I need to rest my Macbook back to factory setting, and get pass the admin pass word too
SOURCE: macbook pro unexpected shut down
After determining the battery health:
http://support.apple.com/kb/HT1519
Then calibrate the the battery:
http://support.apple.com/kb/HT1490
SOURCE: my macbook wont come back from sleepmode its
Hold down the power button for about 15 seconds... the computer will power off completely. Then you can restart... This problem is a result of a hard drive safety device that will lock up the computer to protect against sudden jolts and shocks... It's more evident when the power adapter isn't hooked to the computer...
When opening your macbook, keep it still, level if possible...that will make a difference...
Here's further discussions and ideas...
Let me know if you have success!
SOURCE: I have connected my macbook to my tv using mini
Later MacBook (Pro) use a mini-DVI connector that does not pass analog needed for composite or S-video. Was yours ever working? And most DVI connectors do not pass sound as seen by your cabling. You cannot detect display through RCA. You just set it in Sys Prefs :: Displays, try some other settings, although your seem right.
I have a white early-2009 MacBook and mini-DVI to HDMI adapter (monoprice <$10) and HDMI cable and have not connected the TOS-link for sound, yet--just slideshows at 1920x1080. You will get a much better picture digitally.
-Ken
SOURCE: MacBook 13" starts but screen is barely visible.....
could be your inverter board, whitch controls the backlight. I could very well be the backlight as well, but that is less likely. Inverter boards are not all too expensive, and if you are knoledgable with laptops, i would say doit yourself, but if you have any doubts, take it to apple, sur it will cost more, but it is the safet bet.
SOURCE: I'm trying to connect my phone to my macbook pro
Hi no you do not need dirvers the phone is leeting you because they dont have IPCC TEATHER so they dont allow you ive tried it with mine
If i helped please rate high Cause it helps ME
Thanks....Nick
Testimonial: "Thanks, I wasn't aware of that."
