Model 8045-20--What is a reasonable defrost duration for this unit attached to a small walk-in freezer (6 feet wide, 5 ft deep, 7 ft high). I had it set to 30 minutes every 2 hours, but it does not defrost completely to the top of the cooling fins. Thanks.
the problem is not necessarily with the timer. it seems you have more than ample time and time allocations to perform a complete defrost. most walk ins should have roughly 25-40 minutes of defrost every 4 to 8 hours. if you defrost with a heating element, you may have a problem with the strength of the element,or the element may be pulled away from the coil. you could also have a problem with the defrost thermostat(allowing the defrost to terminate prematurely)
If the air flow and temperature are not being compromised leave it alone. If there is a gradual build up of ice on the evaporator you may have a defrost element or defrost limit switch problem. Set the defrost duration duration to 45 minutes and see if that solves the icing problem. 4 defrost cycles a day should be enough to keep the icing problem at bay. 3 defrost cycles at night about 1 hour apart may also remedy the problem. Experiment until you find the right combination of defrost cycles for your freezer. Watch for any thawing of the product in the freezer and adjust accordingly. Bills Refrigeration/Montana.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Paragon 8145-20 Defrost Timer
I have an Amana side by side that would not cool. Replaced defrost timer and defrost thermostat. The...
(More)
I have an Amana side by side that would not cool. Replaced defrost timer and defrost thermostat. The fridge worked for a couple days then stopped cooling. Fans run constantly. The only frost build up is at the defrost thermostat. Defrost heater comes on when I manually advanced the defrost timer. Any suggestions
Hello, can you tell me where can I find online install and use instructions for a Paragon 8145...
(More)
Hello, can you tell me where can I find online install and use instructions for a Paragon 8145 defrost timer?
