Question about Gateway Computers & Internet
I would like to restore my system. i do not know how to start it
Click on start, all programs, accessories, system tools, system restore,
once u open system restore, click on next, select a date to which u want to restore the system and click on finish, system restore will happen and system will restart, if successful it would show the msg system restore successful
Posted on Nov 14, 2008
    Master:
  • 568 Answers
Its easy click on start go to accessories, then to to system tools and the u will find system restore
GETTING A POPUP "SYNC HAS STOPPED WORKING IN WINDOWS
If you could know when the issue first occurred, let us perform a system restore.
System Restore
1) Before we start, please close all open files and close all open programs.
2) Click Start; click All Programs; click Accessories; click System Tools; and click System Restore. The System Restore user interface should appear.
3) Click Next.
4) From the restore points available, select an appropriate restore point before problem occurs and click Next.
5) Click Next again. The restore process will run and your system will restart automatically.
Nov 12, 2013 | Microsoft Windows XP Professional for PC
Skype fatal error
What sort of error ? are you able to start your computer ?
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue and
work your way through the problem
if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occurred
or click start type in event viewer press ENTER
you might be able work your way through the problem
or
you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System
Configuration utility Installation restore points that occur before you install a program or a service
you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
If the problem is hardware related the system restore might not work .?
Sep 25, 2013 | Skype IM
Well i start up my comp and errors pop up i dont know how to fix
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 11, 2013 | HP Pavilion dv6000z Notebook
Starting problem it is asking me retstart some it dnt starts
Feb 10, 2013 | Computers & Internet
My computer want start and every times I starts it it say error and please restart
Feb 04, 2013 | Computers & Internet
I want to rest my averatec laptop because it has to much memory on it and I dont know how.
When you start your laptop, when it shows the BIOS screen, there may be an option "System Restore". If you have the CD that came with your laptop, you can run system restore from there. Or, if there are restore points that have been created in windows, you can start system restore and choose an earlier date to restore windows to.
Jan 15, 2011 | Computers & Internet
I accidentely deleted my web camera and when i try to open it, it says that: This application has failed to start because Image.dll was not found. Re-installing the application may fix this problem. but i...
You need to tell me the Operating System?Is that an Inbuilt Camera, you are referring to?
Also, in the mean while try to below Trick :-
System Restore
If you are using XP,the procedure is :-
To use System Restore to restore Windows XP to a previous state, follow these steps:
  1. Log on to Windows as Administrator.
  2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts.
  3. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next.
  4. On the Select a Restore Point page, click the most recent system restore point in the On this list, click a restore point list, and then click Next.
    Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
  5. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
  6. Log on to the computer as Administrator. The System Restore Restoration Complete page is displayed.
  7. Click OK.
If you successfully restored your computer to a previous state, and the computer is performing as it should be, you are finished.
Let me know with all details. Do Use System Restore before we look for the application.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 26, 2009 | Acer Aspire 3610 Notebook
"restart the computer"
This time after you uninstall the norton antivirus, it's been corrupted your VGA Drivers & etc., I don't know what else have been corrupted after you uninstall.
All you have to do is restore the system or system restore.
If you enter at Windows Safe Mode the restore using checkpoints on your system.
If not then reformat you windows.
Here are the tips on how to use system restore.
Using System Restore To start System Restore, click Start, Programs, Accessories, System Tools, System Restore. You'll see options allowing you to create restore points and restore your computer to a previous time. If you've already performed a restoration, you'll see a third option to undo the last restoration.
system_restore_welcome_thumb.jpg To create a restore point:
  1. Choose Create a Restore Point and click Next.
  2. Type a descriptive name for the restore point in the Restore Point Description (the date and time will be added automatically) and click Next.
  3. Click OK.
create_restore_point_thumb.jpg To restore your computer:
  1. Start System Restore, choose Restore My Computer To An Earlier Time, and click Next.
  2. In the calendar, choose a day (those with restore points are bolded) and select a restore point, then click Next.
  3. Make sure your files and programs are closed and click OK, then Next.
  4. Wait while the restoration takes place. You'll need to reboot your computer. If you encounter problems after rebooting, reboot once more.
If you find you need to undo a restoration:
  1. Start System Restore.
  2. Select Undo My Last Restoration.
  3. Close any open files or programs and click Next.
Hope this will you and good luck!
If i am helpful please rate me.
Thank you.
Yboyandrei
Aug 15, 2009 | Symantec Norton AntiVirus 2009 - 3 User...
Laptop keyboard has stopped working
Use system restore to restore your PC back to a date before you began having virus problems.
Start Menu -> Programs -> Accessories -> System Tools -> System Restore
When you start System Restore, it will ask if you want to restore to an earlier time, choose a date from before the virus problems started and follow the prompts from there. Your computer will restart, the restore process usually takes 5-15 minutes and then your system reboots.
Let me know if this works for you.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 15, 2009 | HP Pavilion dv1000 Notebook
Rebooting windows vista back to when i first got without a disc
You might try system restore option and restore it to a date you know it worked well
1.
2.
On the Welcome screen, click Restore my computer to an earlier time, and then click Next.
3.
On the Select a Restore Point page, select the date from the calendar that shows the point you'd like to restore to, as shown in Figure 2, and then click Next.
Figure 2
4.
On the Confirm Restore Point Selection page, verify that the correct restore point is chosen, and then close any open programs.
5.
Click Next if you are ready to proceed or click Back to change the restore point.
6.
The computer will shut down automatically and reboot. On reboot, you'll see the Restoration Complete page, and then click OK.
After reviewing the stability of your system, you can choose another restore point or undo this restoration. Just open System Restore and make the appropriate choice. After you use System Restore, you'll have an additional task, Undo my last restoration, on the System Restore Welcome page. Remember that you'll have to reinstall any programs that were installed after the restore point.
If System Restore doesn't work in Normal Mode, it might work in Safe Mode. To use System Restore in Safe Mode, press the F8 key during reboot and choose Safe Mode. When your computer starts in either Safe Mode or Normal Mode, System Restore can be used to capture a working previous state. System Restore can't be opened unless the system is bootable into one of these modes.
Oct 22, 2008 | Computers & Internet
Computers & Internet Logo
205 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
