Question about Whirlpool Dryers
Timer runs but dryer has no heat
Dryer has no heat
  • jlhudson3 Nov 15, 2008
    its a whirlpool electric dryer "ultimate care 2". basically it was running just fine went to check on clothes and dryer was still running but there was no heat
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Is this an electric or gas dryer?
  • 5,911 Answers
Okay...the following link will give you the steps necessary to diagnose and/or repair an electric dryer with a no heat problem:
Read the bottom of the link first. Verify your receptacle voltage is reading 220-240VAC. If you're only reading 1/2 the voltage you could be missing one leg of the 220 service. This will still enable the dryer to run, but the heating circuits will not operate. The reason is the drive motor only uses 110-120VAC, while the heating circuits require the full 220. If this is the case, a receptacle repair is required. Unless you are savvy with electricity, I would only recommend this repair be done by a certified electrician. If you're source voltage at the receptacle is good, then I would assume you have an internal component problem.
Read the section that discusses proper dryer ventilation. If the dryer vent ducting is clogged anywhere, and left in that condition, to dryer heating circuits will actually overheat and result in premature failure.
I hope you find this information helpful. Let me know if you require further assistance.
Posted on Nov 15, 2008
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ... > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
My Kenmore dryer will not heat or turnoff. I have
the timer will not advance without heat.the dryer heats up when it reaches temp. the heat shuts off and the timer advances,when the heat comes back on the timer stops,send the model number next time,
Jul 31, 2010 | Kenmore Dryers
The timer doesn't work. The dryer just runs until
is the heat working?when the dryer heats up and then the heat will shut off then the timer advances,when the heat turns back on the timer stops,heat shuts off the timer will move again,if the heat is working you could have a bad timer
Mar 12, 2010 | Frigidaire GLER341A Electric Dryer
Roper dryer runs but has no heat
my roper dryer does not heat up i checked thermostat, thremo fuse and heating element they show working could it be my timer when dryer is running timer does nt advance it stays in the same position.
Jan 11, 2010 | Dryers
Dryer won't heat
you spent a lot for a timer when you needed to check your heating. check the heating element, the high limit, and the thermofuse
Sep 25, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool electric dryer
As long as the timer is on your heating element will be on.Sounds like you've have lost both.
Feb 11, 2009 | Whirlpool LEQ9858P Electric Dryer
No heat and the timer won't turn the dryer off
The timer runs thew the heat cycle with no heat it will run forever the heat runs thew the timer and thew thermstats and thermal fuses be for going to the heat elament check for 220volts at the heater if the heater has 220volts to it and not heating the elament is bad
Nov 30, 2008 | Roper RGX4634KQ Gas Dryer
Dryer doesn't heat and runs constantly
depending on the model; if the timer is in the automatic cycle it will not advance if there is no heat, it must heat in order to satisfy a thermostat to tell the timer to advance this is what makes it automatic. If the timer gets to the end of the timed cycle and will not advance to off, sounds like a bad resistor connected to the timer, I would first check the heat circuit to find out why its not heating. Dont mean to complicate, but everything in the dryer has something to do with heating, element,thermostats, temp switch, timer and even the motor. Check for burnt wires at the terminal block for the cord. hope this helps.....
Nov 19, 2008 | Dryers
Roper dryer, timer doesn't time out and not heating up?
Dryer will run forever if it doesnt heat up, Dryer has to heat up and thermostat has to get hot and open to start the timer. Odds are rally great, it is your heating element.
Oct 01, 2008 | Roper REX4634KQ Electric Dryer
Kenmore Dryer
I am sorry to hear this, my name is Marc White, i am self employed and it seems as though you have a bad timer, bad timer will cause the timer not to go to the off position and blow your fuse......change your timer..
Apr 03, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
41 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
