Question about Husqvarna Viking 1
Sews only in Reverse
Runs only backward. Reverse switch seems to be stuck.
  • 19,396 Answers
  • Ginko
    Ginko Nov 14, 2008
    First check thestitch pattern.
    When you use a buttonhole stitch or a stretch stitch the machine will sew backwards.
    Ensure the length is set to
    the right of 0 and that it is not in stretch stitch mode or buttonhole mode.
    If the machine is still only working in reverse, then it is likely that it is stuck in reverse and needs to be repaired by a technican.
Metal moving forward but sews backwards
Make sure the Reverse function on your machine is not stuck.
Mar 07, 2017 | Sewing Machines
Singer simply 3116 is stuck in reverse
That indicates that either the cam controlling it or the stepper motor controlling it is stuck. You're going to need it serviced to fix it.
Sep 07, 2014 | Singer Sewing Machines
Sews backwards..when I press the reverse button it sews forwards
Sounds like you have the timing precisely reversed. Time to try again.
Sep 10, 2012 | Singer CE-100 Futura Computerized Sewing...
My "new" elna type 722010 only sews in reverse.
What is the stitch length lever set to (4 in the diagram below)? these models have a lever that slides from positive to negative (ie) reverse, so you need to set it to the positive area, between 2 and 3 above zero. If you move it below zero then it sews that stitch length backwards.
If this machine is new to you, you might want to join the yahoo group called "Elna Heirlooms" there is lots of helpful members who share info on these old machines there.
Jul 15, 2011 | Elna Sewing Machines
My husqvarna classica 90 sews backward instead of forward. Can you help with an answer why?
Make sure the stitch selector is not set on buttonhole. If the machine has set up for a long time not being used it may be that the stitch length is stuck in reverse.
Apr 19, 2010 | Sewing Machines
Will only Sew in reverse.
Could be several things -- motor hooked up backwards, reverse is stuck, etc. Is there a Reverse on the machine? If so, what happens when you activate the reverse. If it then sews forward I would say someone hooked the motor backwards. If there is no change, it would be a problem with the feeding motor or the circuit board. Suggest taking to a reputable service center for analysis. Good luck.
Feb 01, 2010 | Husqvarna Viking 1
Backward stitching
Knowing which kind of machine you have helps alot. Just guessing but maybe the reverse mechanism is stuck and needs some oil in it to free it up. Or the buttonhole mechanism is stuck in reverse part of it.
Probably you should have it looked at.
Dec 31, 2008 | Singer 3116 Simple
Reverse Switch Control on my Kenmore Sewing Machine
My back swith button is not working on my Kenmore sewng Mchine. Can you tell me what the problem is?
Aug 25, 2008 | Kenmore 15516 Mechanical Sewing Machine
Machine sews only in reverse
Be sure you are in the correct stitch pattern...if you are on a buttonhole stitch or a stretch stitch it normal for the machine to sew backwards. Be sure your length is to the right of 0 and not in a strtch stitch model or buttonhole mode.
Bonnie
Jul 28, 2008 | Kenmore 15218 Mechanical Sewing Machine
Sewing Machines Logo
49 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Derek Massey
Natasha Subko
Level 1 Expert
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
