Question about E-Machines eMachines Desktop PC
My e machine turns on okay but after a short while it freezes up
I have to turn it off manually. the cursor still moves but the computer does not respond to any command including to cont alt del.
  • 3 more comments
  • ballard7656 Nov 15, 2008
    I have windows XP and the computer boots up fine. After about 1/2 hour, it freezes and nothing moves except the cursor and I have to turn it off manually and reboot.
  • ballard7656 Nov 17, 2008
    My computer is 2 years old. No recent hardware installation, My husband and myself are the only users. 1 user account and 0 administrator account. I use most of the software that is installed I have never ran a error check on the harddrive and I recently defraged. I am unsure of the hard drive size but I am pretty sure I have alot of memory. We have no pets. I have high speed internet. The mouse pointer moves, SBC global provides its users with Norton anti virus and I also have Spyware doctor and spybot. I have checked the vents and the air from the fan is warm not hot.
  • ballard7656 Nov 22, 2008
    THANK YOU!!!! I finally got the courage to take the cover off. There was a ton of dust in the case. I blew it out yesterday and this morning I turned it on and it did not freeze up. I had held my hand over the vents and the air didn't feel hot, just warm. Anyway I took off the cover and it was full of dust. Once again thank you. You saved me alot of money!
  • bobfiala
    bobfiala May 11, 2010
    How old is it?
    Have you added any hardware, drives, or memory to it recently?
    Are you the only one that uses it, or do kids and others use it also?
    How many user accounts are there?
    How many administrator accounts?
    Is there a lot of software installed that never gets used?
    Have you ever run a error check on the hard drive?
    Have you ever de-fragmented the hard drive?
    Do you know the size of the hard drive(s), and how much free space is available on it/them?
    Do you have pets that shed, or have it in a dusty/dirty environment?
    Do you have a "always-on" internet connection?
    You said that "the cursor still moves". Do you mean that the mouse pointer still moves?
    Do you have an anti-virus installed and updated? If so which one?
    Do you use a mal-ware scanner such as Ad-Aware or Spybot Search and Destroy?
    Without knowing the answers, I'd guess overheating also. Though that doesn't explain the cursor/mouse movement. Fill in the blanks and I'll take another crack at it.
  • bobfiala
    So it turns on and boots in Windows without a problem?
    Which Windows operating system (98/XP/Vista)?
  • 28 Answers
I'm still leaning towards overheating (or maybe a virus). It you feel competent to do so, disconnect your computer, remove the cover and remove all dust, hair, and debris from the interior (a lot can accumulate after a few years). It's not really as hard as it sounds. You'll need a small can of compressed air (available at office supply or department stores), a smallish long bristled paint brush (or similar), and a vacuum cleaner with a hose. Disturb the dirt with the brush and the air, sucking it all up as you go. Be sure to clean the CPU well. It's square, with a heat sink and/or a fan mounted on top of it. Dust is not so bad. Hair and/or dust bunnies are worse, be sure to get it all. Wait a hour to be sure any moisture from the compressed air has a chance to evaporate before plugging it back in.
Run a system wide virus scan. Even though your anti virus is installed, and up to date, it doesn't mean a virus can't get onto your hard drive. Some viruses have a nasty habit of shutting down, crashing,or freezinng your PC when they can't do the things they want to.
You can also try running an error check. It's located near the Windows Defragmenter. Just scan and repair file errors, don't worry about the surface scan.
Go to and download and run program called CCleaner. It's free and safe. It will remove a lot of useless junk from your hard drive and also contains a light-weight registry cleaner that might help.
Let me know if any of this helps at all.
Posted on Nov 20, 2008
  • 300 Answers
It sounds like it may be overheating or there is a problem with a program that is running. For the overheating issue I would check the fans and make sure they are running by place your hand over the exhaust holes and feeling the temp of the air. It should be slightly warm but not hot.
If that seem ok you can try running Msconfig and disabling all startup programs one by one by these steps:
Start > Run > type Msconfig and press enter. After that click the startup tab. Here you will see programs that load when Windows starts.
If you recognize the program thats causing the issue, simply click the box to the left of the item to uncheck it and click OK. You will then be prompted to restart.
