I re install my windows xp and after half of my hard drive are missing before it was 450 GB and now i see only 255 GB
    Sergeant:
  • 207 Answers
Problem123,
This is an addressing issue from the 1st generation of Windows XP it can only Identify THAT much of the Hard drive. Because thats all the index addresses it can utilize for the drive sectors.
While that sounds confusing the solutions are simple
Solution number 1: install Service pack 2 or 3
Solution number 2: Get partitioning software and partition the drive (Partitioning is basically telling the computer to view the one hard drive as two or more depending on how many partitions you set)
Hope this helps you,
Dave
Posted on Nov 14, 2008
    Master:
  • 568 Answers
Have you created partitions before installing XP?
if not then i request you to please first create partitions the way u want then try installing xp
HP xw 4400 will not recognize my hard drive when trying to install OS Windows XP Prof.
Windows XP had a hard time recognizing hard drives larger than 127 GB. The best solution is to install Windows XP with service pack 2 or 3 already slipstreamed. Otherwise, you are going to have to partition your hard drive with at least 1 partition of 127 GB or smaller.
Dec 08, 2012 | HP xw4400 Workstation PC Desktop
I have one problem this is my computer it have not System softwear then what shall i do?
Have you formatted your hard drive? DO you have an os installed? If not, look at installing windows or linux.
Dec 05, 2012 | Dell 341-7901 450 GB SAS Hard Drive
I have a Assembled Computer with Processor Intel Dual Core (R) @ 270 GHz, 3 GB of RAM equipped with Microsoft Windows XP Professional Edition version 2005 service Pack 3 with Wi-Fi Netgear 108 Mbps Lan...
yah you must buy a Y-USB cable for your external hardisk. this is connection both ends are one is for hardisk and the other two cable is for USB slot of computer. why it two wires connection to usb because one wire is for Data and the other is for Power. If doesn't work..it might be a problem in your Operating system. i recommend to you to reinstall your Windows OS.. theres a 4 reasons why it happen appear the error... deffective USB cable..corrupted driver of USB device for seagate, virus infected of your systems..and maybe your hardive is deffective. Please rate if this is HELPFUL..thanks
Aug 22, 2010 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
On my GT5220-(Athlon X2 64 3800,4G'S RAM)--I HAVE THE STOCK 250GB HDD/IDE THAT IS RUNNING XP-32 BIT,AND I AM TRYING TO ADD 500GB SATA HDD THAT HAS WINDOWS 7 ULTIMATE 32BIT UPGRADED FROM XP VER. EVRYTIME I...
ok get a windows 7 disk and turn of the computer and ad the hard drive switch on the computer and set it to boot from disk (seems windows is broken on the 500gb hdd) then boot from disk and install windows 7 to the 500 gb hard drive and set in the bios the boot select for the hard drive (if you use win xp more then make that boot primary) then go threw all the rigmarol of installing windows 7 to the 500 gb one and your done it will have bootable hard drives and will offer a choice when first switched on
May 15, 2010 | Gateway GT5220 PC Desktop
My 250 gb hard drive is only showing capacity of 127gb
Firstly install SP3 if that doesnt work you need to update your bios to get large disk support. If you dont want to perform any of these fixes you could simply split the drive into 2 or more partitions to access the full 250gb. Goto Control Panel/Computer Management/Disk Management you will see in there the missing gb's of your drive. Simply right click it format it and give it a drive letter.......Cheers from Scott
Apr 18, 2010 | Microsoft Windows XP Professional SP2
Missing GB after unpartitioning hard drive
please goto start>control panel>Administrative Tools>Computer Management>storage>disk management . Here you will find all unallocated space and allocateds too. please make those unallocated spaces new partition.
surely it will help you.
Rate me if it helps
Apr 18, 2009 | Maxtor Hard Drive
Dell inspiron 8100 notebook
You may need to try installing windows xp. I had a gateway that had a brand new hard drive and wouldn't take 98, but installed xp flawlessly. Look at the computer and see if it says designed for Windows XP
Jan 20, 2009 | Dell (0K724) for Inspiron 8100 40 GB Hard...
Missing hard drive space
Simple problem you made the partions using FAT 16 file system and 80 GB cannot be partition using win98 10 will limit the disk to 10 GB.
Remove all Partions And Use Windows XP to create partition during Installion.
Fix Ya
Best Of LUCK.
Jan 07, 2008 | Computers & Internet
I Lost 20gb from my 160gb harddrive
Hi, you aint lost 20gb. 1mb is 1024 1gb aint 1000mb for a example i have a 40gb hard drive here, it displays 34.3gb 200gb hard drive is usually 186gb its normal dont worry. :-) all the best John
Dec 17, 2006 | Samsung SpinPoint P80 SP1604N 160 GB Hard...
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
