Question about Ovens
Instructions required - Ovens
I have a GE double oven. JKP44G with touch pad controls
Top oven door will not lock for cleaning cycle. I think I need a new motor for that.
Bottom oven will work sometimes and other times when I turn it on and select the temperature, thinking it is coming on - all of a sudden the temp light goes out like the oven is off and the oven does not heat. Sometimes I touch the clear button and then turn it on. Sometimes it works and other times not.
Could the connections in the control panel be dirty and not making connection at times?
Main question. How do I get to the control panel. How can I pull the oven out to clean the circuit or connectors and change the door motor. If I could just get into the panel I feel I could fix it.
Posted on Nov 15, 2008
Error code F3E3 on whirpool self cleaning oven Shut off oven Now only broiler will work. Why
The fault code F3E3 requires replacement of the oven temperature sensor. I suggest you contact www.repairclinic.com for help with repair instructions and the part you need.
Apr 19, 2017 | Ovens
No instructions
here again MAKE AND MODEL required search Google
Mar 18, 2016 | Ovens
What temp do you cook cakes in if you do not have a fan forced oven
Different kinds of cakes require different temperatures. Most cookbooks tell you what temp to use for each recipe. Same goes for cake mixes. The instructions on the box are way smarter than me.
Mar 16, 2015 | Ovens
Can anyone provide the correct wiring instructions for a replacement oven 6 button timer (C00224982)unit for a Cannon Harmony Duel Fuel Cooker. Old unit has 4 terminals, new one has 6. No instructions were...
Hi, I would contact your supplier, it could be that they have supplied the wrong unit or that it has been modified since original manufacture, these things sometimes require links but normally all the kit required is in the box along with instructions.
If the unit is correct the supplier should be able to tell you what the connections are in relation to the existing unit. Hope this helps.
May 23, 2014 | Ovens
What is max tem exhaust fan do i need for this oven
Check manufacturers instructions this will give sizes and parts required
Jul 12, 2011 | Blodgett 911-DOUBLE Gas Oven
How do i vent my gas oven for my deli. i bought it used and do not have proper venting instructions?
Contact your local municipality's Building Inspector for code and fire department requirements for commercial installations. There will be a permitting process and fee involved but at least the installation will be done properly and not void your insurance.
Dec 21, 2009 | Blodgett (ZEPHAIREG-DOUB) Double Oven
Hello. I have a smeg stainless steel oven in my rented house. I have a problem IN KNOWING of what tempertaure I should use for making cakes. Canadian would be 350F.Many thanks. Leila
350 is a good starting point. Some cakes require different temperatures. May I suggest that you read "The Cake Bible" for excellent instructions on temperature.
Sep 29, 2009 | Smeg SE210X/1 Stainless Steel Electric...
Manual
You can download the instructions you require by going to the Hotpoint web site.
In your browser bar type in --hotpoint user manuals
In the list click on---manuals-user guides-handbooks
In the search box enter the oven model number and download as req'd
Plz rate my solution.
Thanks.
Jan 26, 2009 | Hotpoint Ovens
Clock setting
Press the fourth button from the left (that looks like a tick) then turnthe knob to the right of it to set time as required
Feb 06, 2008 | Neff B1641 Single circotherm super...
Ovens Logo
168 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