As the machine restarts, check to see if the issue has disappeared.
If so, great. Be aware that you that you will be prompted with a "System Configuration Utility" dialog that lets you know you are using Msconfig. If you don't want to be warned of this, click the box that says "Dont show this message..." and click OK.
If not, run Msconfig again, and uncheck the next suspicious program and repeat the process until the problem disappears.
Below is a link with information on using Msconfig. It also has other links that include information of some of the programs that you might see in the startup window of Msconfig.
There's is a "Disable all" button under the startup tab. But I wouldn't suggest using that initially. It is better to uncheck them one at a time so you can see what is causing the issue.
Hope this helps. Please remember to rate this information. Thanks
Posted on Nov 16, 2008
Why does laptop cursor freeze and screen turn white?
Have you ever had the inside of the laptop cleaned out?
If not this needs to be done. If it has been a longtime, this needs to be done also.
What is the model number of the Sony VAIO?
Bottom of laptop.
PERHAPS I can find a Service Manual, and/or pictorial disassembly information. Then we will see if you wish to perform this procedure.
It doesn't take a rocket scientist. (Sorry Gort!)
Reply in a Comment.
Feb 25, 2013 | Sony VAIO Computers & Internet
Cursor won't move
Buy a new one or slam it as hard as u can
Aug 23, 2012 | HEWLETT-PACKARD Envy 17 3D Edition 20 GHz...
What to do when cursor is not moving/freeze?
Hook an external mouse to the laptop, If okay! there is a problem with the mouse pad, but if both show the same it suggest a device driver issue, or a virus. Remove one ram stick any change? now take out the other and put the first one back, any progress? next, remove the main battery and turn it on, batteries can cause all kinds of symptoms.
Mar 08, 2012 | ASUS Eee PC Seashell 1005PEMU27WT 101Inch...
Computer freezes everytime i turn it on, anywhere between 5 minutes to 1 hour. the cursor still moves but that is all. tried scan and defrag. computer will not do a recovery. restore calendar won't go back...
this can cause by virus and running a virus software will just makes your computer to freeze up the best solution would be to reinstall your Operating Software.
Oct 03, 2010 | Sony VAIO RB30C (VGCRB30) PC Desktop
When computer is idle for an hour, mouse cursor freezes up and will not move.
The mouse probably turns off to save battery. That would be my first guess.
Apr 19, 2010 | Logitech LX7 Cordless Optical Mouse
How to remove "in retail store mode with settings" message
Question What should I do if my TV is stuck in Retail mode? Answer Your TV may have been set to Retail Store mode, which is mainly used on the shop floor.
For home use, we recommend that you set the TV to HOME mode, which will allow you to change the settings.
To change to HOME mode follow the steps below.
  1. Press the 'MENU' button on the remote control to access the main menu.
  2. Move the cursor down to select INSTALLATION and move the cursor right.
  3. Move the cursor down to select PREFERENCES and move the cursor right.
  4. Select LOCATION and move the cursor right.
  5. Move the cursor up/down to select HOME and press the 'OK' button for confirmation.
  6. Press the 'MENU' button to exit the menu.
Sep 29, 2009 | Philips 42PFP5332D 42 in. Plasma...
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
My new Acer PC has freeze problem often
A freezing problem can be any number of things.
Remove all peripherals first. on't use a mouse, external monitor, printer, etc... Rule that out.
In order to rule out a software problem, you should restore to original factory configuration. The computer may have come with a CD that you boot with, or you may have to press <ALT><F10> during boot to access the restore partition. If you do not do this, then you are on your own in trying to figure out if it is indeed a software problem that you have.
After restoring...if it still freezes... you obviously have an internal hardware problem. Is it new? Warranty you have.
Old? Bough it used? Clean the fan. It's probably dirty and overheating. Overheat is usually an immediate shutdown, but it could be another chip besides the CPU overheating and causing your problem.
Jun 24, 2008 | Acer Computers & Internet
PM2F 100005615 Mouse
When you start up, have to mouse on the one that freezes and then switch off that one. (turn on the one that freezes first and have the mouse set it. then once it is on boot the other one and then switch mouse.
Nov 26, 2007 | Computers & Internet
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
