New 256 Mb RAM in Compaq Presario 17XL2 not recognized
Bought two 256 Mb sticks to replace the one 64 Mb that came in the laptop Presario. PC won't even put logo on screen so apparently no POST. Replacing the outboard card with the original (leaving the new card in the inboard slot) shows a POST summary with 320Mb and boots to a message that ''himem.sys has detected unreliable XMS memory at 04001960...'' . Opened the configuration tool and found 64Mb maximum - increased to 512 with no improvement. Machine will boot with 64 Mb card in inboard slot unless new card is in outboard slot then no POST. Found one internet post that there might be an ECC/non-ECC issue but no option on CMOS setup. The new chips read 256MB synch 133MHz CL2 and PC133-333-542 plus MT1BLSD8464G-13381. I have replaced the Pentium with a Celeron if that matters. Thanks for any assistance whatsoever.
Don
  • hooks_d Nov 14, 2008
    Actually, the celeron is 500 MHz and the faulty Pentium was 600. If I can get the memory issue fixed I plan to upgrade to a 1 GHz Pentium. The diagnostics don't show a problem with the old memory and the replacement CPU. Both new chips behave the same so they are either both bad or ? The motherboard is a Tiger built for Compaq and I can't find any jumpers or switches but I did use the configuration tool to tell the machine to accept more memory. The motherboard was built in 2000 so I'm pretty sure I won't be able to find any info on it - unless you know of a source. Thanks for looking at this for me.
    Don
  • Frank
    Frank May 11, 2010
    is the replacement CPU have the same frequency or it is higher.?
    if it is not the same frequecy. you need to look on the motherboard and change the CPU frequency configuration to match the new chip.
    there may have memory select on the motherboard. you need to change that also.
    second. the second memorie chip may be bad (very unlikely).
    Genius:
  • 1,605 Answers
500Mhz CPU use DDR333/400 memories. majority are used in MAC.
800Mhz CPU use DDR2 400/533/667 Mhz.
look like either you cna change the CPU or change meories again to match them up.
Posted on Nov 14, 2008
Which ram support for compaq presario c700 tu''
This laptop can have a max of 2Gb of ram, (2x1gb)
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot, None-ECC
Hope this helps.
Aslong as you get 512Mb or 1Gb sticks of PC2-5300 none-ecc laptop ram, you will be fine.
Jan 02, 2010 | Compaq Presario 700 470024-192 Notebook
RAM increment
yes just pur chase 1 128 MB or 512 MB or 256 MB ram but check first *********** bord ram module
check your old 64 Mb ram if it has 1 notch it is ddr1 or ddr2 if it has 2 notch it iks sdram
then pur chase from shop.
then fix it on secodn slot
Apr 24, 2009 | Compaq Presario 5000 PC Desktop
Presario won't recognize second 256 RAM
Remove the original module, install just the new one and then start your computer. If it doesn't start, the memory you bought is bad. The system boards used in the Compaqs will auto-detect memory, and there are no jumpers or BIOS settings needed.
Apr 09, 2009 | Compaq Presario 5000 PC Desktop
Need to know mem spd...333...400 etc to add cards
Memory Installed 512 MB (2 x 256) Maximum allowed 4 GB* (4 x 1GB) requires the replacement of the installed 256 MB DIMMs
*Actual available memory may be less Speed supported PC3200 MB/sec Type 184 pin, DDR SDRAM DIMM slots Four Open DIMM slots Two
Thats the sticks you need
Good luck
Nic
Feb 26, 2009 | HP Compaq Presario SR1630NX PC Desktop
Well i have a compaq presario 1700 XL360 it came with pc100 64 memory ram i tried to upgraded with two 256 memory ram to bring it to total 512 mb thats the max for this computer ...
There is a good chance that your system needs a firmware upgrade in order to recognize the bigger memory. I found one in this page
Be carefull and follow the instructions since you could brick your system.
If that does not work, do not expend more money in that system (very old), just save to get a new one.
P.S. The memory you got is the right kind.
Good luck
Dec 12, 2008 | Compaq Presario 1700 Notebook
Upgrade ram on 12XL125
Specifications for the Compaq 12XL125 state that the system memory is:
64 MB 100 MHz SyncDRAM, shared memory architecture, upgradable to 192 MB - 4 MB dedicated for video memory
This system will not be able to use the ram you are trying to install.  For more about this system go to this link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00013744&lc=en&cc=us&product=95040&dlc=en
Aug 16, 2008 | Compaq Presario 12XL125 Notebook
Ram
Check the configuration of your system, it probably supports 128 MB of RAM at max.
Jul 16, 2008 | Compaq Presario 5000 PC Desktop
What are the ram limits on a compaq presario 5000a. I put 256 ram in the compaq and it only reads 128. Why?
You can install up to 3 sticks of 512 mb of memory. Did you add a 256 stick to the already-existing 128? You need to put DDR266/PC2100 memory. To troubleshoot, remove the 128 stick and put your 256 in and see if it is recognized. You will know right away from the bios screen. Memory needs to be the same type.
Jul 16, 2008 | Compaq Computers & Internet
Compaq Presario M2000 PC Notebook
The Bios on the laptop motherboard only will recognize a total of 1gig Ram. So the 256 stick would be removed and 2- 512 sticks installed.
May 22, 2008 | Compaq Presario M2000 Notebook
Computers & Internet Logo
124 people viewed this question
David Payne
David Payne
