Question about Belling 351 Electric Kitchen Range
How to set timer/clock on belling 636wh cooker
The oven will not work until clock/timer is set from auto, but how is this done?
  • Anonymous Dec 23, 2008
    I need to set the clock and clear from auto for the oven to work.
  • 13 Answers
SOURCE: User Manual for Belling Electric Cooker
The clock is flashing zeros because you need to set the clock timer.To do this you need to press and hold in both of the the cook period and end time buttons together, then with both buttons still held in , press either the "+" or "-" buttons to set the correct time of day
Posted on Apr 21, 2009
  • 1462 Answers
SOURCE: belling db3 duel fuel cooker
they just pull out but need a fair bit of force
Posted on Apr 24, 2007
  • 7 Answers
SOURCE: Oven not working! Belling 614 format
the control modual is bad the oven want work without it
Posted on Jan 10, 2008
IB4G2008
  • 3587 Answers
SOURCE: HOW DO I SET THE
press clock..enter the time, press enter, then clock again..should flash..after 5 seconds
Posted on May 28, 2008
SOURCE: need to set clock on my cannon chichester oven
Go to www.cannonservice.co.uk/hs/pages/manual/manualSearch.do you should find your model there. Terry.
Posted on Jan 31, 2009
I have just baught a second hand belling double oven cooker, we have switched it on and the timer is constantly buzzing! And the top oven and grill don't work! Any ideas on wot could b wrong?
The timer has been set and the cooking time is finished. That is why it is buzzing and the oven is in a turned off state. You need to acknowledge the cooking time finished, and set the oven back to Manual operation from Automatic. In the old days you pressed one of the buttons by the clock that was used to set. I used to have a Belling Double Oven in the UK, but I can't remember about the timer.
Google
make model manual
Google
Dec 19, 2016 | Belling Ovens
I have an old belling farmhouse cooker the hob works fine but the oven isn't igniting manually or by the electric ignition The timer is manual and is stuck on the red patch I can't seem to shift it ...
Take the tiny screws of there are loads down right hand side then release screws on hob once you can lift hob plates up. Undo the covers on back of timer clock control . Make sure you un plug from mains . Take the neutral of back of timer clock. This will allow your oven to auto ignite again
Jan 07, 2014 | Belling FarmHouse 931 Gas Kitchen Range
Twin ovens stopped working
Hi, Have you altered the time clock on the cooker? It is possible that the clock/timer is set for 'Auto'
Dec 26, 2013 | Caple Ovens
I have a Belling 335 everything still works apart from the actual oven part? What could this be and is it fixable??
check your timer,if it has a programm set(by accident)the oven will not work until this has been cleared,if your not to sure then switch cooker off at the cookers main switch on the wall.leave for a few mins and switch back on this should clear any set programm,good luck.
Nov 13, 2012 | Belling 335 Electric Kitchen Range
For some reason my cooker keeps switching itself off, unless the timer is set to 12:01 it does this. It used to go off when the timer counted down to 8 mins, but this varies, and now it has a mind of its...
It sounds like you are setting a cooking time instead of setting the time of day. The oven wont work until a time of day is set. press the centre button (4x)until a red light flashes in the bottom right corner of the clock if you miss it keep pressing until you cycle through to the rh corner(note clock symbal) press + or - until you get to the right time leave for 12 secs then time locks in and your oven will work. the other flashing lites top left= cooking time bottom left =end time top right =timer function with no oven control. If this does not solve it the timer is faulty and requires replacing. good luck.
Oct 31, 2010 | Electrolux Insight EKC6049X Stainless...
Cooker clock requires resetting
You need to press 2 or more of the timer/clock buttons in seqeunce to cancel the auto setting.
The sequence of buttons varies according to the make of cooker, so just keep pressing the buttons until you hit the correct sequence.
Hope this helps.
Jan 06, 2010 | Ovens
Oven will not switch on
If there is an A only on the clock(no other digits) your clock has failed. Either replace , or can be bypassed. Oven won't work without clock set.
Dec 14, 2008 | Smeg SE250XUK Stainless Steel Electric...
Aug 21, 2008 | Kitchen Ranges
Belling Format cooker
I found the following information useful, although it wasn't a belling cooker the controls appeared to be the same. Go down to the electronic timer section. http://www.prestigeappliances.com.au/owner's-manual.shtml
Oct 29, 2007 | Belling XOU482 Electric Double Oven
Belling 351 Electric Kitchen Range Logo
515 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
