnetwork.com/SupportSection/complete-sig-loss
Mike Houston of DISH Network Executive Office
May 02, 2010 | DISH Network 322 DTV Receiver
How do i fit a dual LNB so i can change channels
HELLO
A word of warning! Do not attempt to split any feed coming from a single output LNB to another satellite box - you will be asking for trouble!
Now for the solution. If you are using a standard sky minidish you will need a 40mm adaptor kit, a dual output LNB and another length of satellite cable (Webro WF100 prefereably) but I suppose RG-6 will do the job providing it is not too long (around 10-15 meters or so) a couple of F connectors and self-amalgamating rubber tape.
Power off everything! Remove the old LNB and to do this you'll notice a plastic rivet on the LNB arm of the dish which must be removed. When you have done that and the new LNB is place (don't tighten everything yet), connect your current length of cable to one output and the new length to the other (finger tight should be fine) and make sure BOTH of your boxes are connected. Remember to waterproof those LNB connections.
Power on! You should be getting pictures - if not the LNB will need skewing round a bit. Look at the dish from the front and turn the LNB in a clockwise position say the 2 o'clock position - that should do the trick. Then tighten everything.
I wish you well with it - good luck! (:-)
Sep 20, 2009 | Televison & Video
Set Up for DVR
Hello: If you have only one incoming cable, just hook it up on SAT 1. What happens is that you will only be able to record what you're watching. If you want two incoming cables, just change the LNB to a dual LNB if you have a round dish. If you have an oval dish, most likely has a multiswitch LNB, so all you need to do is hook up another cable to that LNB and run it to the receiver and put it on SAT 2.
This way, you can watch one program and record another program on a dif. channel at the same time. Either way, you need to take out the LNB from the dish for one or the other option. It's best to contact your service provider and get a tech, to do the changes. It's not costly.
Jan 16, 2009 | Samsung SIR-S4040R DirecTV DTV Receiver /...
Satellite dish receiver error LNB Drift detected
that's not true i work for dish network if u have an LNB drift of -8 or +8 you can get a free lnb service call and they can come out n fix at no charge
Apr 22, 2008 | DISH Network 301 DTV Receiver
Directv Samsung problem
I also have directv.At this point,it is a video signal issue on their end.The up conversion is ok at best.Depending on the original video that is probably as good as it gets.The other problem is the wow factor from hd.It is hard not to be critical of the non-hd channels.
Mar 02, 2008 | Televison & Video
Mitsubishi WT-46809 46" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
