Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Samsung self focus
The self focus on our tv is not working so leaving the picture fuzzy
  • Anonymous Jan 16, 2009
    I have shadowing of colors. I need to sharpen pics.
    Problem Solver:
  • 10 Answers
Posted on Nov 19, 2008
No codes on the remote control to configure the self focus
Codes for Samsung are: 0105 0077 0076 0109 0007 0009 0004 0005 0085 0172 0942 0358 0012 0015 0080 0104 0106
Sep 18, 2012 | Televison & Video
Picture out of focus. type or subtitles are fuzzy Have tried all picture adjustments in "menu"
As the CRT (picture tube) weakens the electron beam will loose some of its intensity. This will cause the beam to become a little wider, and thus the scanned picture will look softer or out of focus. Most of the time, the corners, top, and bottom tend to start getting worse than the center.
Sometimes the focus bias can be cheated a little. Some models of TV sets have a focus pot on the CRT circuit board, or on the high voltage multiplier. This control works in a high voltage area. I suggest you get experienced assistance for this. If you take the TV set over to a local TV shop or find an experienced tech, he could try to adjust the focus for you.
Considering the age and type of set you have, you would be better off getting a new up to date TV set.
Jerry G.
Sep 26, 2009 | Samsung TXJ2554 TV
Has fuzzy spots all the way across the screen and just scrolls up
Is the picture fuzzy whether you are waching tv or a dvd or a tape. If it's only fuzzy on tv or dvd or tape then it's the source. If all inputs are fuzzy suspect a bad tv.
Apr 04, 2009 | LG 42LC2D 42 in. LCD HDTV
It could be the focusing, did you check the focus every time? A slow shutter speed also causes blurry pictures. I know you do use your tripod, but if you don't use the self-timer function or a shutter cable then you are not using the tripod properly. Also, check the front piece of glass in the lens, clean it if it has stains or whatever on it.
Mar 28, 2009 | Kodak EasyShare Z1015 IS Digital Camera
Fuzzy Picture
Fuzzy is a funny word. I never use it to describe a picture problem. That because fuzzy can go too many different ways. There is snowy fuzzy, blurry fuzzy, grainy fuzzy, and demodulated fuzzy. If the set goes out of focus intermittently that has something to do with the focus ciruitry. If it goes grainy that is a front end problem, usually tuner related. The other types of fuzzy are generally associated with problems in video processing some where. So, which is it?
Oh, and BTW that unit has three small picture tubes in it, one red, one blue, and one green. It doesn't have a 'bulb'.
Feb 24, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Philips 34pw9818 fuzzy screen
Inside the set you should see a large part with a red wire coming out the top. That is the flyback transformer. There will be 1 or 2 controls on the back of it. One should be labeled screen and one focus. Carefully adjust the focus one until the picture is again in focus. Please note that in that area are high voltages (33,000V) that can be dangerous. Be careful where you touch. IT is best to have a mirror so you can see the picture while adjusting the focus control.
Feb 04, 2009 | Philips 34PW9818 34" TV
Blurry picture
If you know where the fly back is, ok open the casing and see at the back of the fly back, there are two knobs, one for the focus and the other is for the brightness. Try twist both and see which one is for the focus. Ok, from the focus knob try adjusting until the fuzzy sight disappears. Try this, I usually do it to screens with blurry appearances.
Nov 10, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture problems and need service manual.
Apr 19, 2008 | Samsung HC-R4755W 47" HDTV
Samsung model HCN4727W
I had the same problem with mine until I figured out it was from the auto self focus. Normally it should be done with a picture that remains constant or close to it, or else the focus gets screwed up. Go to menu and setup, then turn the self focus off. If you look on the remote and slide the lower portion down you will see a self focus button. My suggestion is to put a DVD in and hit the pause button and then press the self focus button and wait until its finished.
Jan 21, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung rear projection tv has multiple images with differnet colors
The auto self focus screws up if the picture does not remain constant or close to it while focusing. It is designed to self focus every fifteen minutes. Go to menu and then setup and turn the auto focus feature off. I have had mine off for the past year and have had no problems. If you slide the bottom portion of the remote down you will see a self focus button. My suggestion is to put a DVD in and hit the pause button during a scene and then hit the self focus button. It should align back up and may take a couple of tries. (If you have an aftermarket remote, just enter the menu and then setup and you can activate the self focus feature, just don't turn it to auto focus!)
Dec 31, 2007 | Samsung HC-P4752W 47" Rear Projection...
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
112 people viewed this question
Jerry Greenberg
Jerry Greenberg
