Question about Metrologic Instruments MS 7120 Orbit (mk7120-002) Handheld
Scanner not reading
I just got an Orbit scanner with Keyboard wedge interface. Upon connecting it to the PC. The test beep is heard. After that the lasers can be seen blinking. But the scanner is not reading any codes. Not even the programming codes. I can not get further than this I do not know any other way to program the scanner but by scanning barcodes. I downloaded the programming software, but they only refer to rs232 interface. How can I fix this ? Oh yes I tried more than one computer with no luck
2 Suggested Answers
  • 18 Answers
SOURCE: Locked Metrologic MS9520-37 (keyboard wedge) after unintentional programming
You programmed it for usb interface, but the scanner is keyboard wedge. Try pointing the scanner at the "recall defaults" barcode in the manual as you plug the scanner back in.
Posted on Apr 02, 2009
How do I connect the main unit to the front end?
Which main unit to Front end of what?
Sorry to say,but your question is not very clear about which product you need support.
Thus, please give some more detail on your product whenever you ask any support so that the experts can search the exact products and provide better support as there are hundreds of similar products in the market.
Please give exact Make and Model number of your product and also some more detail on your problem so that we could identify your issue better ant give appropriate solution.
Thank you.
Aug 24, 2011 | Computers & Internet
I wish to connect a bar code scanner to my Keyboard Display Unit for inputting data when printing labels. Can you provide information relating to pin outs, protocols and how to set this up? Thanks
By Keyboard / Display unit I'm assuming your using a PC, thin client or dumb terminal. If you are using a PC then the easiest way to do this is to get a bar-code scanner with a USB interface, no programming should be required with possibly the exception being of adding a "Enter" (CR LR) after each scan.
If you have a dumb terminal then you may need to look at trying to use an RS232 connection (if one exists) or a keyboard wedge solution where the scanner is plugged into the keyboard port along with the keyboard.
In any event pin outs would vary depending upon the scanner you want to use and the device you are connecting the scanner to.
Hope this helps
mikeo@acebarcode.com
Mar 02, 2011 | Zebra Eltron LP 2824 Thermal Printer
Scanner beeps but doesn't enter data into system
Have you scanned the configuration barcodes on the manual? For example if you are using keyboard wedge cable, you will need to scan the keyboard wedge barcode from the manual. Page 20.
http://www.handheld.com/download.aspx?download=/data/ffdefe60-2c7a-423f-a204-ee2450b7c4d9.pdf&filename=IT3800PDF+Linear+Imager+PDF
Apr 02, 2009 | HHP IT3800 Handheld
Can't install Symbol LS2208 barcode scanner on a PC (Wedge cable)
You will need to scan the barcode that configures the LS scanner to use keyboard wedge or even the set all defaults barcode. You will be able to find both of this on the product reference guide that you can download from www.symbol.com in the support page.
Mar 14, 2009 | Symbol LS2208 Handheld
Scanner doesn't turn on
Hello Loverboy,
the scanner turns on automatically as he he receives power from the host interface.
Please check the cables and connection. For RS232 interface would you need an external power supply. USB can power the scanner without external power supply. By Keyboard Wedge installation please connnect also the Keyboard.
Nov 09, 2008 | Symbol LS2208 Handheld
Symbol LS 4000i scanner issues
Hello, it looks like the scanner lost the settings. As power is there, so connection is ok. The several (four) beeps after reading the barcode means communication error.
Please try to find the original sheet with configuration barcodes or download it from support.symbol.com website, you would need to scan the barcode for IBM PC/AT & IBM Compatibles from Keyboard Wedge Chapter.
Aug 25, 2008 | Symbol LS 4000i Handheld
Feb 12, 2008 | Metrologic Instruments Voyager MS9520...
Need driver software
hi first you need to know what the interface is then if its keyboard wedge programme for keyboard emulation. if its serial you will need some type of pos programme to run it in if its usb it should be plug and play hope this helps 2dornot2d
Sep 18, 2007 | Metrologic Instruments Orbit MS7120...
Metrologic Instruments MS 7120 Orbit (mk7120-002) Handheld Logo
52 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
George Etukudo
George Etukudo
Daniel Dollive
Daniel Dollive
jackcity
jackcity
Level 1 Expert
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
